Go-Tech Engines Thread
#5898
Has any1 seen the new Go-tech Motors, i bet they'll be insane!!!
http://www.amainhobbies.com/index.ph...filter_mfr=168
and your welcome
and your welcome
i have the race prepped ebmods 5 port and im getting between 9-10 mins run time with 7.5 insert in there and go 0801 pipe just little info for ya thnx will g
#5900
the venturi set comes with 6.5 7.0 7.5 and 8.0 that you can buy... the pipe works well with it im going to try 086 dynamite with long header too and standard header to see what i like more maybe find something i like more later will g
#5901
#5902
http://www.amainhobbies.com/product_...ducts_id/34006
#5903
I think the 007, 053 and 086 come with the same header because I can only find one and since you already have the 007, then you can just buy the pipe for 35 bucks and use the 007 header which I suppose should be the same.
#5904
I have been looking for a new motor for my truggy and I have had good success w/my buggy's go motor. Based on what you say the 5-Port would be my best bet.
What is the general consensus on the MM 5-Port?? Would it be a good choice over the standard (non-modded) for mostly club racing and a few larger events? Is the Massive Mods motor a good choice? If so what pipe would be good, can you give a few choices factoring in price? Anything special I should know about running modded motors? This would be my 1st modded motor and I just have a few questions before making the leap....
Thanks for any answers.
Rex
#5905
That interesting to hear that......However I gotta say that definitely doesn't apply to my engines and the type of modifications that I do... I would be very unhappy if any of my work caused a loss of bottom end, of course unless a customer is looking for that.....edit... On many tracks some of my drivers are dialing bottom end out by gearing up or running soft clutch springs.....
#5907
#5909
I think 22 Racer needs to run a modified engine done correctly
It would also be nice for you 22 Racer not to lump Me or other modifiers into your general comments.
Cheers MM
#5910
I have to agree with you guys there. I have run both the stock 5 port and MM Stage 5 5 Port. Without a doubt the Stage 5 is nasty compared to the stock motor. Both bottom end and top end power are noticeably increased. Perhaps the delivery of the extra power is a little smoother, but the extra power is certainly there. There is definitly no loss in bottom end. Unless I run the 6.5 restrictor and am smooth on the trigger finger, things get ugly pretty quickly.
Same thing with my 7 Port. Not modified nearly as much as the 5, but the tricked up sleeve has definitly given the 7 a new lease of life down low and mid range.
Maybe it's a smoother power delivery down low that is tricking people into thinking it is a power loss ? - although I would find it very hard to describe the MM5 as being softer then a stock motor
2Likes
