Old 07-19-2004, 06:03 AM   #14041
markp27's Avatar
Send a message via ICQ to markp27
Default Re: Serpent 710 tips!
Originally posted by PER-OLA HARD
Hi!
I am new at this popular forum!
Some tips for the S-710.
I recomend to use the new alu levers for the front, as it stabilizes fhe front and makes front down-stop settings more accurate.
http://www.mytsn.com/products/desc.asp?prid=3356
On my car I have changed the rear ds-screws to a M4 for more stabile ds setting.
Regards,
Per-Ola
Per-Ola Welcome to the forum!
With the alu levers, is it simply due to the material being more stable?
With the rear droop screw, you used an M4 grub screw and drilled out the hole in the suspension arm?
Cheers, Mark.
markp27 is offline   Reply With Quote
Old 07-19-2004, 06:35 AM   #14042
Default Re: Re: Serpent 710 tips!
Cheers, Mark.
Hi Mark,
Thanks!
Front: yes the alu is more stabile so the small M3 insex screws works better then they touch the alu levers instead of the more flexible parts.
Rear: I drilled the holes to 3.3mm and replaced the standart M3 insex with a M4. Works nice I think!
Cheers!
/Per-Ola
PS. I will check in here now and then....
PER-OLA HARD is offline   Reply With Quote
Old 07-19-2004, 06:41 AM   #14043
JustRace's Avatar
Default Re: Re: Re: Serpent 710 tips!
Hi Mark,
Thanks!
Cheers!
/Per-Ola
Per-Ola....check in often
Could you please describe your current clutch setup..Shoe, spring, gap measurements. Thanks.
JustRace is offline   Reply With Quote
Old 07-19-2004, 06:51 AM   #14044
markp27's Avatar
Hi Mark,
Thanks!
Cheers!
/Per-Ola
Thanks Per-Ola, it's nice to have your input here
Now if only the weather would remain dry, so that I could try some of these things out
Cheers, Mark
Old 07-19-2004, 07:08 AM   #14045
PSI Racing's Avatar
I figured the aluminum Anti-roll bar levers would solve my problem with the bars not being securely tightened down.
Good to have a second opinion from a Serpent Team Driver.
Thanks.
PSI Racing is offline   Reply With Quote
Old 07-19-2004, 07:17 AM   #14046
Default Re: Re: Re: Re: Serpent 710 tips!
Sure....
My clutch setup is as follows: the yellow shoe (good!), standard fly weights, hard spring (grey from old centax-2), sping tension about 9.5mm (from shaft end to nut) and a clutch play of 0.45-50mm. Exellent!
/Per-Ola
Old 07-19-2004, 07:19 AM   #14047
PSI Racing's Avatar
PER-OLA HARD,
What other optional parts are you running in your car?
Old 07-19-2004, 09:13 AM   #14048
cyba888's Avatar
PER-OLA HARD
Welcome to the 710 forum! Glad to have another Factory Team Driver join us
2014 and 2015 BD7 Black Series, Yokomo RPX ESC- Yokomo 4.5T Motor
Yokomo B-MAX4 III Factory Team Kit, Muchmore ESC- LRP 6.5T Motor
Mugen MBX7R Eco- 2200 KV Motor
Futaba 4PX
cyba888 is offline   Reply With Quote
Old 07-19-2004, 09:34 AM   #14049
cyba888's Avatar
Pyramid
When you adjust the drag brake do you not only adjust it from the brake linkage screw but on your transmitter as well? Incase it starts to fade I was hoping you can adjust it using your tx? Is it possible without interfering with your carb settings?
Futaba 4PX
Old 07-19-2004, 09:46 AM   #14050
Sow&Steady's Avatar
Hi Mark,
Thanks!
Cheers!
/Per-Ola
Welcome Per-Ola!
You've sold the idea! I'm going to online to order the Al parts .... swoosh!!!
http://3hobby.net REVISITED V2 - Its on steroids!
https://www.facebook.com/ssteady
Sow&Steady is offline   Reply With Quote
Old 07-19-2004, 09:47 AM   #14051
Sow&Steady's Avatar
Cheers, Mark
that's why you should come over here now and not wait till Oct!
Old 07-19-2004, 10:12 AM   #14052
Originally posted by PSI Racing
PER-OLA HARD,
First, thanks everyone for the warm welcome, I think we can have a lot of fun here!
Optionals, actually I am no fan of optionals but as a team driver it is my duty to test things (a nice duty though.... hehe). I only use Serpent orginal option parts:
* The pro brake pads, works good almost no wear but the steel brake plate seems to wear instead (but cheaper to replace). I use the pro plate with holes.
* The middle axle alu support, good but not a must have....
* The radiotray and chassi alu support, really stiffens up the car and makes chassi bend less during a crash, a must have!
* The front alu levers for the anti-rollbar, a must have!
* The new rear rollbar, makes the rollbar action more accurate and no play, I recomend to try this one if traction is decent.
Another tips (I have used it the last weeks) is to use a longer inner pin in the rear driveshafts (11.7mm instead of 9.7mm) as this decreases the wear of the rear diff steelparts. These pins was used in the S-705 and Impact differentials and seems to work, make sure they are perfectly centered though.
Good luck!
/Per-Ola
Old 07-19-2004, 10:19 AM   #14053
PSI Racing's Avatar
Good luck!
/Per-Ola
Thanks PER-OLA HARD.
How much does your car weigh when it's race ready?
Do you have a picture of the new rear roll bar?
Old 07-19-2004, 10:20 AM   #14054
markp27's Avatar
Default Re: Re: Re: Re: Re: Serpent 710 tips!
I would if it weren't for all the cycle races and marathons
Old 07-19-2004, 10:21 AM   #14055
cyba888's Avatar
When will the front orange alu levers for the anti-rollbar be available?
Futaba 4PX
