Serpent 710
Old 07-16-2004 | 09:48 PM
  #13981
PSI Racing's Avatar
Default Re: Re: Re: Re: Re: Re: Re: Titanium screws
Originally posted by Pyramid
East..
Yeah East.
Are you saying that they make the Serpent shocks?
PSI Racing is offline
Old 07-16-2004 | 09:56 PM
  #13982
Pyramid's Avatar
Registered User
Default Re: Re: Re: Re: Re: Re: Re: Re: Titanium screws
Originally posted by PSI Racing
Yeah East.
I believe so, I think Central RC in Japan offering customer with S710E (stand for + east hop ups) which include the shock. Kind of Tmagic G4/V1RR shock with lack of bleeding process (the way I see it on magazine only).
Pyramid is offline
Old 07-16-2004 | 09:58 PM
  #13983
Pyramid's Avatar
Registered User
Default Re: Re: Re: Re: Re: Re: Re: Re: Re: Titanium screws
Now I remember why Mr. Giant runs Yokomo shocks on his. Does it mean it wont perform well using standard shock? (j/k)
Pyramid is offline
Old 07-16-2004 | 10:11 PM
  #13984
Pyramid's Avatar
Registered User
Just received some stuff,
SER 802831 orange set up wheels.. kind of look a bit pale (not bright enough).
SER 2158KHM... can not wait to try
Pyramid is offline
Old 07-16-2004 | 11:17 PM
  #13985
PSI Racing's Avatar
Oh that's what you meant.
Ok, I understand now.
Old 07-17-2004 | 03:02 AM
  #13986
redsand's Avatar
Default Re: Re: Track width
Originally posted by Sow&Steady
Think of it as your stance. With your feet together you're pretty wobbly, easily push to one side or another, in other words your weight shifts easier. On the contrary, if you spread your stance you are more stable in terms of side to side weight shift ... a lot harder for someone to push you to one side or the other.
Similarly, if your trackwidth is narrow, the weight of the car can shift more/easier from side to side. Conversely for wider track width.
Within limits and depending on your overall set-up ... narrower trackwidth in the front gives a little more steering because the when you initiate a corner you're starting to force the weight of the car to shift from side to side.
Careful with the track-width adjustment, if the front is set too narrow (approx. 2mm narrower than rears), the rear will start to swap end with the front at mid and corner exits. Very hard to drive with that setup.
redsand is offline
Old 07-17-2004 | 10:33 AM
  #13987
Schrijver99's Avatar
Looks very sweet.I've mine already, but no time/wheater to try it out.
Schrijver99 is offline
Old 07-18-2004 | 07:29 AM
  #13988
cyba888's Avatar
Pyramid,
When you use your drag brake does it wear out the brake pads fast, and how about in a 30 minute race?
cyba888 is offline
Old 07-18-2004 | 06:41 PM
  #13989
Default Re: Re: Re: Track width
With preseent JITC track condition, any 710 setup would still traction rolling.
We cure it with smaller rear trackwidth kind of (FR)200 / (RR)198.5 mm , perfect !!
GoldFinger is offline
Old 07-18-2004 | 07:23 PM
  #13990
InitialD's Avatar
Default Re: Re: Re: Titanium screws
Originally posted by KevinS
Are those hex, not philips?
They only come in hex. I have not seen any philips. I believe some philips screws at the bottom of the chassis can be replaced by M3 countersunk hex screws, especially around the battery casing area.
Do they come in packs of 8 or 10?
They usually come in 8 pieces.
Are they available in most lengths as used on the 710?
Yes they are. The longer ones come in pack of 6.
Are they available with different heads? (socket, button, flat)
Do they have M4 too?
I have not come across M4 titanium screws. I think that's because electric cars do not use them !
I have not seen socket type yet. Perhaps they do have. Countersunk and button head types are pretty common.
InitialD is offline
Old 07-18-2004 | 07:27 PM
  #13991
InitialD's Avatar
Default Re: Re: Re: Re: Track width
Have you tried higher front and rear roll centers? It apparently cures any type of traction rolling.
InitialD is offline
Old 07-18-2004 | 07:28 PM
  #13992
InitialD's Avatar
Don't get it wrong when using drag brakes... The drag brake is only suppose to "function" when you release the throttle and when the servo is in neutral position. Therefore at servo neutral position, the brake pads are rubbing the brake disc.
When you're on throttle, the brake pads are not suppose to rub against the brake pads. To check, roll the car (when the engine is off) on and off throttle. Off throttle, there should be a little drag. How much? That would depend on you. When you're on throttle, the car is suppose to roll free.
InitialD is offline
Old 07-18-2004 | 07:36 PM
  #13993
Marcos.J's Avatar
Super Moderator
Default Re: Re: Re: Re: Re: Track width
this is how i ran my serpent and even with 35 shore tires front and rear ,i still didnt get any traction roll!
Marcos.J is offline
Old 07-18-2004 | 07:47 PM
  #13994
HIgher, you meant just like book stock ?
Tracktion is extremely high, even CD3(evo version from LD3) is flipping.
Old 07-18-2004 | 08:16 PM
  #13995
InitialD's Avatar
Default Re: Re: Re: Re: Re: Re: Track width
Higher in the front (zero shims under the front upper arm) and higher rear roll center than stock like UBO/LB, UTI/LT, UTO/LT, UBI/LT and UBO/LT.
I believe when you put the zero shims under the front upper arms, you cannot mount the steering lingkage above the servo saver. You need to mount it like the manual.
InitialD is offline
