Like Tree2Likes
Go-Tech Engines Thread
Old 03-12-2009 | 08:20 AM
  #5941
hey,
how many o rings on each needle of the carb? just one, correct?
racer6888 is offline
Old 03-12-2009 | 09:48 AM
  #5942
Sohot you are fine just run it. read my post though about the seal in the bearing moving though.
malik is offline
Old 03-12-2009 | 02:11 PM
  #5943
i have been blowing glowplugs...could this be a result of this? but then again i have been tuning the motor thinking i had the long carb but it turns out i have the intermediate. which means my hsn was too rich...will overly rich top end kill glowplugs?
SoHotRightNow is offline
Old 03-12-2009 | 02:57 PM
  #5944
grizz1's Avatar
Originally Posted by racer6888
hey,
Correct, just one on each needle.
Being way rich will kill plugs eventually. Just like when a plug quite often dies after break in. Don't stop your motor by blocking the exhaust off either. This definitely kills plugs real fast.
Try setting the HSN to about 1.5 turns in from flush and LSN about 2 turns in from flush to start with, and tune for a clean top end from there. Then set the LSN for a clean take off and 4 - 5 sec pinch test.
grizz1 is offline
Old 03-12-2009 | 02:58 PM
  #5945
22Racer's Avatar
It was sitting for a few days with the tank empty. i took out the flywheel to change it and found some dirt caked on the bearing. when i went to wipe it out. a little while later it looked to be that a little bit of fuel starting seeping out of it. wiped it again then no more...what are the simptoms of a leaky bearing. i have only gone through a gallon on the engine
It is fairly normal for some dirt to be caked on the bearing after removing the clutch. If it is bad it will leak as you run the car. After a heat it will be damp and dirt will be caked on the chassis under the clutch.
Rex
22Racer is offline
Old 03-12-2009 | 03:32 PM
  #5946
MassiveMods's Avatar
All front bearings leak , some more than others . How to tell if the bearing is stuffed or not is put the edge of your thumb nail gently on the seal of the bearing. if you can push it round then you need a new one. if it dosent then its fine.
M
MassiveMods is offline
Old 03-12-2009 | 03:35 PM
  #5947
I said the same thing on the last page but massive explained it simpler thanks.
malik is offline
Old 03-12-2009 | 04:26 PM
  #5948
RETRO RC's Avatar
Originally Posted by ben1970
Hi Grizz,showed Paul and Adrian at the race and they were surprised tooPaul is going to get me a gen 5 crank.I`ll thro another rod and bearings in and let her rip again.I have a 5port waiting in the wings if this doesn`t workout.
Hey Ben,
did you find out what was locking the crank up, when you showed it to me the crank was locking on something but without removing it I couldn't see what.
what a demon of a track that was on the weekend talk about having to concentrate to find a way through the mine feild
Still a good result for Go engines with Jerry 2nd and myself 6th after a rough start
Adrian
I'm sure Paul will get your 7pt up and running just like new again
RETRO RC is offline
Old 03-13-2009 | 08:15 AM
  #5949
Default Doubts
Hello guys, I'm not sure if these question has alredy been made here, but here we go:
1- What is the recomended gluw plug and venture to be used during the break in process of a 5 ports GO Tech ?
2- What is venture diameter you are using on the 5 ports GO when the engine will be used on a Buggy ? I used to have a black OS, and for that engine I was using a 7mm venture. But I'm preaty new in a Go world.
Hope eveybody could help me.
Cestari
Cestaric is offline
Old 03-13-2009 | 11:49 AM
  #5950
grizz1's Avatar
Cestari
Hi Cestari, Just leave the stock black plastic 8mm venturi in for break in.
Several plugs work well in the GO motors. OS P3 or P4 seem to be a common choice.
Check out the break in method on the bottom of page 78 of this forum from Mugenb46. This is a good way to break your GO motor in. A lot of people change the con rod after the first 2 gallons too, just as a precaution, because these motors are so tight when new.
Depending on track conditions etc, probably the 7 mm restrictor for racing. If you still find the bottom end a little too much for your buggy, go down to the 6.5 mm restrictor.
grizz1 is offline
Old 03-13-2009 | 02:10 PM
  #5951
vyt666's Avatar
is this very 1st generation 5port engine im using?coz i dont know what are the differences between the 1st gen and the other gen thats been released by GO,but i think the carb is the revise one unlike the old one which is hard to adjust the idle stop screw coz its under the carb throat,im just curious about the different gen's of the 5 port
and what are the factory needle settings of this engine?
thanks!
vyt666 is offline
Old 03-13-2009 | 02:37 PM
  #5952
grizz1's Avatar
Can't really tell much from the photo. A lot of the changes between generations are internal. As far as I know the carb was changed quite a bit between Gen 1 to Gen 4, but the actual motor was not changed too much (somebody please correct me if I'm off track here).
The most recent change from Gen 4 to Gen 5 saw quite a few changes throughout the motor, including a new tapered cooling head, new carb, shorter LSN needle, modified "O" ringed pinch bolt, new crankshaft, and a turbo head button as standard.
grizz1 is offline
Old 03-13-2009 | 03:38 PM
  #5953
can you take some pics of the elements in the plugs .. that way we can tell whats happening to it ..
Old 03-13-2009 | 04:00 PM
  #5954
i threw them away so i will take a pic when i run this weekend...i can just tell you that they turned white in color. on one the fillament actually broke in two. it was also white with the broken ends black....im also racing this weekend at night, it will be cold around low 50's. what plug should i use? im currently using odonell 77t
Old 03-13-2009 | 04:32 PM
  #5955
That plug is fine I am curious to see what the prob is maybe a lean hsn?
malik is offline
