Old 08-01-2007, 08:28 PM   #8776
asw7576's Avatar
Originally Posted by tancp81 View Post
yes,at 1st i try adjust gun 1st, but is not epa or setting make this problem...
then my buddy spotted is the pinion area too tight (it should move freely...),so what we do ,we unscrew 2.5mm n screw back , it move freely again... (taken out 1 shims out)
then , i ran another fuel, come back, the pinion tighten again... same way i unscrew the 2.5mm again n screw back , it ok again...
anyone know what coz this ???my bearing are okie
ps:now every tank i use, i have to check that pinion if not , i start engine it will move by itself like 1/10 of trottle speed...
Check these : you have tire rolling problem on starter box , right ?
clutch gap = the difference between clutchbell and clutch shoe. They should be very close but not yet touching. How to do it ? Use some shims before the inside clutchbell bearings. Keep adding shims until the clutchbell spin freely. <---- I think your problem is here
end play = the play on horizontal axis ( clutchbell axis movement towards thrust bearing ). The play should be kept minimum by adding shims between the thrust bearing and the thrust bearing locknut. Spin your clutchbell again at this point.
Centax spring = Mugen Super Hard Silver or Kyosho Super Hard Black.
Centax spring tension = twist the centax spring locknut until 0.9mm deep. Not enough tension ( 0.5mm ) will engange the clutch too early.... causing a bogging effect ( lame acceleration ). Very high tension ( 1.2mm ) will cause your engine scream crazy while the car is not accelerating fast enough due to clutchbell slipage.
Old 08-01-2007, 09:39 PM   #8777
tancp81's Avatar
thanks 1st...
actually im very newbie at this machanical stuff, i not sure how does clutch , centax run / engage...(it also means that i dunno when to apply shims before bearing or after ) but it really solve the problem by removing n adding shims... i wonder why it will like that,is it too hot???...
thank again for ur reply n patient...
tancp81 is offline   Reply With Quote
Old 08-02-2007, 01:51 AM   #8778
asw7576's Avatar
thanks 1st...
here u go ....
Shims ? Get them from Tower Hobbies and search Tamiya shims.
Here my tips :
Always clean your engine after use....... even you stinks like hell, clean your engine as soon as you get back home. Use clean clothes, thick cotton buds and metal polish to clean engine internals. Take your time polishing engine parts. Spray with electric motor cleaners before assembling the parts again, and please use plenty of after run oil ( I recommend Mugen engine maintenance oil or Novarossi oil : clear type ) to put back the piston sleeve.
Old 08-02-2007, 02:15 AM   #8779
tancp81's Avatar
here u go ....
Here my tips :
thanks for ur pic, will try n check...
Old 08-02-2007, 04:35 AM   #8780
asw7576's Avatar
Sorrry......
this is final correction. ( I mistakenly typed end play for centax spring tension. The word end play should not been there ).
Old 08-02-2007, 10:52 AM   #8781
JayL's Avatar
Clutch?
What do I do if I have removed all shims near the thrust and still can't quite get .3mm movement forward and back of the pinions? the book says go .3-.5
my spring is tightened to 9.5mm, "mike s setup" I have about 1mm spacers so the clutch bell spins free of the clutch shoe, and it only just does
thanks
JayL is offline   Reply With Quote
Old 08-02-2007, 07:21 PM   #8782
Seisick's Avatar
jay
beware, clutch gap is set by the shims in the outer bearing and the bearing stopper, the endplay is set with the shims between the clutch nut and the first inner bearing, so if your desire is to obtain a clutch gap say to 0.6mm and even without shims you can not get that amount, what you do is to install in the top of the cranksshaft a shim with diameter 3x4.8x0.1 or 0.2mm. in that way you could obtain the desired clutch gap. please do notice that the first thing you should do is to set the gap and then the endplay, the manaul on the 720 and the nt1 have great instructions on how to set the centax system
happy racing!
Seisick is offline   Reply With Quote
Old 08-03-2007, 12:48 AM   #8783
asw7576's Avatar
Originally Posted by Seisick View Post
jay
happy racing!
