Old 08-04-2007, 04:12 PM   #8791
Osiris 75's Avatar
Trader Rating: 17 (100%+)
Originally Posted by Loveless View Post
Yo guys should i lock the front end of my car , some say it helps in breaking , some say it makes the car drive much more easier, which one is it, or is it both, orshould i just leave it alone?.
Do the lock, I've won my last 3 races with it!!
SPONSORS: AWESOMATIX USA / HOBBYWING USA / AVID CONCEPTS / R1 WURKS / POWERMASTER FUELS (VP RACING) / 2MM DESIGNS
RC TARGET/CAPRICORN USA / REFLEX RACING / ULTI TIRES
Chris Kemper
Osiris 75 is offline   Reply With Quote
Old 08-04-2007, 06:14 PM   #8792
Rc_Boy89's Avatar
Send a message via MSN to Rc_Boy89
Originally Posted by Osiris 75 View Post
Do the lock
I agree, the front locked is great comparing to the one way which was standard with my mtx-4 kit I found the car is much easier to drive and of course helps with breaking which I found lets me drive harder in and through the corners and if i stuff up I no I have breaks, not a handbrake which is going to spin me out and lose time
Rc_Boy89 is offline   Reply With Quote
Old 08-04-2007, 06:34 PM   #8793
wallyedmonds's Avatar
we all like diffs up here. my 2 cents.
wallyedmonds is offline   Reply With Quote
Old 08-05-2007, 12:23 AM   #8794
itchy b's Avatar
Originally Posted by wallyedmonds View Post
the t0164-2
the upper pillow ball part is set in 2 making the upper link shorter.
hence giving more front grip in theory.
i us this most of the time.
its not 2mm its 2
would this feature also kind of increase the castor, as when the steering turns left or right the camber would increase more than standard because of the 2 degree top set in position?
itchy b is offline   Reply With Quote
Old 08-05-2007, 04:26 AM   #8795
no
Old 08-05-2007, 05:46 AM   #8796
HarKonnenD's Avatar
Trader Rating: 23 (100%+)
Send a message via AIM to HarKonnenD
Any of you guys running any droop upfront? I'm still near there of the factory settings with just some changes to F/R camber and rear toe in. I swapped over my JR 9000S into my MTX4 for steering (robbed it from the MRX4) and the previous STR servo, the JR 4800S is now for throttle. Couldn't believe I had that mild servo in for steering all along as I thought I had the 8800s. Decided my next .12 will be the JLR so as soon as I get one I'll try it out and let you guys know how it runs in the MTX4. Such the plugs are $9 a pop...but so are the OS #8 Turbo P8s I use for my Carlsen TZ.
HarKonnenD is offline   Reply With Quote
Old 08-05-2007, 05:52 AM   #8797
LogiK's Avatar
Trader Rating: 11 (92%+)
Hey,
Im not getting my 2 speed cutting in (I have wound it out alot still nothing)
What are some thing I should look at, what could be causing it..
Thanks,
Cameron.
LogiK is offline   Reply With Quote
Old 08-05-2007, 09:51 AM   #8798
Osiris 75's Avatar
Little to no droop in the front.
Chris Kemper
Old 08-05-2007, 06:56 PM   #8799
ShrekNZ's Avatar
Originally Posted by LogiK View Post
Hey,
Thanks,
Cameron.
You may be starting off in second if you have wound out everything - it may be sluggish down low and changing almost immedately.
Set the shue clearance to almost nothing (probably about half the bals showing) and even and the tension to the screws flat across (per the manual)
Is you tuning ok if you are running too ritch for instance the motor won't reve out enough to engage second.
ShrekNZ is offline   Reply With Quote
Old 08-05-2007, 07:17 PM   #8800
1mm droop
and good luck with that motor
hey ninja plugs up here are $14:00 a plug.
novarossi plugs are$11;00
Old 08-06-2007, 12:22 AM   #8801
LogiK's Avatar
The tune is fine, will check the shoe.
Old 08-06-2007, 12:23 AM   #8802
HarKonnenD's Avatar
Wally- Wow that's expensive. Nova plugs here are about $5-$6 a pop. Not sure how much are the Ninja plugs though.
Old 08-06-2007, 06:09 AM   #8803
ya plugs up here cost a bit.
Old 08-06-2007, 03:29 PM   #8804
edward Haywood's Avatar
Looking 4 part # for new harder spur gears
Mtx-4.....Rolling baby/Blue Diamond /West Chester/
Magneto X-Woodawson/FX/Nitro forever/
edward Haywood is offline   Reply With Quote
Old 08-06-2007, 08:29 PM   #8805
asw7576's Avatar
I don't think there are any harder material than the stock spur gears.
Even the delrin type ( blue color ) from 3racing are not tough as advertised.
Yo..... Wally.... Do you know if I can use novarossi plugs into OS engines ( or Novarossi engines with OS plugs ) ?? .......... I heard the bottom tip of the plugs are different angle ?
Thanks man.
MUGEN MBX5R/MUGEN MBX5T PROSPEC/TRAXXAS RACE REVO Jason Halvorson R/C Items: For Sale/Trade 14 01-12-2008 10:32 AM
USA's Most Wanted FOR SALE Mugen MBX5R,Losi 8 comp, and Mugen MBX5T Prospec Truggy nobike R/C Items: For Sale/Trade 69 04-28-2007 07:45 PM
Another MTX3 prospec w lots of parts and an optional Mugen X12 w Mugen pipe Scott Fisher R/C Items: For Sale/Trade 11 11-21-2005 05:45 PM
drake xxx nt and mugen mst-1+extras......Looking for a kanai 2 or maybe mugen buggy [email protected] R/C Items: For Sale/Trade 5 06-30-2003 09:31 PM
