Old 08-02-2004, 11:13 AM   #14476
Sow&Steady's Avatar
Default Re: Lola
Originally posted by PSI Racing
They sell it as a complete kit.
Bodymount-set front Lola-GTP type S710
http://www.mytsn.com/products/product.asp?prid=3837
All they need to do now is come up with a rear floating mount.
http://3hobby.net REVISITED V2 - Its on steroids!
https://www.facebook.com/ssteady
Sow&Steady is offline   Reply With Quote
Old 08-02-2004, 01:21 PM   #14477
Neil Rabara's Avatar
Which items on the car are considered common break items and stress related breakages?
Neil Rabara is offline   Reply With Quote
Old 08-02-2004, 04:21 PM   #14478
Arun's Avatar
In a normal race hit, the only things that really break are the front steering blocks.
This is as long as you get the updated kit with the longer rear arms, thicker upper bumper, thicker rear shock tower, and newer dogbones (not brittle like original dogbones). The only other problems come from axle wear, which can easily be prevented by regularly greasing the dogbone pins.
http://nexusracing.com
Arun is offline   Reply With Quote
Old 08-02-2004, 07:48 PM   #14479
InitialD's Avatar
Good summary Arun. Is there any mention about newer dogbones? I have not heard of it.
Old 08-02-2004, 10:33 PM   #14480
Arun's Avatar
It was not something that was really mentioned outright, but the original dogbones, like the ones included in most kits, used to snap easily on impacts. The new ones will bend before they break, much like on the impulse/705. The new ones are obviously heavier, though I have not weighed them. They also seem to be darker in color. The original ones had a slight fade to them. They have been available for a while now.
They are not really worth buying if you can get the 835 shafts though.
Old 08-02-2004, 11:05 PM   #14481
Wouldn't that add more drag with the grease?
Old 08-02-2004, 11:06 PM   #14482
Is that the universal with the outdrives?
Old 08-02-2004, 11:09 PM   #14483
Arun's Avatar
I never noticed a difference before/after. Even so, the 710 probably has the most free drivetrain of any belt gas car.
Old 08-02-2004, 11:11 PM   #14484
Arun's Avatar
I don't understand what you are asking here.
Old 08-02-2004, 11:29 PM   #14485
Well, usually the universal is the shaft with the axel. What exactly are you referring to with the 835?
Old 08-03-2004, 01:00 AM   #14486
Pyramid's Avatar
He meant the regular OLD spring steel dog bones.
Pyramid is offline   Reply With Quote
Old 08-03-2004, 02:45 AM   #14487
Arun's Avatar
What Pyramid said is correct. I'm sure you know how durable the spring steel is. If serpent releases universals, I will never buy them. Once you put spring steel in your car, you can quit worrying about your drivetrain. I have the HUDY spring steel wheel axles (#801214) combined with the 835 spring steel driveshafts (#808320) and custom modified spring steel one-way outdrives (#808223) in the front of my car . I bought the dogbones, and had the other parts left over from my 705. The rear of my car is all stock. I re-grease the rear dogbone pins on a semi-weekly basis to prevent axle and diff wear.
Here is a crude pic of the front drivetrain.
Old 08-03-2004, 03:13 AM   #14488
Pyramid's Avatar
[BI have the HUDY spring steel wheel axles (#801214) combined with the 835 spring steel driveshafts (#808320) and custom modified spring steel one-way outdrives (#808223) in the front of my car . [/B]
Just wondering what will airborne on deadly impact those will be the strongest combination.
Old 08-03-2004, 10:03 AM   #14489
PSI Racing's Avatar
I just got an email back from Serpent USA.
They said that we could order
Part #SER100003 Spare Parts Set for Serpent 710
http://www.serpent-usa.com/product-page-ser100003.html
Part #SER100006 Option Parts Set for Serpent 710
http://www.serpent-usa.com/product-page-ser100006.html
from our local hobby shops, so the prices should be cheaper than what they have on the Serpent USA website.
Yes, you may purchase these items from your local shop.
Thank you for the inquiry.
Best regards,
Serpent USA
PSI Racing is offline   Reply With Quote
Old 08-03-2004, 03:46 PM   #14490
I understand now, thanks guys.
