Go-Tech Engines Thread
#5973
hi peoples
I'm looking for a new eng. and just found this Item number: 220373384347on the bay. I cant find much info on it, is it a good eng? what does the "factory mod" part include? I have run SIRIO NOVARISSI V-SPEC ect in the past how will this compare? thanks in advance.
Buy from a local dealer and get some sort of back up service and warranty.
Cheers MM
#5974
Congrats man !!
And you got the new 0801 pipe series ... im waiting for mine !!, that stinger now its reinforced, very good !!
cya,
#5975
Hi, I have a 5 port go engine on my hyper 9, I used to drive in Bogota, 2.600 mts over sea level.
My problem is that every time tha I am re-fuling (pit stop) my engine flame out. every time.
What can I do?
I have changed: Glow pug, for 6 to 4, I have made shorter presure line.
What can I do?
#5981
I ran my ProTwister modded - Go Tech 5port this Saturday at ReoRaceway in Indiana. I was top qualifier for the B-main, bumped to the A-main and finished 4th after a 20min main. I was most impressed with only 1 pit at the 10 minute mark. The Go Engine continues to be a reliable choice.
Thanks,
Brandon
Thanks,
Brandon
#5982
Ok guys have a question for ya. Just broke in my new Go 21.7port turbo. runs flawlessly. Now that I took the alluminum foil off, I'm wondering what temps are normal for that motor because this thing is spot on and with the body on after a full tank ran through im only getting to 190 deg F? That amazes me and was wondering if thats normal or not. Thanks again guys
#5984
Rex
#5985
The stinger isn't reinforced in the picture I believe it is just a reflection from the plastic shrink wrap
Adrian
2Likes
