Serpent 710
Originally posted by markp27
Bearings front and back are ceramic
and the crankshaft is at least partially coated - I can't remember now if it was fully coated or not.
Polish my balls
and the crankshaft is at least partially coated - I can't remember now if it was fully coated or not.Polish my balls
Also we have the old sleeve from old batch
, this is the new one:
Originally posted by Schrijver99
Only the big-end side of the shaft is coated, not the shaft/inlet side
Old sleave
I'll have to buy another JP, then
Look at the pics here. See any similarities with the new NSR sleeve?
What's the best way to remove the conrod from the crankshaft - It takes me ages to get the conrod removed as it keeps getting stuck on the last bit of the crankshaft's conrod pin
Any tips would be appreciated
Originally posted by InitialD
Not if you have the "Moteur rode" sticker version on the box.
That one is broken in in the factory already.
I was looking high-and-low for this, but it looks like mine needs running in.
Initial D,
I'm not sure if you seen my post a couple pages back, but here it is again.
D,
I didn't compare the KO 2343 and 2344 for myself.
I asked Josh Cyrul about it, and this is what he said.
PSI Racing - I prefer the higher torque in my gas cars. I used to always choose the speed for the steering but after I tested a few different servos I then opted for the high torque as I liked the feel - less twitchy off center but it did seem to have more steering in the higher speed (higher load) corners. I'm not sure what Ralph uses...
D,
If it still stuck.. good, dont remove it. Mostly a "new" engine is difficult to pull out the engine. Should be easier after completely broken in.
If still hard to do, (if it was my engine) I prefer to let it there.
Just take up the sleeve and spray the piston and crankshaft with CRC(contact cleaner) or Permatex(carb/choke cleaner).
Do not use your kungfu for this part.
