Old 04-22-2004, 12:21 AM   #8626
PSI Racing's Avatar
Default Re: Re: Re: Re: Re: Re: Re: Re: Re: Front Ball Diff
Originally posted by InitialD
That's a smart way. If anyone remembered, I actually asked this question to Julius (not knowing at that time that he does not work for Serpent ) when the 710 just came out about the batch numbers below the box which has the weight of the contents and some numbering and alphabets printed. I asked what those numbers meant and somebody chided to say that was utterly waste of time to know what it meant !
Perhaps it's good to bring that subject up again and probably have people like Rene C answer it.
On the back of my box one of the codes is specifically labeled "Batch: D495".
So I'm sure if you could get someone to say what batch numbers have the updated parts, you would know which kit to buy.
On the back of my other Serpent kits, they each have a batch number.
I'm not sure if we could use this method around the world, or just here in the US.
PSI Racing is offline   Reply With Quote
Old 04-22-2004, 12:22 AM   #8627
cyba888's Avatar
Havent touched my 710 in about 3 weeks and I dont plan to run it in another 3 weeks. How long can I let the 710 sit before I need to change the shock oils? Going to LA for vacation
2014 and 2015 BD7 Black Series, Yokomo RPX ESC- Yokomo 4.5T Motor
Yokomo B-MAX4 III Factory Team Kit, Muchmore ESC- LRP 6.5T Motor
Mugen MBX7R Eco- 2200 KV Motor
Futaba 4PX
cyba888 is offline   Reply With Quote
Old 04-22-2004, 12:44 AM   #8628
BaxterC's Avatar
Going on Vacation and not taking your SNAKE no... you will need to rebuild it completely when you get back or she'll not want to perform... be nice to your snake and take it to LA, you may find a track and then you can race there one or twice...
I am only joking, dont take it to heart...
BaxterC is offline   Reply With Quote
Old 04-22-2004, 12:50 AM   #8629
PSI Racing's Avatar
If you're coming here to Southern California for vacation, you better take your 710 with you.
We have a lot of big namers down here and several nice tracks.
It's also usually sunny and warm.
You'll regret not bringing it with you.
Old 04-22-2004, 12:50 AM   #8630
InitialD's Avatar
I would take off the shocks or just suspend the wheels and not let it compressed.
I would not be worried about the shocks. I would be more worried about the engine.
Old 04-22-2004, 12:51 AM   #8631
InitialD's Avatar
Temptation is great !
Old 04-22-2004, 12:52 AM   #8632
InitialD's Avatar
Default Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Front Ball Diff
It should work the world over if we can decipher the coding since it comes only from Holland and distributed to the world all over.
Old 04-22-2004, 01:00 AM   #8633
PSI Racing's Avatar
Default Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Front Ball Diff
I wasn't sure if Serpent USA put these stickers on, that's why I wasn't sure if this method would work.
Ok, here's what my sticker says.
SERPENT MRC B.V.
QUALITY CONTROL
80200
SERPENT 710 2004
PACKED BY: IV/FN
CHECKED BY: RH
BATCH: D495 WEIGHT: 2.295 kg
I know the codes might be different, but is the format basically the same on your's?
Old 04-22-2004, 01:07 AM   #8634
InitialD's Avatar
Default Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Front Ball Diff
Yes they are. Mine also says Batch D495...
Old 04-22-2004, 01:10 AM   #8635
PSI Racing's Avatar
Default Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Front Ball Diff
I got mine before Christmas last year.
I know it was one from the first batch to the US.
Old 04-22-2004, 01:12 AM   #8636
PSI Racing's Avatar
Default Batch
I guess now all we have to do is find out what batch has the updated parts.
Old 04-22-2004, 01:13 AM   #8637
InitialD's Avatar
Default Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Front Ball Diff
Mine was one of the first batches to Malaysia.
Old 04-22-2004, 01:16 AM   #8638
PSI Racing's Avatar
D, have you tried out that front ball diff yet?
How do you like it?
How does the car handle with the front one-way locked?
Did you have to use a different setup?
Old 04-22-2004, 01:34 AM   #8639
InitialD's Avatar
How do you like it?
Tried it briefly. Nice handling. Must not make the diffs too loose. Turning is nicer than the front solid axle.
Unfortunately when I tried the front diff, I was using different shocks. 40 wt with 4 holes (1.2 mm holes) front and rear. Was using front yellow and rear white with 37 shore front and rear. Car handled nice. I just need to test out more with harder springs and harder tires this weekend with the same shocks.
Old 04-22-2004, 01:36 AM   #8640
markp27's Avatar
Send a message via ICQ to markp27
Have you put the Mazda into action yet?
markp27 is offline   Reply With Quote
