Serpent 710
Old 09-23-2004 | 09:21 PM
  #16126
Sow&Steady's Avatar
Originally posted by B4
I have driven the 710 on fast open tracks and also some slow one's with pvc piping to mark the track out, also raced at one track with concrete about 100mm high down one side of the main straight. I hit this once and the car did a wheel stand and still no damage to the CV.
Well, I guess you must be one of the lucky ones who had a good pair/set.
Sow&Steady is offline
Old 09-23-2004 | 09:54 PM
  #16127
markp27's Avatar
Default Re: Re: Rear anti-roll bar
Originally posted by KevinS
You should center that ARB, it seems to be to the right too much. If the levers are not in the same angle, the ARB will get tweaked when the suspension is compressed.
Hi Kevin, yeah, noticed that with the ARB, too The new unpainted version (ahem) is now central
You car is even cleaner than mine! Why? WHY? WHYYY?
I wanted to be best at something...
It's my new improved photoshop dirt filter - D has the old version which has a lot of bugs in it The new one does a better job on blues and oranges
markp27 is offline
Old 09-23-2004 | 10:00 PM
  #16128
markp27's Avatar
Default Re: New Servo Lever
Originally posted by GoldFinger
Anybody ever try that?
The measurement is 3mm deeper(or longer) and about 1.5mm narrower.
In theory it should make our weapon unbeatable in fast sweeper but a bit suffer in very low speed corner.
What do you think ?
I heard this from a good friend of mine, one who isn't too old or the holder of the Ring
this leads to more corner speed. And, becuase the servosaver is longer the curve radius is a little smaller. But when there is very little grip the turn in is a little poorer
markp27 is offline
Old 09-23-2004 | 10:38 PM
  #16129
Suspended
Default Re: Re: set up wheels
Originally posted by Sow&Steady
Choco, not a must have, more of a nice to have.
thanks
SERPENTFREAK69 is offline
Old 09-24-2004 | 02:42 AM
  #16130
InitialD's Avatar
Default Re: Rear anti-roll bar
Originally posted by markp27
Here's a pic before I started polishing the roll bar
Showing off latest version of "eradicate and terminate dirt" Photoshop filter at work on Friday?
InitialD is offline
Old 09-24-2004 | 02:43 AM
  #16131
InitialD's Avatar
Default Re: Re: New Servo Lever
That would be <cough, cough>... meee isn't it?
InitialD is offline
Old 09-24-2004 | 02:44 AM
  #16132
InitialD's Avatar
Yeah but Mark and I are the REAL 710 superstars no?
Superstars you are.
InitialD is offline
Old 09-24-2004 | 02:49 AM
  #16133
InitialD's Avatar
Chastity belt is a must then!
Oh my ! You mean you're still wearing it? Respecta !
InitialD is offline
Old 09-24-2004 | 02:51 AM
  #16134
InitialD's Avatar
Default Re: Re: Re: Rear anti-roll bar
Now you why I don't post pics of my car ! Turns out that they look even more dirty than in real life. Funny how somebody would want to sabotage you.
InitialD is offline
Old 09-24-2004 | 02:52 AM
  #16135
InitialD's Avatar
What do you think ?
Bro, the shorter wheelbase mod should take care of the low speed corner, no?
InitialD is offline
Old 09-24-2004 | 02:57 AM
  #16136
markp27's Avatar
Default Re: Re: Re: New Servo Lever
Nope
markp27 is offline
Old 09-24-2004 | 03:00 AM
  #16137
markp27's Avatar
Doesn't the mod also affect the ackerman?
markp27 is offline
Old 09-24-2004 | 03:10 AM
  #16138
InitialD's Avatar
You got me thinking along the same lines... Bravo. I guess the RING is with you this weekend.
Moving the arms behind angles the steering linkage as the servo saver is at fixed position while the linkage to the steering block gets pulled behind when the wheelbase is shortened. Sort of like mimicking the new servo saver... I guess it makes the front wheels toe out a little too if you didn't adjust and compensate the steering linkage lenght.
Last week I tested the short wheelbase mod. From 1 mm shorter to 2 mm shorter, the car felt better and better. I'll try 3 mm this weekend. The car felt easier to turn. Sort of like less scrubbing during the turn on sharp apexes with the rear end still very stable.
I hope to test the new Serpent rims I got too. 40 shore rear and fronts. First impressions were the compound seem to be more firm like what you noted.
InitialD is offline
Old 09-24-2004 | 03:15 AM
  #16139
InitialD's Avatar
Default Re: Re: Re: Re: New Servo Lever
Nope
Shucks ! Is that the elusive hooded guy sitting at Serpent R&D in Holland? muahahah
InitialD is offline
Old 09-24-2004 | 03:21 AM
  #16140
Sow&Steady's Avatar
I'll take it off when I travel to Budapest or Sao Paolo .. ahem.
