Serpent 710
Old 04-02-2004 | 09:44 AM
  #7546
Marcos.J's Avatar
Super Moderator
Originally posted by GlennCauley
I'm glad to know that I'm not the only one who doesn't necessarily subscribe to the theory that "more expensive is always better"
I too used to run expensive servos for both throttle and steering, but then realized that I didn't have to for throttle.
Cheers guys!
especially when i can get the Futaba S3004 for $8.99 at my local hobby shop, better than spending $80 to $100 on a digital servo that will perform just as good for throttle and brake duties!!
Marcos.J is offline
Old 04-02-2004 | 09:45 AM
  #7547
EXACTLY !!!
GlennCauley is offline
Old 04-02-2004 | 09:46 AM
  #7548
Marcos.J's Avatar
Super Moderator
Default Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Slowly the 710 is getting the
Originally posted by PSI Racing
The only problem is I taught my wife about RC's, so it's not easy to pull that off.
Second she's always online checking the bank account.
It's not that bad though.
She bought my 710 for me for Christmas, and she let me build it before Christmas.
She also bought me a 1/10 gas stadium truck for my birthday last year, and a 1/8 on-road the year before.
Plus I supposed to get a new motorcycle (2004 Yamaha R1) around May.
She'd only get me a new engine if mine is broke.
I just rebuilt it recently, so I don't think it's going to break anytime soon.
and R-1 lucky you
Marcos.J is offline
Old 04-02-2004 | 09:52 AM
  #7549
teammpp's Avatar
Most definately not always better. I think that less expense was always better cause it meant you were going faster and not hitting and breaking much.
We need to start a club for the cheaper is always better guys. Never know where it could lead.
We could even follow F1 and threaten a breakaway world race series if the manufacturers dont supply us with cheaper engines and tires
teammpp is offline
Old 04-02-2004 | 09:57 AM
  #7550
Marcos.J's Avatar
Super Moderator
Marcos.J is offline
Old 04-02-2004 | 11:08 AM
  #7551
clmbia45's Avatar
[QUOTE]Originally posted by Palmaris Europe
[B]Correct and not correct.
It depends what type of Ti you use. Most types of Ti are softer than Steel (6AL-4V for a starter which is the most common Ti used in R/C cars). The problem is using the Ti correctly. For instance, you cant use Ti outdrives with steel pin dogbones as these will just cut through the Ti outdrives in a matter of runs. yet you can use the steel outdrives and use Ti dogbones without any great deal of wear over a full year.
Probably because the titanium dogbones use steel pins (or at least the ones I had did). And you can't get them out to replace them as you can with the steel ones.
clmbia45 is offline
Old 04-02-2004 | 11:21 AM
  #7552
clmbia45's Avatar
Default Re: Slowly the 710 is getting there....
Originally posted by markp27
Well, I've cancelled my order for my 2106 Novamega engine with my LHS here in DE and am ordering it via those nice guys at The Border Now it can't be too long before I get the 710 onto the circuit.
Tomorrow, the 705 makes its first venture onto the circuit since October - everything rebuilt, re-lubed and reset.
In rebuilding the 705, I saw all the mistakes I made when I first built it last year. It was then my first RC and I thought I'd done a good job in building it - now I recognise that there were several things which I hadn't appreciated when I was building it.
I just hope my engine still starts!
And it might not, with your Grosseshloshingeverwasser!
clmbia45 is offline
Old 04-02-2004 | 01:17 PM
  #7553
Marcos.J's Avatar
Super Moderator
My bad. I heard 60% from somewhere.
at 60% , that engine would have been screaming!!!!!!!!
Marcos.J is offline
Old 04-02-2004 | 01:52 PM
  #7554
Marcos.J's Avatar
Super Moderator
Default Re: Re: Re: Re: Re: Re: Slowly the 710 is getting there....
Originally posted by InitialD
Euro !
1 EUR = 1.23288 USD
wow is there anything that you dont know!
Marcos.J is offline
Old 04-02-2004 | 02:01 PM
  #7555
clmbia45's Avatar
Talking
IMHO=in my honest opinion
Nobody on this forum is HUMBLE!
clmbia45 is offline
Old 04-02-2004 | 09:49 PM
  #7556
markp27's Avatar
Default Re: Re: Slowly the 710 is getting there....
I couldn't have put it better myself!
markp27 is offline
Old 04-02-2004 | 10:23 PM
  #7557
rodrigo1508's Avatar
Hi again, What do you guys normally do to break in your engines?
rodrigo1508 is offline
Old 04-02-2004 | 11:12 PM
  #7558
BaxterC's Avatar
Hey Rodrigo, I posted mumething on the engines thread, Here is what I wrote:
Originally posted by BaxterC
Well, this is a very contravercial subject, but from my research, I have found this.
Here is what you do.
With the engine in the car, Run the motor as slowly as you can and very rich, for about 2 minutes, then let the engine cool completely, then run it as slow as possible for another 2 minutes then let it cool completely, continue this for about 3 tanks. REMEMBER that when your motor stops to cool, make sure the piston is at the bottom of the stroke. Once you have completed this, then start to cycle the engine in the 2 minutes by taking the revs slowly to about a 1/4 throttle, then down, let it cool again, do this twice, then take it to half throttle and down, but remember to be progressive, smoothly up, and smoothly down. Let it cool, do this twice, then to 3/4 throttle and down, do this twice, you are now ready to start to lean it out and get it up to race tuning. Remember to change your plug when you have finished.
Remember that this is what I do, but I run mine on a bench with a prop, it is much more controlled.
BaxterC is offline
Old 04-02-2004 | 11:49 PM
  #7559
Marcos.J's Avatar
Super Moderator
i run one tank at half throttle very rich, let it cool and one omre tank at full throttle very rich, then its time to hit the track and start leaning it out.
Marcos.J is offline
Old 04-03-2004 | 12:00 AM
  #7560
jfc_tech's Avatar
I usually run at least the first tank, 1 tank idling on a car stand (wheel off ground). I use hotter plug #5 for run-in. After that either one more tank idling or on road 1/2 throttle rich, tons of smoke then stop half tank.let it cool. start and let it hot reach 100deg, cool back...cool, hot,cool, hot. all the while the while leaning a bit by bit...until 1 litre, i think. well, thats me. Now my engine is still in good shape...my NovaMax P5. Now using #6Tf plug.
jfc_tech is offline
