Old 02-16-2004, 02:20 AM   #4441
cyba888's Avatar
Is it necessary to use a fuel filter, do think its necessary to have one?
2014 and 2015 BD7 Black Series, Yokomo RPX ESC- Yokomo 4.5T Motor
Yokomo B-MAX4 III Factory Team Kit, Muchmore ESC- LRP 6.5T Motor
Mugen MBX7R Eco- 2200 KV Motor
Futaba 4PX
cyba888 is offline   Reply With Quote
Old 02-16-2004, 03:02 AM   #4442
Sow&Steady's Avatar
Default Re: Re: Re: Re: Front Roll Centre Adjustment!
Originally posted by InitialD
Try 37 shore or even 35. If your track is a little more technical, you can soften the shocks.
Yesterday, I tried switching to the stock Serpent 30 wt oil, composite shock body, yellow springs, 5 holes front and rear and stock shock mountings. 37 shore front with 40 shore rear. Tires at 63 mm front and rear.. Rear sway bar 3 mm. No front sway bar connected. Caster at 5 mm behind the front upper arm. Rear diff is medium light. Camber -2 front (left and right) and -4 rear left and -3.5 right. Front toe out -1 and rear +2. Rear trackwidth 197 mm and 200 mm front. Ride height is 5 mm front and 7 mm rear. Droop is 1 front and if I'm not mistaken +8 in the rear. DRS arm is in the above setting. Front rollcenter with 4 mm spacers under the front upper arm (lowest roll center). Rear rollcenter is with the lower pin at stock bottom position with the upper rear arm at the shortest upper arm position (UBO/LB).
Oh yes, the car felt lighter with the composite shock bodies !
And that is all you have to say after giving us all those details on your set-up??? Man!
Sow&Steady is offline   Reply With Quote
Old 02-16-2004, 03:13 AM   #4443
InitialD's Avatar
Default Re: Re: Re: Re: Re: Front Roll Centre Adjustment!
Ok, Ok... Besides the mentioned decrease in weight due to the aluminum shock body , the car was fabulous ! On a short small technical track that is.
Old 02-16-2004, 03:17 AM   #4444
InitialD's Avatar
I'm actually not sure of this one right now. There are conflicting reports that the tank that we're currently having on the 710 is the same old tank and inner filter from the 705. Therefore we have to use an external filter.
The 710 is suppose to come with a "different" tank which has inserts inside the tank to compensate for fuel increase / decrease during tech inspection in big competition races. Externally, the 710 tank and the 705 tank looks exactly the same. I don't think any of our 710 cars have that new tank. If you have that tank, I do not think the external fuel filter is required. That was what I understood from the mytsn forum.
Old 02-16-2004, 03:22 AM   #4445
cyba888's Avatar
How do you know if you have the new tank?
Futaba 4PX
Old 02-16-2004, 03:40 AM   #4446
Schrijver99's Avatar
If you open the feulcap and you can see a hole for a screw at the bottom you have the new one (with brasscollor filter inside).
If you can't see it, you have the old one (705 tank with old white 705 "filter")
I also have the old one and have to use a fuelfilter
Schrijver99 is offline   Reply With Quote
Old 02-16-2004, 05:07 AM   #4447
cyba888's Avatar
I think I got the old tank Anyone got a pic of a new or old tank?
Futaba 4PX
Old 02-16-2004, 05:21 AM   #4448
hi all,
the old 705/835 tank have a plastic fuel filter inside, the new one
a metall filter (sinter) inside.
4racer is offline   Reply With Quote
Old 02-16-2004, 05:23 AM   #4449
cyba888's Avatar
Is this what your talking about? The only thing I see is a hole with the fuel tube going into it.
Futaba 4PX
Old 02-16-2004, 05:25 AM   #4450
This is the old filter. Sorry but i can't show you the new tank.
Old 02-16-2004, 05:29 AM   #4451
Whoops posting the same pics.
You also have the old 705 tank.
There's a thread on MYtsn about the old/new tanks but's in german.
Old 02-16-2004, 05:30 AM   #4452
cyba888's Avatar
Yep I got the old one too
Futaba 4PX
Old 02-16-2004, 06:05 AM   #4453
redsand's Avatar
Send a message via Yahoo to redsand
Default Fuel Filter Route
How do you guys route the fuel filter ? Mine seems to rub the carbie linkage and not sure if there's any other way to route it.
redsand is offline   Reply With Quote
Old 02-16-2004, 06:08 AM   #4454
Default Re: Fuel Filter Route
See pic.
Old 02-16-2004, 07:01 AM   #4455
markp27's Avatar
Send a message via ICQ to markp27
It's actually not worth reading the German thread, as it degenerated into people abusing each other about pretty petty opinions.
markp27 is offline   Reply With Quote
