Old 07-23-2007, 12:42 PM   #8746
Default belt tensioner plate mtx 4r
hello guys i'm new tho this forum but i just assembled my mtx4r but i came across a problem, when you have to assemble the belt tensioner plate you have to assemble it with the bearings facing the front of the car, but a few pages further i noticed that the plate is mirrored, so i took the plate off and i
mount it in the oposite direction, but now the holes arent counter sunk and the plate interferes with the engine mount. why does one page of the manual says A, and the other page of the same manual says B.
thank you in advanca for your reply,
dirk
oskamp is offline   Reply With Quote
Old 07-23-2007, 03:35 PM   #8747
va_connoisseur's Avatar
Send a message via Yahoo to va_connoisseur
dirk
Welcome to the Mugen family (once you enter this family, you can never leave. ). And the holes should be counter-sunk. Be sure to check the Mugen MTX-4R thread, nitro knowledgebase (http://www.nitrokb.com/mtx4/index.html) and I also have a build sequence on my site (www.teamkhaos.com).
And again, welcome to the Family
va_connoisseur is offline   Reply With Quote
Old 07-23-2007, 09:26 PM   #8748
Car Breaker's Avatar
dirk
the bearing should be in the front and if you see the counter sunk facing the pipe, then you assamble it right. The reason there are two assambly is because the old version MTX4 has the bearing closer to the back and block the engine, later they update the carbon plate to have the bearing in the front, hope that answer your question
Car Breaker is online now   Reply With Quote
Old 07-24-2007, 11:07 AM   #8749
blanks596's Avatar
Trader Rating: 14 (100%+)
does anyone go beyond the 6tooth gear split-like maybe 7 tooth split on either pinions or spurs?
Serpent/Desoto Racing
Max S
blanks596 is offline   Reply With Quote
Old 07-24-2007, 11:31 AM   #8750
YBSLOW's Avatar
I run 17/24 sometimes.
YBSLOW Racing
RC Target - Capricorn
HOTRACE Tyres, Tru Source, Fantom
POWER MASTER Fuel, 2mm Designs
Protoform Bodies, Avid Bearings, AMR Engines
YBSLOW is offline   Reply With Quote
Old 07-24-2007, 11:31 AM   #8751
lil-bump's Avatar
Trader Rating: 83 (100%+)
Originally Posted by Seisick View Post
FYI part H0774 IS THE SAME AS THE MSR SPRINGS, ITīS JUST THAT IN THE
US SOME PARTS ARE SOLD USING THE MSR CODE, SUCH AS THE ULTRA HARD SPRING, WORKS GREAT BY THE WAY
The MSR spring seems a little stiffer than the Mugen Ex hd spring. I get slippage if I go any further than .8mm spring tension. Someone mentioned that the MSR spring might be used with the MRX4/r.
lil-bump is offline   Reply With Quote
Old 07-24-2007, 02:04 PM   #8752
blanks596's Avatar
how does that work out for you? Have you stripped any gears or does the car bog down when shifting into second?
Max S
Old 07-24-2007, 02:07 PM   #8753
YBSLOW's Avatar
Works good if you have a lot of motor, too big of a split for most stock motors.
YBSLOW Racing
Old 07-25-2007, 09:51 AM   #8754
my new mtx4r (previously owned the 4 standard). someone kick me!, it says Kyosho on my mugen!
TomB is offline   Reply With Quote
Old 07-25-2007, 09:54 AM   #8755
HarKonnenD's Avatar
Trader Rating: 23 (100%+)
Send a message via AIM to HarKonnenD
Sweet ride TomB! Nice n clean.
HarKonnenD is offline   Reply With Quote
Old 07-25-2007, 08:42 PM   #8756
Osiris 75's Avatar
Trader Rating: 17 (100%+)
That Kyosho CRF may burst into flames on that mtx4!!
SPONSORS: AWESOMATIX USA / HOBBYWING USA / AVID CONCEPTS / R1 WURKS / POWERMASTER FUELS (VP RACING) / 2MM DESIGNS
RC TARGET/CAPRICORN USA / REFLEX RACING / ULTI TIRES
Chris Kemper
Osiris 75 is offline   Reply With Quote
Old 07-26-2007, 02:35 AM   #8757
JetMD's Avatar
It's not as bad as running a Mega in a Mugen though...
www.vorra.org
MINO Racing
JetMD is offline   Reply With Quote
Old 07-26-2007, 06:01 AM   #8758
itchy b's Avatar
If you really need it Rob and i will take you up on the request and give you 2 kicks for the price of one
Shame on you !!!!
itchy b is offline   Reply With Quote
Old 07-26-2007, 07:30 AM   #8759
Shame on you !!!!
Old 07-26-2007, 07:44 PM   #8760
wallyedmonds's Avatar
no it just dos not work (joking)
i run a sirio sometimes in my mugen.
wallyedmonds is offline   Reply With Quote
MUGEN MBX5R/MUGEN MBX5T PROSPEC/TRAXXAS RACE REVO Jason Halvorson R/C Items: For Sale/Trade 14 01-12-2008 10:32 AM
USA's Most Wanted FOR SALE Mugen MBX5R,Losi 8 comp, and Mugen MBX5T Prospec Truggy nobike R/C Items: For Sale/Trade 69 04-28-2007 07:45 PM
Another MTX3 prospec w lots of parts and an optional Mugen X12 w Mugen pipe Scott Fisher R/C Items: For Sale/Trade 11 11-21-2005 05:45 PM
drake xxx nt and mugen mst-1+extras......Looking for a kanai 2 or maybe mugen buggy [email protected] R/C Items: For Sale/Trade 5 06-30-2003 09:31 PM
