Serpent 710
Old 03-28-2004 | 08:13 PM
  #7051
clmbia45's Avatar
Smile Re: Re: Re: Re: DOG BONES
Originally posted by InitialD
Not that I know off any dogbones of that size...
Thanks for looking. jack
clmbia45 is offline
Old 03-28-2004 | 08:41 PM
  #7052
Marcos.J's Avatar
Super Moderator
Originally posted by jfc_tech
check this out. I used during my recent final. i predicted rain will fall, so i just trued the tires like this. cool effect...
i should have won my final (rain only starts the last 10 minutes) ...i was leading while the rest engine died...left only 3 cars on the track...suddenly the race director stop when only left 1'45''. the rain was too heavy he said! ..end up 3rd(based on qualifying result!)
thats a pretty good cut
Marcos.J is offline
Old 03-28-2004 | 08:47 PM
  #7053
I raced today and I was the only 710 at the track. i had some problem loosing rear trackion but my car was pretty quick. I was told. My mistake was getting late to the track. So next sunday I will be there early to have time to set up. - I will be gettin my caliper this week (digital) to I can set my centax properly.
my friend told me my clutch was slipping? how do I fix that?
Profoxcg is offline
Old 03-28-2004 | 08:48 PM
  #7054
Marcos.J's Avatar
Super Moderator
wich track did you race at?
Marcos.J is offline
Old 03-28-2004 | 09:03 PM
  #7055
InitialD's Avatar
Have you done the flyweight mod? Loosen the pre-tension nut for the clutch spring till you get no slippage.. Do it 1/4 turn at a time.
InitialD is offline
Old 03-28-2004 | 09:13 PM
  #7056
Marcos.J's Avatar
Super Moderator
InitialD how was your racing? im jealous i had to work , cant race until next sunday, i want to try my new body (Alfa-Romeo)
Marcos.J is offline
Old 03-28-2004 | 09:17 PM
  #7057
markp27's Avatar
When I'm not around, somebody decides to show off with his new shell !
I'm told mine is ready.
Well, it wasn't a picture of mine, so that should be ok? No?
A "friend" of mine has borrowed my D1 and not brought it back yet!!!! As soon as I get it back, I take a pic of my new shell.
Still no signs of my servos nor motor Man, this is getting stupid!!!
markp27 is offline
Old 03-28-2004 | 09:25 PM
  #7058
Coral Springs, i liked that track very much
here is a picture of it
Profoxcg is offline
Old 03-28-2004 | 09:26 PM
  #7059
markp27's Avatar
Originally posted by crashed_1
Funny thing is the colour reacts differently to light source... If you look at it from a 90º angle it's GREEN, but diagonally it's BLUE....
Oh well...
WOAH!!! That sounds pretty freaky to me!!! I think we need a picture of this shell
markp27 is offline
Old 03-28-2004 | 09:27 PM
  #7060
Default Where IS Serpent?
If anyone knows....I'm actually in the Netherlands now and would love to check out the RC Mecca if permitted......
zaiguy is offline
Old 03-28-2004 | 09:28 PM
  #7061
Sow&Steady's Avatar
Well, as usual, luck and driver skills will always let you down again ! Anyway, I was actually very satisfied with my 710. The car was fantastic on a tight infield / technical and a high speed straight with a sweeper hook at the end of the track. Too much traffic and the solid front was very useful. When tire selection was right, the car was very responsive ! Did not change my car setup at all from the previous outings on other tracks. Just played a little (plus minus 5 minute turns) on the rear diff screw. I just changed tires using 35 shore front and 37 shore rear or 37 shore front and 40 rear. Tire wear was the same front and rear !
Well, at least you had fun.
Was it RCTecs' new track?
I was lucky enough to get inivited on their opening and drove a few tanks. A lot of grip and certainly longer than it looks. My Rody was screaming by the time I reach mid-way through the straight.
Keat Seng was fastest amongst all of us ... especially in the infield.
Who won in this race?
I need to look your set-up closer ... wondering how you managed to get equal wear with those set of tyres!
Sow&Steady is offline
  #7062
InitialD's Avatar
Originally posted by Marcos.S710
InitialD how was your racing? im jealous i had to work , cant race until next sunday, i want to try my ney body (Alfa-Romeo)
Thanks for asking Marcos. It went just OK for me. Was happy with the car's performance. Excellent and very agile. Not happy with myself though and the mistakes that one makes.
After all the hard racing, the original kit rear bottom arm (right side) had the treading loose which I replaced with a new one. Not other parts broke. Oh yes. Stripped the 1st gear spur too during practise the day before due to own fault when the car flipped. The meshing of the spurs / pinions need to be very good to avoid the the gears stripping. After the change of spurs and aligning the engine and gear meshing properly, the spurs lasted the whole day's race without problems.
InitialD is offline
  #7063
That's all it takes to fix it? lossen the pretension nut?
BTw i have cut the weights so they seat in between the posts.
Profoxcg is offline
Old 03-28-2004 | 09:31 PM
  #7064
Sow&Steady's Avatar
Originally posted by markp27
Sow&Steady has provided some web space for the FAQ, so now I'm not limited to only 200k Bytes, it is now possible to add some pictures to the doc - but unless you have a good printer it may not print out so good.
With pleasure Mark
Let me know if you want the set-up to be diferent. Your own web space maybe? Or web journal? Own ftp account?
RC Reviews at your service!
Old 03-28-2004 | 09:35 PM
  #7065
Marcos.J's Avatar
Super Moderator
yes i have seen that one before i alwayss wanted to make it out there but havent got a chance too!
Marcos.J is offline
