Serpent 710
#7891
Originally posted by AMGRacer
I think Serpent USA has screwed up. That motor is OLD I remember a few kicking around like 3 years ago....... BTW that motor also sucks hard, at least the original items did, the piston/sleeve fit was TERRIBLE and it took around 2 litres to run the motor in. The porting was not optimised in the crank and the bottom end was shocking.
#7892
Originally posted by GoldFinger
Yes.. correct. Im still remember that 2103.
#7893
#7894
How many volts on my receiver pack do I need in order to run safely? I would like to check once in awhile but want to make sure whats a safe voltage? I usually just plug it into my charger and it reads how many volts it has. This reading should be accurate from the charger correct? Can someone give me some numbers?
#7896
Originally posted by InitialD
Like AMGRacer mentioned, NiMH does not need discharging. But some purist would insist on discharging theirs anyways.
I would actually recommend discharging the RX and TX batteries after your weekend runs - although it isn't as important as in electric touring cars.
For my EVO III I have GP3300 battery packs - when I discharge them with an NiMH discharger, I can squeeze 4 Amps into them, when I don't discharge them and then recharge, then I only get 2.9 Amps - also the overall power output is lower and the car isn't so responsive.
Obviously the case is different for the AAA packs in the 710 - you wouldn't notice any difference in response if the batteries weren't discharged and maybe the run time is not hugely different, but good battery maintenance does help to allow the pack to "live" longer.
A couple of things to observe with NiMH is never leave them for long periods with a full charge and never discharge them completely (i.e. to zero volts; NiMH discharges cut-off at about 0.9 V) - apart from that you can pretty much do what you want.
Cheers, Mark.
#7897
Originally posted by jfc_tech
We Sabahan, if it no changes...4 persons.
#7898
Originally posted by MrChan
Ok ...It's the time to say "hello " to each other as face to face !!
#7899
Spoke like someone who know his stuff.
#7900
Woow ! If I did not see your nick, I would have thought Barry Baker or Josh Cyrul answering that !
Did I write that!
Must have been a Jedi mind trick, I think
#7901
their faces u can check in my website, under top drivers.
#7902
One NiMH cell is 1.2 V. 5 cells would be 6V. Some times after charging, it even touches to 7V.
#7903
Where is the top driver link ? Better give me quick before night time !!
Click the top drivers...KK / labuan drivers
#7904
#7905
I believe most receivers have a threshold voltage of about 4.8 V before the fail safe kicks in (if you have one).
