Old 12-08-2007, 10:23 AM   #8926
YLLIB's Avatar
lil bump, you beat me to it......lol
YLLIB is offline   Reply With Quote
Old 12-08-2007, 10:51 AM   #8927
quietstorm76's Avatar
YLLIB ygpm
Team Shepherd USA:Nugget's Ranch Raceway
Primary Weapon: ?
Secondary Weapon: ?
Tires>>> I don't know yet
quietstorm76 is offline   Reply With Quote
Old 12-08-2007, 12:30 PM   #8928
rmdhawaii's Avatar
Originally Posted by Nitrorea View Post
Taking a few steps back here....my first Mugen kit,
As a side note, since this is your first Mugen kit, you might want to try checking out this Web site for some MTX-4 tips...
http://www.nitrokb.com/mtx4/
rmdhawaii is offline   Reply With Quote
Old 12-08-2007, 11:46 PM   #8929
YLLIB's Avatar
I hope this works for the guys that e-mailed me. Track SpeedWorld TESTED on both conditions - smooth, tight, high traction w/ VHT and clean no spray asphalt.
Front End:
198mm width
4mm ride height
2 deg camber angle
2mm upper arm spacer
.5 toe out
1mm rebound stop
no bump stop
use to138 steering blocks w/1mm spacer on steering arm
front sway bar flat
Rear End:
199mm wisth
5mm ride height
5 camber angle
1.5 toe angle
3mm rebound stop
no bump stop
lower arm position
2mm upright spacer
2.5 wire roll bar
3mm in on wire sway bar ball
0 wheel hub spacer
use to144 mounted on lower hole
Frt Shock
stock piston
600 mugen oil
springs light blue
middle postion shock mounted
Rear Shock
stock piston
600 mugen oil
springs light blue
3rd from the bottom shock mounted
Front - One way
Steering Ackerman -- A
Rear Diff -- 50,000
Tires 40 front and 40 rear ----- I use Jaco
Body - Protoform Stratus and stock wing
Good Luck Billy
Old 12-09-2007, 05:54 PM   #8930
Primary Weapon: ?
Secondary Weapon: ?
Old 12-09-2007, 11:19 PM   #8931
johndayo101's Avatar
Trader Rating: 128 (100%+)
Default mtx4 set up
Originally Posted by YLLIB View Post
Hello Johndayo101, I have Mike Swauger set-up on my car for the past 4 months and It is awesome for hi-bite track and med-bite tracks and is proven that it works on both contions, but you have to like steering and able to pull the triger easy at times but it is fast with that set-up and the one-way. I have put the diff the front with 100000 and it is good but around 2 tens slower at times but real easy to drive. I can fax it to you or I will also try to don load it to my next meesage or call me at SpeedWorld and I can give it to you quickly.
I hope this helps
www.speedworldraceway.com
nice website. do you sell parts for mugen mtx4?
thanks [email protected]
johndayo101 is offline   Reply With Quote
Old 12-09-2007, 11:40 PM   #8932
YLLIB's Avatar
Hello johndayo101, Thank you and yes I do. I will pm you on the set up
Billy
Old 12-12-2007, 07:26 AM   #8933
JRGTR's Avatar
Send a message via MSN to JRGTR
Default QUESTION?
Hello,
I have a quiestion about the side belt pulley, what is the diffrence of the 23T and the 24T side belt pulley? is about the transfer rate on the AWD or the feel of the car on handling on turns?
MTX5/Novarossi engines!
Byron's Racing Fuels/Airtronics
Matrix tires
www.pitlanehobby.com
JRGTR is offline   Reply With Quote
Old 12-12-2007, 08:07 AM   #8934
lil-bump's Avatar
Trader Rating: 83 (100%+)
I believe it's 24 and 25 tooth pulley. A 24 tooth on the side gives a little over drive (the rear turns less than the front). A 25 tooth will give more a 1/1 ratio meaning the front and rear wheels are driven at the same pace. But this all is dependant on you front and rear tire diameter. I believe this is correct. but don't qoute me. Look at the Rollout Chart from Mugen it will explain more.
lil-bump is offline   Reply With Quote
Old 12-12-2007, 08:29 AM   #8935
JRGTR's Avatar
THANX
Matrix tires
Old 12-12-2007, 08:39 AM   #8936
YLLIB's Avatar
Your right the overdrive changes, if you cut the tires as you would for the 24t and then put the 25t on the car will be under driven say 1/2 percent, say you cut your tire at 59mm frt and 61mm rear. But some of the drivers like the tire diameter are closer together so the rear doesn’t wear faster than the front and tires will be more equal from the start of the race. To acieve the same over drive the tire dia differance is around .5mm differance from frt to rear with the 25t. It is not the most correct answer, but it easy to explain it that way some racers try it.., lol. I tried it and I personally didn’t like it.
Old 12-27-2007, 09:55 AM   #8937
JRGTR's Avatar
Did any one meassure the steering angle with the set up station tools? I trying to have moore over steer on my MTX-4 without changing the Mtx-4R front upright. now I correct some ups! on the steering servo mount and the steering servo arm, now I am having 30o on each side. Is this good? because with the new front upright I'll get 2o moore but I want to try with out the upgrade first. please some feed back
Matrix tires
Old 12-27-2007, 12:23 PM   #8938
2CARTEAM's Avatar
Default MTX4 vs. MTX4R
Can anyone tell me what are the significant differences between the MTX4 and the MTX4R besides the option parts. Can a MTX4 be upgraded to a MTX 4R? We currently own a MTX3 and are looking to upgrade. Any input would be greatly appreciated.
2CARTEAM is offline   Reply With Quote
Old 12-27-2007, 01:59 PM   #8939
chippy's Avatar
The Major change from the MTX4to The MTX4R is in the front steering geometry
Different front hubs 2deg and the lower arms
The 4 is easily upgraded to the 4r
Just cant remember the other upgrades
But they where only cosmetic things like alloy wheel hubs
Iam sure someone will add the rest
chippy is offline   Reply With Quote
Old 12-27-2007, 01:59 PM   #8940
JRGTR's Avatar
yes, the diffrences are the engine mounts, new one way dif, front uprights and lower control arms and rear upper ars mount
Matrix tires
MUGEN MBX5R/MUGEN MBX5T PROSPEC/TRAXXAS RACE REVO Jason Halvorson R/C Items: For Sale/Trade 14 01-12-2008 10:32 AM
USA's Most Wanted FOR SALE Mugen MBX5R,Losi 8 comp, and Mugen MBX5T Prospec Truggy nobike R/C Items: For Sale/Trade 69 04-28-2007 07:45 PM
Another MTX3 prospec w lots of parts and an optional Mugen X12 w Mugen pipe Scott Fisher R/C Items: For Sale/Trade 11 11-21-2005 05:45 PM
drake xxx nt and mugen mst-1+extras......Looking for a kanai 2 or maybe mugen buggy [email protected] R/C Items: For Sale/Trade 5 06-30-2003 09:31 PM
