Serpent 710
Old 11-19-2003 | 12:29 AM
  #1006
InitialD's Avatar
Default Re: Re: Re: Fuel Tank??
Originally posted by Schrijver99
Same tank: YES, Same filter: No its a new fuel filter!!!!!!
But do you still need to use an external filter with the 710? If yes, then it's still the same filter as far as the drivers are concern !
InitialD is offline
Old 11-19-2003 | 12:31 AM
  #1007
InitialD's Avatar
Default Re: Re: Re: Re: Re: Fuel Tank??
No, there's a new fuel filter inside the tank
Yes, as with all tanks in gas powered cars, you have an internal filter in the tank.
InitialD is offline
Old 11-19-2003 | 12:34 AM
  #1008
InitialD's Avatar
Do you use this car with a touring body or a lola body, cause of the modded floating bodymount rear (I see normal body posts added)
Yes, I use the lola mount and mod it to have longer body post screwed on it so that I could use TC bodies.
With the lola mount you are not able to use the 7 mm rollcenter spacers on the upper rear knuckles but you're able to slit in a 2.5 mm spacer which I find is OK for my setup.
InitialD is offline
Old 11-19-2003 | 12:38 AM
  #1009
InitialD's Avatar
Originally posted by Pyramid
I still cannot get mine the way your built it as without the diff plate (inside the diff adjuster) the balls will all fall out. It is just because the diff adjuster is not shaped to hold the balls, in fact, it is shaped to hold the diff plate
I have yet to use my external diff adjuster. I use the FPS diff pulley which requires bigger balls from the 15 x 28 x 9 (part number 1374). These balls are way bigger (4.5 mm in diameter) than the stock ball diff ones. That and the excellent tip on how to build a perfect diff so that you can adjust it externally and not make it slip. Works perfectly for me !
InitialD is offline
Old 11-19-2003 | 12:45 AM
  #1010
InitialD's Avatar
Oh yes I forgot to add that the diff stays very smooth after many runs unlike the stock one where it becomes gritty sandy feeling when you turn it. I think it's because the lip on the FPS diff pulley covers and seals the diff balls quite good.
InitialD is offline
Old 11-19-2003 | 01:10 AM
  #1011
Schrijver99's Avatar
Default Re: Re: Re: Re: Re: Re: Fuel Tank??
you're right but not with the 705 wich has a fuel-pickup and not a fuel-filter inside (bad product) the new 710 has a new filter in side the tank so you don't need an external filter
I'm also running the FPS and the new diffadjuster, i use the FPS for long runs and as a backup when i don't feel right with the diffadjuster. I think the FPS is better to adjust in very little steps, but its also very heavy for the car
Schrijver99 is offline
Old 11-19-2003 | 01:20 AM
  #1012
InitialD's Avatar
Default Re: Re: Re: Re: Re: Re: Re: Fuel Tank??
Well, I was actually not referring to running the FPS diff itself. I was referring to running the ordinary ball diff BUT using the FPS pulley instead of the normal pulley meant for the ball diff...
InitialD is offline
Old 11-19-2003 | 01:25 AM
  #1013
InitialD's Avatar
Default Re: Re: Re: Re: Re: Re: Re: Re: Fuel Tank??
See the difference?
InitialD is offline
Old 11-19-2003 | 02:11 AM
  #1014
See the difference?
Yes i see. But it's you need more time to adjust the diff that with the FPS or Diffadjuster.
Do i see that you have your modded Ball-Diff in your Impulse and an old Gear-Diff in your 705 . Or is it that my eyes are getting old
I hope that with the new 710 the problems with diff are gone
Old 11-19-2003 | 02:19 AM
  #1015
InitialD's Avatar
Not really. I find no difference in the time to adjust the modded ball diff than with the FPS. Put in the pin in the hole to lock the diff and turn the right rear wheel clockwise (to tighten) or anticlockwise (to loosen). That's it.
Your eyes are getting old ! The Impulse PRO initially had the FPS but now it's in the 705 (the one with the mod rear floating mount). So the lighter modded ball diff is now in the Impulse PRO (soon to be converted to another 705 ). The rear gear diff? In the tool box.
There's actually no problems with the ball diff in my opinion. You just need to install it correctly and it works consistant from time to time.
InitialD is offline
Old 11-19-2003 | 02:31 AM
  #1016
S710_Nut's Avatar
Default Weight!
Guys,
Getting back to the weight discussion, I think it came in at 1675g, i know it was with body, radio, but no fuel... What about engine and tune pipe? Look forward to hearing from you soon
SN
S710_Nut is offline
Old 11-19-2003 | 02:32 AM
  #1017
S710_Nut's Avatar
Whats this about diff problems that serpent have? I was hoping i had left all that behind when i sold my NTC3?
SN
S710_Nut is offline
Old 11-19-2003 | 02:37 AM
  #1018
Don't you use the lock-screw
http://www.rctech.net/forum/attachme...&postid=595935
What is it that i see in the lower right corner
It doesn't look like an FPS or ball diff
Old 11-19-2003 | 02:39 AM
  #1019
SN
Sorry but it's problems with the (old) 705, the 710 has a new improved Diffadjuster
Old 11-19-2003 | 02:41 AM
  #1020
InitialD's Avatar
There's actually no problems with the 705 rear diffs. The only thing was that like the NTC3, you could not adjust the ball diff on the fly. You need to loosen the grub screw which is difficult to access. Else, if you try to loosen the rear diff externally without loosening the grub screw, you'll end up with the rear end loosing drive.
There's a simple solution to that which is to use loctite. There was some instructions compiled with regards to building a bullet proof ball diff posted on the 705 thread. One that would make the ball diff able to adjust externally even without the use of the external diff adjuster hop up.
I further went ahead to use the FPS pulley on the normal ball diff because that one protects and closes the diff balls better. Also, not that it's a serious problem but it takes away the wobble found when you install the stock pulley. And yes, lastly the FPS diff pulley is wider and does not make the rear belt slip like what some people have complained...
InitialD is offline
