Serpent 710
Originally posted by InitialD
Good one.
Good one.
it was a sign!!!
Hey, how did the break in of the PRECIOUS go?
Today's weather seems ok, but I'm training with my racing partner
and tomorrow is a day with the GFs
Tuesday I should be free to do what I want and then on Wed I travel to Switzerland for my bike tour/mountain training until a week come the following Sunday
The engine seems nice, though - it starts easy and even though everything is very rich, I can, with a little care, pull away without the engine cutting out - I'm getting the impression of bigger problems with the 2106 now
Originally posted by PMR
Do you guys know of any website that could aid us design our asphalt track. Dimension is 44x21 meters. Your help will be greatly appreciated.
You can even drive on it afterwards
Thanks guys. One guy at my LHS said that maybe the grease I'm using in the diff is to slippery wich is making the diff balls slide on the plates and not turn? He said maybe thats why I have to have the diff so tight so that the pulley won't turn.
I'm using a Synthetic automotive grease. I'm going to order the Super Grease this week and will wait to rebuild my diffs and Centax thrust till I get it!
Hi,
I took the oneway diff out today and put the ball diff in to try it. I lost both dogbones whilst on the track, do i need to run a narrower front track or put some foam on either end of the dogbones.
Originally posted by B4
Hi,
Hi,
This is common with the diff. Use foam or fuel tubing. I use foam with good results. All my friends use tubing.
Originally posted by markp27
Man were you every lucky
How did it go yesterday?
But today went %*$#$*&#%^#&.
Started 6th in 1/4 Final. We 20min. finals and 45 Main Final. After 17min at 5th place someone hit my car from behind and my rear right demperrod broke
Originally posted by Schrijver99
Yesterday went good for me - placed 26 of 42.
a very good performance. Any news on the other guys?
Cheers,
Mark.
Originally posted by SupermaxxRich
So how exactly are you guys quoting the way you do? I've tried hitting the quote button but it never turns out like the way you guys do it with the box around your quote????
Each section of quoted text starts wth two sets of squared brackets, the first one containing the word QUOTE and then second on the letter B.
And at the end of the quoted text comes two more sets of squared brackets this time the first one contains /B and the second one /QUOTE
When you hit quote and you wish to write some text in the middle of a quoted section, simply go to the position within the text where you wish to write and then type the two sets of squared brackets with /B in the first one and /QUOTE in the second.
Then write your text and when you've finished, remember to put another set of squared brackets containing QUOTE and B before the quoted text continues.
If this still isn't clear - simply hit the quote button on one of the postings where this is done and you'll see how it was achieved.
Cheers, Mark.
