Old 02-06-2007, 12:57 AM   #7276
rmdhawaii's Avatar
Hey A.I. ~ You done building your car yet??
Nitro Knowledge Base: http://nitrokb.netne.net
My YouTube Channel: http://www.youtube.com/nitrokb -> Lots of on-road nitro & eletric action + some off-road as well
My Flickr Photostream: http://www.flickr.com/photos/nitrokb/
Kyosho V-ONE RRR WC (x2) \ XRAY T2'007 \ Also owned: XRAY NT1 & Mugen MTX-4
rmdhawaii is offline   Reply With Quote
Old 02-06-2007, 01:56 AM   #7277
rmdhawaii's Avatar
Ran my MTX-4 for the first time this weekend with a Lola body. Put in about 3 tanks during open practice, just to get a feel for the car. I was still breaking in the TZ that I put in it (running really rich), so I couldn't push it that hard yet. In the infield, the car was great. The steering is very responsive (I'm using a Futaba S9451). The car drives really well and I'm pretty happy with the setup, except that the car parks itself (rear end comes around about 90 degrees and stops) on corner entry, under hard under braking prior to taking a hair pin turn. If I brake sufficiently before taking the turn, it's just fine. I didn't have any time for setup tuning, but it's something I definitely need to nail down the next time I run the car. I got several suggestions from RoyU (Thanks again Roy ). Anybody else have some suggestions?
Thanks!
Tires: NitroShoes, 40 shore front and rear
Front Diff: 30K
Rear Diff: 10K
Sway bar/blade: 3Racing, blades flat
Setup: As specified in the kit setup sheet (downloaded from the Mugen Seiki Japan Web site)
Body: Protoform Lola, front wheels centered over front wheel well
Old 02-06-2007, 02:04 AM   #7278
jaykay's Avatar
Ok, the Lola Body makes everything easier.
Do you use 400 oil in the damper and the 1.3 hole in the front damper? When not, try it. Feels much better.
A nice tuning is to use 20.000 oil in the rear diff.
mixed the 10.000 and 30.000 mugen.
And put the O-ring in the diffs away.
jaykay is offline   Reply With Quote
Old 02-06-2007, 02:23 AM   #7279
rmdhawaii's Avatar
Thanks JayKay ~ The only part I didn't understand is about the o-rings. Kannst auf Deutsch sagen. Welche tiel meinst du?
Old 02-06-2007, 02:35 AM   #7280
jaykay's Avatar
Yes, i can say it in german. Itīs called: O-RING
Old 02-06-2007, 02:38 AM   #7281
itchy b's Avatar
do you mean that you take the o-rings out??
How does this effect it?
-Blitz-Rallyhawk-EX 1.5R-Xpress-P64 Tyrrell-Lotus79-Espirit VTA
EX1.5-SC10 4x4
itchy b is offline   Reply With Quote
Old 02-06-2007, 02:40 AM   #7282
rmdhawaii's Avatar
Thanks. There are two different types of o-rings in the diff (S3/S5) and I wasn't sure what you meant by "put away".
Old 02-06-2007, 02:45 AM   #7283
itchy b's Avatar
I'm still not sure what is meant by "Put o-rings away"
I must have missed something
EX1.5-SC10 4x4
Old 02-06-2007, 02:46 AM   #7284
chippy's Avatar
When removing the circled O rings it just like running a lighter diff oil
Just takes some of the friction off the smller sun gears.
They say it makes the diff action smoother but I could never tell the difference.
chippy is offline   Reply With Quote
Old 02-06-2007, 02:46 AM   #7285
jaykay's Avatar
Yes, take the o-rings out. After it, the diff works like a diff. With the o-ring you break the diff so when you use for example 30.000 diff oil, you havent the effect of 30.000 diff oil. It`s difficult for me to explain that. Just try it.
Old 02-06-2007, 02:47 AM   #7286
FREAKAH's Avatar
Originally Posted by Kanea6
i have a problem with my Mugen MTX-4 i have had the car for about 1yr now and it has started to strip gears. on a race meets i will probly strip about 4 spurs a race meet. The gears striping has cost me so many race wins. it has most recently cost me win in the c final in the summernats is wollongong Australia. could some please help me fix this problem.
The oneway bearing on the first gear spur may be locking-up momentarily not allowing it to freewheel when the second gear spur kicks in. Had that happen to me with my MTX-2. You will need to clean the oneway bearing out with motor spray really good and re-lube it ONLY with AE Stealth/ball diff grease or oneway specific grease. If that doesnt work then change the oneway bearing/gearholder.
Another thing you could check is the shaft that the oneway rides on. It may be developing ridges where the oneway's roller gets locked up on.
Hope this helps.
Second-Hand Racing
RACE WORLD HAWAII
Losi Type-R |Tamiya F104 PRO | Tamiya F103 | Mugen MTX-4R | AE FT GT2
FREAKAH is offline   Reply With Quote
Old 02-06-2007, 02:49 AM   #7287
rmdhawaii's Avatar
Thanks for clarifying that.
itchy_b: put away = don't use.
Old 02-06-2007, 02:54 AM   #7288
itchy b's Avatar
Ok,
that makes sense now
I will try that as i had a problem with oil leaking out of the out drives which i fixed by using the shock type O-rings which are a little thicker but solved the problem but i think that they are making the diff bind up slightly
Thanks for the tip as i think that this will cure the issue and make the diff much more consistent
EX1.5-SC10 4x4
Old 02-06-2007, 02:55 AM   #7289
FREAKAH's Avatar
Run a little less droop/down stop. You are getting too much weight transfer to the front and unloading the rear suspension.
Second-Hand Racing
RACE WORLD HAWAII
Old 02-06-2007, 02:55 AM   #7290
itchy b's Avatar
Which = Put them in the parts tray
EX1.5-SC10 4x4
MUGEN MBX5R/MUGEN MBX5T PROSPEC/TRAXXAS RACE REVO Jason Halvorson R/C Items: For Sale/Trade 14 01-12-2008 10:32 AM
USA's Most Wanted FOR SALE Mugen MBX5R,Losi 8 comp, and Mugen MBX5T Prospec Truggy nobike R/C Items: For Sale/Trade 69 04-28-2007 07:45 PM
Another MTX3 prospec w lots of parts and an optional Mugen X12 w Mugen pipe Scott Fisher R/C Items: For Sale/Trade 11 11-21-2005 05:45 PM
drake xxx nt and mugen mst-1+extras......Looking for a kanai 2 or maybe mugen buggy [email protected] R/C Items: For Sale/Trade 5 06-30-2003 09:31 PM
