Serpent 710
Old 02-14-2005 | 09:51 PM
  #20041
markp27's Avatar
Originally posted by InitialD
Well, going to a new track the first time and far away is always like that. Especially without a reliable wingman <cough, cough>. Stupid things you never expect happen will happen.
I guess you came back thinking you never played so much RC in your life eh?
You said it, D! I couldn't believe how intense it was. I should have really had a bit more race experience before going (the winternats was only my second race ever).
Our daily routine was, getting up at about 05:00 - breakfast by 06:00 - kick Fmolzer and Ammdrew's pit bitch out of bed by 06:15 - at the circuit by 07:00. From then on, work on cars, fix cars, marshal, drive car a couple of times, fix it again, give lots of money to Fast&Furious (great guy!!!), replace broken parts, clean car, pack it all up again......at about 18:30 drive back to motel - eat, drink and then sleep (5 to 6 hours).
Man that was hard work!
markp27 is offline
Old 02-14-2005 | 09:53 PM
  #20042
markp27's Avatar
Default Re: Re: Engine Problem source found.
Hey, that looks a lot like the engine on Uncle Crash's 710 ! <rub salt mode>
Not much longer, matey - I'm going to get one to match my new fuel tubing
markp27 is offline
Old 02-14-2005 | 09:57 PM
  #20043
markp27's Avatar
Spot the still intact rear-shock tower I came back with both originals!!!
What I broke: left upper and lower front arms, steering block, a couple of dog-bones and an outdrive. MS said the outdrives are a bit weak for the solid and new ones will be out soon.
I found the 3racing carbon fibre front bumper to be quite weak, too - I will replace it with the new standard upper bumper plate.
The new wheels were superb - even after taking the left-hand side off my car (due to radio glitch just before my qualifying session *EEK*) the wheels stayed very true.
markp27 is offline
  #20044
InitialD's Avatar
Default Re: Re: Re: Engine Problem source found.
You have seen the light? The Frenchies are not going to like you.
InitialD is offline
Old 02-14-2005 | 10:00 PM
  #20045
InitialD's Avatar
However, normally the thicker sway bars would be used, too.
You mean nobody used the thicker rear sway bar?
I was actually thinking of suggesting to put original 705 steering blocks at that time when Onkel Sow asked me for suggestions on how to cut down traction roll since the last time I remembered communicating with Rene... But that would mean bigger 10x19x5 bearings which would make it slightly heavier... Anybody did that?
InitialD is offline
Old 02-14-2005 | 10:04 PM
  #20046
InitialD's Avatar
You should have redeemed those shock towers with brand new complete 710 kits from MS and Rene.
What a lot of people are doing is use the bumper and upper plate meant for the Lola bodies. Better and more sturdy. Less prone to damage on impact.
Don't we already know that...
InitialD is offline
Old 02-14-2005 | 10:09 PM
  #20047
markp27's Avatar
I think everyone started out with the thicker rear, but there was so much steering that the old sway bar had to be used. Even with my "little" steering setup, I had my controller set to 55% - normally I would set it to 70%.
I'm not aware of anyone using the old steering blocks - but it would be an interesting idea for next year.
markp27 is offline
Old 02-14-2005 | 10:12 PM
  #20048
InitialD's Avatar
If I recall, it was Rene's idea actually...
InitialD is offline
Old 02-15-2005 | 06:31 PM
  #20049
TitaniumR's Avatar
We run on low traction tracks too. The general consensus is the 2.5 mm rear sway bar and the new servo saver gives better cornering speed. Tighter turning radius too.
What problems are you having with the 2.5 mm rear bar? The rear spinning when coming out of the corner? Try a harder front sway bar setting with the 2.5 mm rear sway bar...
2.5mm makes rear very loose for me, on power sends tail everywhere... maybe then my rear toe was only 1.5deg causing it. Now it's 3deg.
Then I'll prob install the new servo saver tonight and try the 2.5mm again.
Thanks.
TitaniumR is offline
Old 02-15-2005 | 08:25 PM
  #20050
InitialD's Avatar
Just a quick note... How are you installing the 2.5 mm rear sway bar? How many mm from the end of the sway bar?
If you set it at 0 mm (the end of the sway bar), make sure the rear sway bar assembly does not touch and bind the rear upper arm upon suspension compression...
InitialD is offline
Old 02-15-2005 | 08:54 PM
  #20051
TitaniumR's Avatar
About 3mm such that it misses the upper arm. MrChan also got me a EAST racing blade type that I'll try out first. The whole unit is really heavy.
Old 02-16-2005 | 05:43 AM
  #20052
jag's Avatar
jag
Scotty was the only one in the A main using the 2.5mm sway bar. That could be because his car is short... I think he told me 3mm short. That's just my guess.
jag is offline
Old 02-16-2005 | 06:51 AM
  #20053
InitialD's Avatar
Cool. Thanks for the info. Yes, I think all this while he used the shorter wheelbase trick. I think it was Art Carbonnel who sets the car like that.
InitialD is offline
Old 02-16-2005 | 07:07 AM
  #20054
jag's Avatar
jag
You are correct. Art is Scotty's mechanic... at least that is how appears to this outsider. Scotty's car is trick. He is also running an early version of the Mega ZX12... maybe a WC version
jag is offline
Old 02-16-2005 | 07:24 AM
  #20055
InitialD's Avatar
What do you mean by a "early version" of the ZX12?
InitialD is offline
