Serpent 710
Old 09-09-2004 | 04:09 AM
  #15391
Sow&Steady's Avatar
Originally posted by Juan C Munoz
Thank you !
I'll keep those thing in mind..
No problems ... the car is very good, very fast. If you get beaten its your fault ...
Sow&Steady is offline
Old 09-09-2004 | 04:17 AM
  #15392
Default Li-poly
Hi,
Lithium Polymer bateries, uses on all current mobile phone on the market today
The Li-poly batteries availeble now are not a good option for use in now-days racingcars.
The electronics used need more power as a mobile phone.
Besides, it's very difficult to charge them with the current chargers.
If you're looking for more power, and longer and more ennergy I would go for NiMH cells for use in camera's and photocamera's.
They are the same size as the regular AA batteries, but have more ennergy. Their mostly around 2100 or 2300 Mah, but the voltage is lower, 1.2 You can build your own packs, you'll only need small lips (orion makes them) and an extremely hot soldering iron ( 50W or up) so you can get the job done very quick, so you don't overheat the cells.
There are to negative sids about these cells.
They are more heavy then the regular ones used.
They are expensive.
Thomas
840918001 is offline
Old 09-09-2004 | 04:25 AM
  #15393
Sow&Steady's Avatar
Default Re: Li-poly
Originally posted by 840918001
Hi,
They are expensive.
Thomas
Thomas thanks for the info.
Sounds like I better just stick to my current ones ... Sanyo 800 mAh AAA cells. I've used these continously in 1 hour mains without problems.
Old 09-09-2004 | 04:32 AM
  #15394
Pyramid's Avatar
Registered User
Originally posted by Sow&Steady
Oh, forgot to mention to you that the pop-up pictures of the underside of the deck (in BlackBook) is not displaying.
hmmm, they seems fine from here.. but thanks for the info
Pyramid is offline
  #15395
markp27's Avatar
Hey D, whatever OS Mark is using today, its certainly showing its fangs and arguing with the Master!
Uh oh!!! hadn't thought of it like that
markp27 is offline
Old 09-09-2004 | 04:33 AM
  #15396
markp27's Avatar
... subject to available grip, different throttle input (Analog Driving is my term) imparts different centrifugal and centripetal forces which varies weight transfer that proportinally relates to bite side bite/grip of your tyres?
D, I think Sow has had a stroke or something - he's talking strange!
markp27 is offline
Old 09-09-2004 | 04:34 AM
  #15397
markp27's Avatar
Good point ... which was why NiMo destroyed his 2-speed one-way bearing in his FW05 within one lap of removing his restrictor!
Forgot about the restricter
markp27 is offline
  #15398
markp27's Avatar
It has nothing to do with end-play or dirty bearings Mark. Its the JP, you really should pass that engine to me so I can check it and ensure that your ceramic bearings never gets harm again.
You know already the Jedi Mind tricks don't work with me
markp27 is offline
Old 09-09-2004 | 04:35 AM
  #15399
markp27's Avatar
Default Re: Re: Re: Re: Re parts
Originally posted by Schrijver99
And what about the one-piece engine mount!
I've had it in my hands last friday, but there was only one and i wasn't the first, so i have to wait for friday to get mine. Forgot the part nr but the price is cheaper than the X-bracket
More metal to buy
markp27 is offline
Old 09-09-2004 | 04:36 AM
  #15400
Pyramid's Avatar
Registered User
I see what you meant... they are ok now.. thanks
Pyramid is offline
Old 09-09-2004 | 04:38 AM
  #15401
Sow&Steady's Avatar
No, the ones showing underneath the top deck ... servos and PT.
Yes ... I see that you fixed it.
Old 09-09-2004 | 04:40 AM
  #15402
Sow&Steady's Avatar
Yeap ... two-stroke-starved. what can you expect from 2 year old engines?
Old 09-09-2004 | 04:41 AM
  #15403
Sow&Steady's Avatar
Oh no! I'm doomed! I knew I should keep my trap shut some times.
Old 09-09-2004 | 04:43 AM
  #15404
Sow&Steady's Avatar
Oh by the way ... I prefer my PT on the top deck because its power light glows ORANGE when powered up!
That's what one has to do when one loses the battle of who's got the most orange metal bits.
Old 09-09-2004 | 04:44 AM
  #15405
markp27's Avatar
Thanks for the tip, Sow
BTW YGM
markp27 is offline
