Serpent 710
#6302
Originally posted by cox049
I did it as explained in Mark's FAQ and I like it. I added 2 bushings on the body post to take it back further and it fits perfect . Had to cut the lower pin on the B post and drill a hole.
No drilling or cutting required. I think this was mentioned by ammdrew and fmolzer.But do note that it makes the front shock tower mounting weak...
#6303
Originally posted by InitialD
If you look at the plastic tree that contains all your shock parts, there would be one unused item that would fit fine as spacers. You can use it as I believe it is about like 5 or 6 mm thick.
As of the strenght... It looks weaker... It feels very stiff, and my guess is that the two mounting screws would take the damage as they are longer and float those 5 or 6 mm's... Maybe is better than cutting a shock rod.
If you wanna try it and give your opinion it would be very appreciated big "D"
#6304
#6305
I found those rivet shaped plastics that I don't know what they were for...
Like what you say, it looks weak but in reality it may not be. I've tried a few runs with it and did not encounter any problems. But since I lack a long countersunk screw to mount the shock tower with the spacer, I used back the stock mounting. Also with no problems.
#6306
I just turned the shock tower around and put two flat head 3x14's .
Took a second look and it feels nice and strong. Maybe a couple of stainless screws would do a good job there, so they'll bend but won't break.
It could be called "Floating front shocks Mod"
I'm gonna crash for SHURE
.... So I'll report on how it goes
#6308
[QUOTE]Originally posted by InitialD
[B]They were actually for the older shocks that did not make use of the steel balls that snap onto the shock caps...
Now that you mention it... My kit was missing the steel balls to complete the setup and had those cheapo plastic rivets... I knew I wasn't going to use THAT... So I had to go and get a bag ($7.99) of steel balls to be able to finish the "maqina"
#6309
Hey guys... sorry for the site and all... I tried 50megs, could not get in to upload, and I tried geocities... still could not upload all... and a bandwidth restriction
that makes me mad... but at least we have a smaller FAQ that I saw the tire selection from Art... did you see the tips and tricks... I thought that was sweet.... http://www.daltonshop.com/tips_tricks.htm
#6312
If you practice, you'll get a honorary
