Serpent 710
Old 09-06-2004 | 08:56 PM
  #15196
InitialD's Avatar
Originally posted by tomkelley
Really though I don't think they were overcompensating for the front solid axle other than the rear differential and sway bar settings.
Thanks for the setup details. Much appreciated.
I do have to admit that the new Mega .12 engines performed quite admirably. I just couldn't figure out why they had set their bottom end setting on the engines so lean, but they sertainly pulled a lot of cars on the long strait and sweeper.
Can't wait to see those engines. Did they use stock carbs or put Nova ones?
InitialD is offline
Old 09-06-2004 | 08:58 PM
  #15197
InitialD's Avatar
Default Re: Re: Re: 710 at the US Nationals
Brandon was front one way most the time, not sure if he went to the locked for the main, my guess is not because he was using one way in qualifing.
I'm just guessing from the pics because the caster in the front is set very little. More like for solid front axle use.
Also, I thought that he would be using solid front because the last major race he raced the 710 with one.
InitialD is offline
Old 09-06-2004 | 09:10 PM
  #15198
tomkelley's Avatar
Default Re: Re: Re: Re: 710 at the US Nationals
Originally posted by SERPENTFREAK69
any pics?
You have to look few posts back!!!
tomkelley is offline
Old 09-06-2004 | 09:16 PM
  #15199
tomkelley's Avatar
stock carb
Old 09-06-2004 | 09:25 PM
  #15200
Pyramid's Avatar
Registered User
The new S720,
Sorry for the crappy picture, the new camera is at home.
Pyramid is offline
Old 09-06-2004 | 09:36 PM
  #15201
InitialD's Avatar
Originally posted by Pyramid
The new S720,
That's a good one Pyramid !
Damn, I must now get myself one because of these new things that they include.
A side note, I noticed from a friend's plastic front upper bumper brace from Serpent that he replaced was REALLY much thicker. Kudos to Serpent for staying true to their word. Performance through evolution.
InitialD is offline
Old 09-06-2004 | 09:47 PM
  #15202
Pyramid's Avatar
Registered User
Indeed they are and the new lola lower bumper is really strong also.
Pyramid is offline
Old 09-06-2004 | 09:57 PM
  #15203
markp27's Avatar
The new S720,
Nice one Pyramid! The new diff collar - what is the difference between the new one and the old one?
markp27 is offline
Old 09-06-2004 | 10:03 PM
  #15204
InitialD's Avatar
Ummm, I think the same thing what Rene is trying to achieve with the grooves and the grease? Should make the setting of the diff not so sensitive.
InitialD is offline
Old 09-06-2004 | 10:20 PM
  #15205
markp27's Avatar
I deny all knowledge of what you're talking about
markp27 is offline
Old 09-06-2004 | 10:28 PM
  #15206
markp27's Avatar
Default Droop discussion
D, where you responsible for starting this discussion in one of the forums? I'm sure it has something to do with the Ring!
Take a look at the Xray T1 Forum - Someone asked why the droop screw needs to be reset due to tyre wear. I've explained why, but no one seems to understand what I'm saying Are we discussing different things?
markp27 is offline
Old 09-06-2004 | 10:36 PM
  #15207
InitialD's Avatar
Why so defensive?
InitialD is offline
Old 09-06-2004 | 10:52 PM
  #15208
InitialD's Avatar
Default Re: Droop discussion
Of course it has to do with the RING...
Well, I guess it's just different interpretations. Both are correct. I think the guy sees the droop as in the value you get on the droop gauge. That is fix and does not change when tire wears down. Chassis uptravel however changes.
Damn. A typical case of having to clean your own shit...
InitialD is offline
Old 09-06-2004 | 11:00 PM
  #15209
InitialD's Avatar
Default Re: Re: Droop discussion
If they are still stubborn and do not want to listen to you , point them to the MASTER.
http://www.mytsn.com/publ/publ.asp?pid=7107
Especially this part;
Other things to change....
If you change tire size but compensate for it using the above method you will need to do something else. When you use smaller tires you will need to raise the car to get the same chassis clearance. When you do this you will change the position of the suspension. If you were to raise the chassis a lot you could end up with the suspension reaching the downstops and not going further. So if you really want to adjust things correctly, you need to change the downstops too. You can use the same trick as above.
If you run for instance 4mm smaller tires than what is in the setup sheet, you need to change the downstops by half the difference. So if the setup sheet calls for a 7mm rear downstop you'd need to set 5mm if you were to run the small tires.
InitialD is offline
Old 09-06-2004 | 11:25 PM
  #15210
markp27's Avatar
Exactly what I've been tryig to explain - some have fixed themselves in a certain understanding and can't see the wood for the trees.
I knew it would have something to do with you
markp27 is offline
