Old 06-12-2007, 05:13 AM   #8626
I'm just mounting my MTX-4R and I think that I saw the same problem with the steering rod/pivotball touching the upright. When I checked the instructions better I saw that I had forgot to put a small 1 mm washer between the pivotball and the upright.
With a washer in place everything is working like a charm again.
/Marcus
Minten is offline   Reply With Quote
Old 06-12-2007, 09:48 AM   #8627
quietstorm76's Avatar
I took mine all apart and noticed that on one side it had the old style(mtx3) pivot ball retainer washer. It's not recessed like it is on the MTX4.
quietstorm76 is offline   Reply With Quote
Old 06-12-2007, 01:05 PM   #8628
wallyedmonds's Avatar
ya its a little different so it dosent move around and sits more snug on the ball
wallyedmonds is offline   Reply With Quote
Old 06-13-2007, 07:41 AM   #8629
arr see car's Avatar
Location: West Ozzie living in Merrigum...Shepparton...Victoria
Default Droop
I did my droop today and want to clarify if I did it right as to TomB said in a earlier post.
Currently my droop setting are:
Front: +2
Rear: +4
Does this sound about right. Never played with the droop before.
Cheers
...Current Toys...
.....(: WIFE :)......
.MST MS-01D Pro.
....Axial Wraith....
arr see car is offline   Reply With Quote
Old 06-13-2007, 07:55 PM   #8630
rizal_eg9's Avatar
Hi all.....
I got a question, i like to know what is the effect off adjusting the steering servo saver...the manual instruction said to adjust the spring to 1mm.....what effect do we have if we increase the spring pre-load....as i can see that my front tires is wobbling on a fast right left kink....
Cheers.
rizal_eg9 is offline   Reply With Quote
Old 06-13-2007, 09:37 PM   #8631
Trader Rating: 14 (100%+)
Increasing the preload will put more pressure on the servosaver so it doesnt "cam out" as easily. The effect is that it will fix you wheel wobble (if it is from the servosaver) but you must be careful because the servo saver is less effective. If you bang a board hard enough, it can bust your servo.
thunderbt3 is offline   Reply With Quote
Old 06-13-2007, 09:43 PM   #8632
rizal_eg9's Avatar
thanx mate.....any tips on how to determine how much pre-load to add....any rules off thumb to follow???
Old 06-14-2007, 09:08 PM   #8633
Theres not any rules to follow but I just follow the manual. You can tighten it to your liking but run the risk of busting your servo if you're too tight.
Old 06-14-2007, 10:24 PM   #8634
asw7576's Avatar
I tightened 2mm deep.
My servo is Sanwa ERG VX.
Old 06-14-2007, 10:47 PM   #8635
rizal_eg9's Avatar
that is what i'm planning to do.....just like the MTX3.....and my servo is VX.....but i have killed a VR servo on my MTX3 previously....
Old 06-15-2007, 03:06 AM   #8636
I'm looking for a website for a good amount of setup suggestions. If you have a setup that works feel free to PM me. The track I race on is somewhat a tight track with low/med traction. I'm more interested in what type of diff to use in the front or oil wt. in F/R diffs? People at my track are supposedly running 3K-10kwt. fluid in the rear and 50k-60k in the front? Since I haven't seen many setups with a diff in the f/r I'm curious what others are using.
daveb is offline   Reply With Quote
Old 06-15-2007, 04:38 AM   #8637
10.000 rear
20.000-30.000 front
but 20.000-30.000 in the rear and a 1way front is better
but if you like better breaking diffs are better.
Old 06-15-2007, 11:57 AM   #8638
va_connoisseur's Avatar
Send a message via Yahoo to va_connoisseur
Default Rolling the car
I have finished the majority of the build, just need to put the motor clutch assembly in. Here's my question:
With the tires on, on a level surface, how far should the car roll it given a gentle push? Or better, should the car roll freely? My car seems 'tight'? but I went back through and nothing is binding that I can see. It's a MTX-4R if that helps. Thanks.
va_connoisseur is offline   Reply With Quote
Old 06-15-2007, 12:49 PM   #8639
Moderator
Artificial-I's Avatar
Trader Rating: 17 (100%+)
Send a message via AIM to Artificial-I
Check the brake disc. I found I had mine slightly set wrong and with everything off the car , belts and driveshafts. I was able to pinpoint its perfect rolling point while still keeping the pads close to the disc.
Artificial-I is offline   Reply With Quote
Old 06-16-2007, 01:30 PM   #8640
HarKonnenD's Avatar
Trader Rating: 23 (100%+)
Send a message via AIM to HarKonnenD
Hey guys I'm back. The move went well and I'm finally in my own apartment. Did I miss anything new for the MTX4? I hear there is a new RB R3 Rody coming out soon, a .12 motor, and wondering how will it stack up to the others on the market in price and power. My mugen hasn't been let out for a bit as there are more things important right now to be payed for, but when the time is right I'll slowly get few more option parts for my ride as well as try a new motor.
HarKonnenD is offline   Reply With Quote
MUGEN MBX5R/MUGEN MBX5T PROSPEC/TRAXXAS RACE REVO Jason Halvorson R/C Items: For Sale/Trade 14 01-12-2008 10:32 AM
USA's Most Wanted FOR SALE Mugen MBX5R,Losi 8 comp, and Mugen MBX5T Prospec Truggy nobike R/C Items: For Sale/Trade 69 04-28-2007 07:45 PM
Another MTX3 prospec w lots of parts and an optional Mugen X12 w Mugen pipe Scott Fisher R/C Items: For Sale/Trade 11 11-21-2005 05:45 PM
drake xxx nt and mugen mst-1+extras......Looking for a kanai 2 or maybe mugen buggy [email protected] R/C Items: For Sale/Trade 5 06-30-2003 09:31 PM
