Old 09-09-2004, 04:19 AM   #15376
Sow&Steady's Avatar
Originally posted by InitialD
Onkel Sow, NiCD is old tech. Go for Li-Poly at least.
Li-Poly? What is that? Where can I get more info?
If the discharge vs time curve looks good then I'll like to get some to plug into my brain ... the part which controls driving skills!
Trying to play Jedi mind tricks on Mark is it?
Driving faster he is. In the force on his right there is disturbance.
I need to meditate more before October.
http://3hobby.net REVISITED V2 - Its on steroids!
https://www.facebook.com/ssteady
Sow&Steady is offline   Reply With Quote
Old 09-09-2004, 04:20 AM   #15377
Sow&Steady's Avatar
Where have you been all this while Onkel Sow? See what work he does and what OS he runs at home and you know he's serious shit.
Yeah but anyone who dares to run Windows has got to be serious ... I mean in serious shit!
Old 09-09-2004, 04:22 AM   #15378
Sow&Steady's Avatar
Correct. But I think that happens only on an ideal situations where you do not get any slipping in the inside wheel which is impossible because the outside wheel gets more pressure than inside wheel due to the turning.
Unless you're in a banked sweeper like the one at AMCC ...
Old 09-09-2004, 04:23 AM   #15379
Sow&Steady's Avatar
Originally posted by markp27
Yep, you are right! the only remark I would make is that this only happens when power outweighs available grip and for me, I gently accelerate out of a corner, meaning at least during the first part of the corner exit, the inside wheel won't/shouldn't loose traction.
Hey D, whatever OS Mark is using today, its certainly showing its fangs and arguing with the Master!
Old 09-09-2004, 04:25 AM   #15380
Sow&Steady's Avatar
Yep, it is pretty much dynamic, so the theory says one thing, but the practice may be completely different.
I agree with you there ... in practice I just nail the throttle! I call it "Binary Driving" ... either brake or WOT!
Old 09-09-2004, 04:28 AM   #15381
Sow&Steady's Avatar
Difference in steering input creates different inner and outer tire circle radius and therefore creates different wheel spin rate on outer and inner wheels.
... subject to available grip, different throttle input (Analog Driving is my term) imparts different centrifugal and centripetal forces which varies weight transfer that proportinally relates to bite side bite/grip of your tyres?
Old 09-09-2004, 04:29 AM   #15382
Sow&Steady's Avatar
With a JP FX engine, is that ever possible?
Good point ... which was why NiMo destroyed his 2-speed one-way bearing in his FW05 within one lap of removing his restrictor!
Old 09-09-2004, 04:34 AM   #15383
Sow&Steady's Avatar
Yep, maybe the end-play is a little too tight. I've gone through about 6 bearings so far
It has nothing to do with end-play or dirty bearings Mark. Its the JP, you really should pass that engine to me so I can check it and ensure that your ceramic bearings never gets harm again.
Old 09-09-2004, 04:35 AM   #15384
Sow&Steady's Avatar
I'm really behind when it comes to new stuff on the car. I don't even have the metal bits in the car.
Behind? Its the age thing again...
At least you're at full steam here in the forum once more.
Old 09-09-2004, 04:46 AM   #15385
Schrijver99's Avatar
Default Re: Re: Re: Re parts
Man you beat me to it - was just about to answer
And what about the one-piece engine mount!
I've had it in my hands last friday, but there was only one and i wasn't the first, so i have to wait for friday to get mine. Forgot the part nr but the price is cheaper than the X-bracket
Schrijver99 is offline   Reply With Quote
Old 09-09-2004, 04:48 AM   #15386
Juan C Munoz's Avatar
Hey What's up guys...
I bought a Serpent 710 a couple of weeks ago. But there is only one problem... Where do I put the switch ?? I saw a fellow racer, that had a carbon fiber switch mount, but he told me that it was from the HPI Pro 2. I went into the HPI site, and look through the parts and couldn't find it. What do you recommend me ?
Juan C Munoz is offline   Reply With Quote
Old 09-09-2004, 05:02 AM   #15387
Pyramid's Avatar
Lithium Polymer bateries, uses on all current mobile phone on the market today
Pyramid is offline   Reply With Quote
Old 09-09-2004, 05:02 AM   #15388
Sow&Steady's Avatar
If you intend to race I recommend that you do not use a switch. They're not worth the trouble unless you use one of those electronic switches.
If you insist on using a switch then you can use double sided tape and tape the switch either to the steering servo or on the top deck just above the steering column.
the best solution of all is to read the article written by our Serpent friend Glenn Cauley here.
Another excellent resource is here as well as the 710 GAQ you can dowload from MarkP27's signature.
The best of all is my website but because its so good its offline!
Old 09-09-2004, 05:06 AM   #15389
Sow&Steady's Avatar
Are they smaller and lighter for the same voltage and capacity (mAh)?
Oh, forgot to mention to you that the pop-up pictures of the underside of the deck (in BlackBook) is not displaying.
Old 09-09-2004, 05:07 AM   #15390
Thank you !
I'll keep those thing in mind..
