Serpent 710
Old 09-07-2004 | 03:27 AM
  #15226
Sow&Steady's Avatar
Originally posted by Pyramid
The new S720,
Sorry for the crappy picture, the new camera is at home.
Dang! Now I have to go get a THIRD kit!
Sow&Steady is offline
Old 09-07-2004 | 03:29 AM
  #15227
Sow&Steady's Avatar
Default Re: Re: Droop discussion
Originally posted by InitialD
Damn. A typical case of having to clean your own shit...
Old 09-07-2004 | 04:09 AM
  #15228
markp27's Avatar
Originally posted by Sow&Steady
Maybe I'll share with you the fact that I am a member of 2 clubs here in the UK and both track records are held by 710s.
Sow, now don't be so modest and tell us who holds the records
markp27 is offline
Old 09-07-2004 | 05:03 AM
  #15229
Denso#1's Avatar
Thumbs up 3 hobby.com back up
When did this happen ?????????????? i clicked on my favourites and bang there it is in all its former glory
Denso#1 is offline
Old 09-07-2004 | 05:14 AM
  #15230
markp27's Avatar
Default Re: 3 hobby.com back up
SOW!!!!! IT'S BACK!!!!!!!!!!!! It must have been D with his ring!
markp27 is offline
Old 09-07-2004 | 05:19 AM
  #15231
InitialD's Avatar
I know someone ... given a Serpent 710 .. who will work 24hrs a day. His name is InitialD!
Don't forget spares, tires hop ups etc.
Serpent! Take note! He will work for you for a mere kit a year!
Of all things that I do not expect you to remember, you remembered ! Amazing memory selection.
InitialD is offline
Old 09-07-2004 | 05:22 AM
  #15232
InitialD's Avatar
Damm... you really are the Miester, that is 57gr + 2 screws and plastic nuts.
Oh, I cannot take all the credit. Somebody posted this eons ago. But that's using 9550 servos for steering and throttle.
If you are using 2 standard servo size (ex, S9451) and receiver (ex, Futaba R131iP), you will need about 120gr on the left.
Yup, that's what I found. I needed to put a LOT of weight to balance it up (if I recall more than 80 grams) with normal 9451 steering and 2144 throttle servos. But then again, I don't put any now and I have not felt anything. Perhaps the RING makes up for everything.
Using the new hudy tweak board from HSP-108255 will gives more accurate reading but then of course if you could afford 4x digital scales that would be nicer
More toys !
InitialD is offline
Old 09-07-2004 | 05:24 AM
  #15233
Denso#1's Avatar
Markp27
Check out the shout box on 3hobby
Denso#1 is offline
Old 09-07-2004 | 05:28 AM
  #15234
markp27's Avatar
Markp27
Ahhhhhhh so nice to have 3hobby back I've already "shouted" back
markp27 is offline
Old 09-07-2004 | 05:48 AM
  #15235
Sow&Steady's Avatar
I don't have a choice BUT to be modest for the record holder for BOTH tracks is none other than Mark Green.
Old 09-07-2004 | 05:57 AM
  #15236
Sow&Steady's Avatar
Basically 3hobby.com was hacked ... its been getting hacking attempts about 6-8 times a week. they finally managed to get in and then try to hack the main server so my hosting provider shut me down.
They turned it back on after I kept requesting an opportunity to back up my files. This only hapenned a couple of hours ago. I've also been asked to find the problem or 3hobby.com will shut down again.
Am working on that now. you'll see some of the "services" slowly come back on when I've cleaned out what I think may be the problem.
  #15237
Sow&Steady's Avatar
Default Re: Re: 3 hobby.com back up
Yeap ... that's D is on top of the Users' List ! Its his RING!!!
Old 09-07-2004 | 05:59 AM
  #15238
Sow&Steady's Avatar
Oh yes SERPENT, don't forget some spares ... and the latest Huby set-up thingamajig too.
Its called hormones or PMS or something. You get older, go senile and then you have a neuron or two reconnect and voila! Einstein again!
Old 09-07-2004 | 06:20 AM
  #15239
packetdreamer's Avatar
dang! it's acting up again!
packetdreamer is offline
Old 09-07-2004 | 06:23 AM
  #15240
Denso#1's Avatar
Angry 3hobby.com
And then it was gone again
Denso#1 is offline
