Old 04-06-2004, 10:25 PM   #7876
Trader Rating: 2 (75%+)
Originally posted by jscamry
PUNISHER: when you are drawing out your designs do you, draw them on paper 1st and decide what colors you want to use or do you do it all on the body:?also what kind of airbrush are you using??
thanks Jason
You have a PM
PUNISHER is offline   Reply With Quote
Old 04-06-2004, 10:51 PM   #7877
MrChan's Avatar
Send a message via ICQ to MrChan
Default Re: Re: Re: Re: Re: Re: Re: engine shims
Originally posted by InitialD
No idea. No leave left !
Are you going? How many SG guys are going?
I think about 10++ ..
How many from Malaysia ?
MrChan is offline   Reply With Quote
Old 04-06-2004, 10:57 PM   #7878
Send a message via AIM to Profoxcg
MrChang, what is a 715Rc?
Profoxcg is offline   Reply With Quote
Old 04-06-2004, 10:58 PM   #7879
Default fw-05 versus s710
has anyone had a chance to compare these cars?
Old 04-06-2004, 11:16 PM   #7880
InitialD's Avatar
Originally posted by AMGRacer
The 2102 is the old specification motor based on the first generation RS12 motors with the cast piston, not CNC machined.
Here are the specs:
2102 SX12 3P-RE
RPMl 34.000
Bore x Stroke 13,80 mm x 14,04 mm
Ports 3
Piston Type casted type
Crankshaft 11 mm - SG
Plug Style normal
Exhaust Type Rear
Carb 5,5 mm - Aluminium alloy - Slide - Double adjustment
Where did you get those specs? If they are ordinary rear exhaust 3 port engines with microcasted piston, the part number should be 2103 MCP since there is already an ordinary rear exhaust 3 port engine in NovaMega's product line up in the form of part number 2103.
Old 04-06-2004, 11:17 PM   #7881
InitialD's Avatar
Default Re: Re: Re: Re: Re: Re: Re: Re: engine shims
Don't think anyone is talking about going !
Old 04-06-2004, 11:20 PM   #7882
Default Re: fw-05 versus s710
Compare? FW-05 is made by kyosho and S710 is made by Serpent, so its different
GoldFinger is offline   Reply With Quote
Old 04-06-2004, 11:22 PM   #7883
InitialD's Avatar
I have seen a few in action. Not that impressive I must say. But I guess as with all cars, you need to set it correct. Anyway, I would gather that from the shaft driven design, high internal ratio (3.0 or 3.08) with a minimum FDR of about 5.0, the car is suited for smaller tracks and have good acceleration. If you have a huge track, the 710 is the way to go.
Old 04-06-2004, 11:23 PM   #7884
InitialD's Avatar
Default Re: Re: fw-05 versus s710
A politically correct statement.
Old 04-06-2004, 11:26 PM   #7885
AMGRacer's Avatar
Not microcasted. CAST piston, ie. the technology before the RS12 S3. Think RS12 S1.
Let me find some specs.............
OK check here:
http://www.serpent.at/action/mega/mega.html
AMGRacer is offline   Reply With Quote
Old 04-06-2004, 11:30 PM   #7886
Default serpent battery
Can anybody tell me if i should discharge my reciever batteries after a weekend of racing to keep them in good condition?
P.S. has anybody heard when the new wheel are coming out for the 710?
Brett.w is offline   Reply With Quote
Old 04-06-2004, 11:32 PM   #7887
AMGRacer's Avatar
Default Re: serpent battery
If it is a NiMH RX pack then you dont need to discharge. If it is a NiCD RX pack then you should discharge.
Old 04-06-2004, 11:33 PM   #7888
InitialD's Avatar
Aha... But I fail to see why NovaMega comes out with an old engine design when MCP is the way to go... Clearing off old stocks? Anybody's guess.
BTW, thanks for the link.
Old 04-06-2004, 11:36 PM   #7889
AMGRacer's Avatar
I think Serpent USA has screwed up. That motor is OLD I remember a few kicking around like 3 years ago....... BTW that motor also sucks hard, at least the original items did, the piston/sleeve fit was TERRIBLE and it took around 2 litres to run the motor in. The porting was not optimised in the crank and the bottom end was shocking.
Old 04-06-2004, 11:42 PM   #7890
InitialD's Avatar
Like AMGRacer mentioned, NiMH does not need discharging. But some purist would insist on discharging theirs anyways.
Look at mytsn 710 forum. Ronald Baar replied to say this;
"The mould is in its final stages, but then the rims must be produced and then the tire manufacturers will take their time to make the complete product.
I estimate it will take until june-july before most shops will have them.
Until then the current ones are still working fine and will remain available as well. "
