Serpent 710
I like the alfas on an MTX (very fast)but they are way to ass'y on a serpent and the 2.1 is a flying brick areodynamically. you just need to look at how the tires come off the track after a main to see why the mugen likes an alfa and a serpent does not. the Mugen smokes the rear tires down so it needs more front downforce. the serpent wears tires even so it wants a balanced body like a stratus. don't get me wrong the mazda was pretty good but with my current setup the stratus works better downforce is even at low and high speed.
ps D
the friend
would be one in the same.
ps D
the friend
Originally posted by InitialD
At 50 to 60% dual rate, I never had problems when the servo is too slow for me. I think that's because my hand is too slow for the servo. And the only thing I keep chanting to myself is Sow & Steady, Sow & Steady, Sow & Steady...
Aaahh good 'o young one, you are learning, you are learning, may the ring be with you...
Ummm, Sow&Steady mentioned that the tires need a little warming up before traction comes up. It could be due to that.
Besides, the best brand of tire does not have 45 shore rear tire.
Originally posted by Pyramid
Logically (to me is the fact), every brand of tires (at least the one that I`ve been using before) need to be warmed up just like your engines that would work best on its actual running/race temp
To be fair, one must not do this comparison of warm versus cold on the first run with a particular set of tyres because they have not "worn-in" to a particular setting. Do this on the second run. Of course, all this taking into account that equal age of foams, trued or not etc etc.
Ultimately this is only important for a 5-minute heat where you want to get to optimum grip as soon as possible. If you get enough warm up time before each heat then it does not matter either which brand you use ... you'll be able to get warmed up enough. Here at my club in the UK they run the race so efficiently that you're lucky to get 2 laps before each heat!
On the S710, it more on a not having true ackerman which is what we experimenting at this moment. Maynot be true, but we have to do what we believe.
Originally posted by Brightbluehaze
So I guess this is an advantage the mugen has? adjustable ackerman?
Not intended in any bad way to the 710 I love the car so far, I am able to set it up to carry more corner speed than the mugens which currently dominate our track but when I do the car becomes a little "twitchy" or "unpredictable" and is hard to be consistent with.
Having said that, Kawahara has just released a hop-up that allows the ackerman to be adjustable in-situ. Looking at it, I don't see why either Serpent or Kawahara can't do the same for the 710.
Originally posted by GoldFinger
For those reason, the Bridgestone powered car never made an awesome start and always slow on 1-2 laps after tire replacement.
And if we taking Montreal GP result as a example, 1 factor that could makes the Reds win is 2 pistop instead of 3
Very good analogy Goldfinger ... here's another one : in our RC world then its like some NTC3 boys NOT using their tank inserts resulting in less fuel stops than us using standard 75cc tank right?
Problem is hardly anyone need to refuel in a 5 minute heat though right?
Originally posted by Marcos.S710
hey BaxterC i'm finally a papa!!!baby boy 7lbs , 8 oz born this morning at 11:30 am, i will send you a pic tomorow when i have time to upload them!!!
Now go out and celebrate ... go buy another 710!
so what's going to happen to your FW05R