Are you sure, you are not mixed them up ??
clutch gap is set by the shims in the outer bearing and the bearing stopper ?? ..... try yourself by putting shims between outer bearing and bearing stopper. The clutchbell still stick to clutchshoe.
the endplay is set with the shims between the clutch nut and the first inner bearing ?? ..... try yourself to put the shims between centax spring locknut and first inside bearing...... the clutchbell will move father apart from clutchshoe, right ? .... Is this the best definition for end play ? or is it the proper explaination for clutch gap ?
Remember, sometimes the manual book editor could be wrong interpreting drawings into english definition, or simply just made wrong explainations completely ( like Xray did about anti dive vs pro dive definition in T1 ).
Old 08-03-2007, 07:03 AM   #8784
itchy b's Avatar
I am wondering about the different front uprights for the mtx4?
I have the TO138-b and TO164 which is the 2 degree upright.
I believe that the original ones are TO138.
My question is, if the TO138-B uprights were to fix the bump steer issue, are the new TO164 uprights to make it even better or is there a different reason for the 2 Degrees upright?
Cheers
Joe
itchy b is offline   Reply With Quote
Old 08-03-2007, 07:55 AM   #8785
wallyedmonds's Avatar
to run the t0164 2 you need the t0151-b lower arm,it has better turn in
what it dose is shorten the upper link.
the t0138-B you need the lower arms too and it keeps the upper link the same as stock.
stock you get bump steer t0138
or you can say it makes more grip,your total setup matters,you can have more grip in the front but still push.
wallyedmonds is offline   Reply With Quote
Old 08-03-2007, 12:15 PM   #8786
JayL's Avatar
um, hmmm
guess I will check the nt1 and serpent 720 manuals
Old 08-03-2007, 04:38 PM   #8787
ShrekNZ's Avatar
I understand the only change for the T0164 upright is that the steering arm is 4mm lower allowing you to use shims to change the bump steer. However this will be limited unless you also update the lower arms as the new arms are cut away to prevent fouling. You can probably still run the new uprights but have to shim them to 4mm and thus not get any change.
Currently we are using 2mm where the kit MTX4 is 1mm
We've found this to be quite a useful tuning tool although it still kinda go's against the grain - I used to muck around with Hot Rod's ans bump steer was a real no no and is caused by bad steering geometery.
ShrekNZ is offline   Reply With Quote
Old 08-03-2007, 06:28 PM   #8788
the t0164-2
the upper pillow ball part is set in 2 making the upper link shorter.
hence giving more front grip in theory.
i us this most of the time.
its not 2mm its 2
Old 08-03-2007, 06:32 PM   #8789
Originally Posted by JayL View Post
um, hmmm
i dont know what could be wrong with your clutch the only thing i can say is start from the start and see where you went wrong,and read mikes right up in rc x mag
http://xrcmag.idigitaledition.com/issue.php?issue=4
Old 08-04-2007, 01:01 PM   #8790
Loveless's Avatar
Default Locking the front end.
Yo guys should i lock the front end of my car , some say it helps in breaking , some say it makes the car drive much more easier, which one is it, or is it both, orshould i just leave it alone?.
AIRTRONICS/KEVLAR R.D./MUGEN FUEL/PARMA, CENTRAL BODIES/MUGEN SEIKI/PICCO ENGINES/JP ENGINES/ BELTRANS WHEELS AND HOBBIES, KAMIKAZI RACING.
"Free your mind, and your ass will follow"...
Loveless is offline   Reply With Quote
MUGEN MBX5R/MUGEN MBX5T PROSPEC/TRAXXAS RACE REVO Jason Halvorson R/C Items: For Sale/Trade 14 01-12-2008 10:32 AM
USA's Most Wanted FOR SALE Mugen MBX5R,Losi 8 comp, and Mugen MBX5T Prospec Truggy nobike R/C Items: For Sale/Trade 69 04-28-2007 07:45 PM
Another MTX3 prospec w lots of parts and an optional Mugen X12 w Mugen pipe Scott Fisher R/C Items: For Sale/Trade 11 11-21-2005 05:45 PM
drake xxx nt and mugen mst-1+extras......Looking for a kanai 2 or maybe mugen buggy [email protected] R/C Items: For Sale/Trade 5 06-30-2003 09:31 PM
