Like Tree2Likes
Go-Tech Engines Thread
Old 03-04-2009 | 07:54 AM
  #5791
i found the p4 to work good in pretty much all conditions
cjm1126 is offline
Old 03-04-2009 | 07:55 AM
  #5792
will g's Avatar
i run odonnell plugs in my 3 port race and ebmods 5 port i used 77t and 97t will g
will g is offline
Old 03-04-2009 | 10:20 AM
  #5793
mfrosty's Avatar
That's good to know. Anyone out there tried any of the McCoy plugs on the 5 port yet?
mfrosty is offline
Old 03-04-2009 | 11:27 AM
  #5794
Originally Posted by rageworks
Hey MM, how about posting a part number for the turbo head
button that's made for the .25 and also let us know who has
them in stock?
Any answer? Humm, I didn't think so.
rageworks is offline
Old 03-04-2009 | 01:18 PM
  #5795
grizz1's Avatar
Originally Posted by pgeldz
Ok, who am I kidding. I'm not waiting 2 weeks, ha ha ha.
I've decided on the Massive Mods modded 3 port race engine, with FULL break-in service. They even asked what type of fuel/nitro content I'd be using, as well as what pipe and which glow plug I'd use (most likely 086 and OS P3), so they can closely replicate those conditions when they break it in for me!
Now that's as turn-key as you can get, and FANTASTIC customer service!!!
I'll keep everyone posted...
- Paulie
Yep - Massive Mods is the best we have down here in Australasia. Product and service is tops.
Glad you went with the modded 3 Port R Spec, you won't be disapointed. Have fun kicking butt at the track with your "budget motor"
Yep - P3 or P4 is a good choice for the GO. OS plugs are getting a little more expensive now, but for an extra dollar or two I think the performance edge and longevity of these plugs in the GO motors is worth it.
The man is propably flat out bro. I doubt he will be able to help you with a distributor anyway. I am assuming you are in the US. MMods is in Australia, some 14,000 miles away in the South Pacific. Best you contact Brian at Pro Twister Mods, or Russell at Race Factor industries in the US. I'm sure they will be able to help.
grizz1 is offline
Old 03-04-2009 | 01:31 PM
  #5796
burnettk's Avatar
+1
burnettk is offline
Old 03-04-2009 | 03:54 PM
  #5797
Did you misunderstand what you were reading? The question
was directly asked to MM. No one else. I think he is a grown
man that can answer any questions himself.
Old 03-04-2009 | 05:37 PM
  #5798
MassiveMods's Avatar
here ya go
Part Number: 25-0206 Burn Room 25R Turbo
Remind me to ask you where you get your coffee from
M
MassiveMods is offline
Old 03-04-2009 | 10:18 PM
  #5799
grizz1's Avatar
Geez - just trying to be helpful. I wonder what crawled up his arse ????
Last time I looked this was an open forum. If you want to talk to someone in particular and don't want help, advice or comments from others on the forum, send a PM.
Hope you get better and can stop taking the pills soon.
grizz1 is offline
Old 03-04-2009 | 10:54 PM
  #5800
Guest
Default 3 port r spec help
Hi guys I got a 3 port r spec stock. What should the Temps be? And what should the needles be set at? And how long should a race motor idle for, I have heard a race motor should t idle for a long time at all.
T4-RC8 RACER77 is offline
Old 03-04-2009 | 10:58 PM
  #5801
Guest
Default 3 port
I am using a rb concepts 6 plug and 086 pipe and byrons gen 2 fuel
Old 03-04-2009 | 11:36 PM
  #5802
grizz1's Avatar
Temps - Don't worry about temps. Throw the temp gun away and tune for performance and smoke. To many things effect the temp any given engine will run at. Some guys run at 100 C, some at 115, some at 125. Depends on oil quantity and quality in the fuel, clutch set up etc. Anywhere between 95 C to 125 C is ok
Needles - will depend on what LSN you have in the carb (what generation your motor is).
Fairly safe starting point for most of the GO's is LSN 1.5 turns in from flush and HSN .5 turns in from flush. If you have a long LSN you won't need to go in any more on the HSN, just lean the LSN until you have a good tune (around 2.5 in from flush normally.
If you have the newer intermediate length LSN, then you will be able to go in further on the HSN (about 1.5) to get a good tune. LSN should be about the same.
Idle time - Hmmm no hard and fast rules there either. Again it depends on oil percentage in your fuel etc. I use a low % but high quality oil fuel, and can let my GO idle for a couple of minutes no problem - then gun it and it won't bog much at all. A higher percentage oil fuel will bog the motor down sooner and take off wont be as crisp after its sat for a while.
I wouldn't worry about it too much. Tune for a good clean top end, then tune the bottom so when you pinch the fuel line off (about an inch back from the fuel nipple) you get only a slight increase in revs (about 500 rpm) and the motor dies between 4 and 5 secs after you pinch off the line. This should be pretty close. It will idle as long as it wants to with the fuel etc you are using.
Hope this helps. Please no abusive replies - I'm feeling a little delicate after the last time I gave some advice on here
grizz1 is offline
Old 03-05-2009 | 05:21 AM
  #5803
Tabushi's Avatar
Well here is my DM One for the race this weekend. It will be my 2nd race on this class i ended 3rd on the first race but second race was not able to attend due to a bad motorcycle accident. I have medical permission for this weekend so i will try my best to race sorry for the crappy pics i took them with my cell phone :
Chassis : DM One
Motor : GO .21 5 ports
Pipe : GO 0801
Tyres/Wheels : Ipanema Sintec
Bearings : Avid RC
Shock and diff oils : Ultimate Racing
cya,
Pat
Tabushi is offline
Old 03-05-2009 | 07:20 AM
  #5804
coaltrain's Avatar
I'm about to order a .28 3 port and I have a question about my starter box. The one listed below is what I already have, I used it on my XXX-nt, will it have enough power to start the GO or will I need to buy a new box too?
http://www.amainhobbies.com/product_...ducts_id/17056
coaltrain is offline
Old 03-05-2009 | 07:23 AM
  #5805
Tabushi's Avatar
I would give it a try, for sure you will have problems for break inn because the engine its tight for that box, but after brak inn, you are set ... (i think)
cya, and good luck,
Tabushi is offline
