Serpent 710
Old 03-18-2004 | 06:20 PM
  #6286
InitialD's Avatar
Originally posted by markp27
I'm pretty lucky in that respect! Here in Germany there are 4 excellent tracks all within 45 mins of me, but none of which have been driveable uptil now due to snow
But you could drive up or take a train ride to Heemstede though...
InitialD is offline
Old 03-18-2004 | 06:25 PM
  #6287
Marcos, your car looks very good
Profoxcg is offline
Old 03-18-2004 | 06:26 PM
  #6288
InitialD's Avatar
Default Re: Initial D
Originally posted by Profoxcg
BTW, do you think it is posible to get a -x mm for the end play? is so then what do you do? (dumb question NM)
Theoretically, yes. That could be a result when you put too much shims in step 8.6 and also if you put too much shims in step 8.7.
Hardly likely that would get a negative end play when doing shimming in step 8.6. More likely for you to get it when you're in step 8.7.
Like I mentioned, when you feel that there's something wrong when you reach to the end of screwing the F14 screw when you put too much shims in step 8.7. You will find that there is a resistance to lock the F14 screw onto the SG shaft of the engine at the end just before tightening it completely. Do not tighten this further when this happens as you'll probably destroy the 2 small normal bearings.
you also mentioned that a poorly tuned engine will not be responsive. well my engine ... when I try to shut it off by blocking the exhaust , takes forever to die. (more than 10 secs)
If you try to block the exhaust and the engine refuses to die, then somewhere in your pipe connection is leaking. Check. Are you using one piece or 2 piece pipe?
Try shutting off the engine by stopping the engine flywheel. The other method is to pinch the fuel line supply into the carb to cut off the engine. The latter method would be the best as you could also check if the low end needle is too lean or too rich. When pinching, the engine idle should only go up a little and then die straight away. If it take forever to die, then the low end needle is rich.
thanks, do you know what are the "stock" neddle setting?
I turned 1.5 turns on the low end and 3 on the main needle.
I would not know about the Sirio. I would suggest to ask for help from a reliable person or if you're daring enough, tune it yourself. Always tune from rich settings. HSN first and then LSN. You could just richen out the needles to 4 or 5 turns out on the LSN and HSN and start tuning from there.
InitialD is offline
Old 03-18-2004 | 06:30 PM
  #6289
great thank you !
Profoxcg is offline
Old 03-18-2004 | 06:53 PM
  #6290
jfc_tech's Avatar
My LHS is also 45 mins away and has a good selection of goods - but when I need something quickly I send off my order to holland
Well, sorry to say but here my place, either the track is around 25 or 15mins away only. the lhs also around the same time travelling.its must have been tough during the snow.
Still, i wanna try playing snow man
jfc_tech is offline
Old 03-18-2004 | 07:11 PM
  #6291
sparksy's Avatar
Default Re: Re: One-piece engine mounts for 710
Originally posted by InitialD
I remember reading somewhere about team Mugen using this in the MRX-3 at the 1/8th WC last year. What advantage can the one piece engine mount do?
Much like using a larger heatsink, but the weight is lower, and it is removing heat fron the crank case more so then the combustion chamber.
sparksy is offline
Old 03-18-2004 | 07:36 PM
  #6292
Marcos.J's Avatar
Super Moderator
Thanks a bunch , i hope that it will do better than the BMW body
Marcos.J is offline
Old 03-18-2004 | 07:37 PM
  #6293
Marcos.J's Avatar
Super Moderator
Default Re: Re: InitialD what do you think of this body?
Time to kick ass !
you know it!!!!!!!
Marcos.J is offline
Old 03-18-2004 | 07:45 PM
  #6294
Default Marcos
I few people run it at my track (bte thanks your invitantion to help me, but i am a little far your your track, do e-mail me how to get there an the times to race, ill check it out in a fews weeks )
I got an Astra body, I hope it does better than my Evo VI on my TG10R hehe
Profoxcg is offline
Old 03-18-2004 | 07:48 PM
  #6295
Thumbs up 1/8 cars
for some reason i like those lola bodies and those cars are awesome, I went to my track tonight (go racing hobbies) and there was this guy with a new 1/8 mugen (blah) but there were a few 710's I tryed their clutches and they are pretty resonsive. i left my car over night at the HS so rick can fix it for me... I miss my baby !! but tomorrow night I am gong to drive it FINALLY !!!!
Profoxcg is offline
Old 03-18-2004 | 07:52 PM
  #6296
rodrigo1508's Avatar
who make the astra body?
rodrigo1508 is offline
Old 03-18-2004 | 07:58 PM
  #6297
Marcos.J's Avatar
Super Moderator
Default Re: Marcos
check out the website for our track and pics,
www.fullthrottlespeedway.com
Marcos.J is offline
Old 03-18-2004 | 08:02 PM
  #6298
mine is by Serpent
Profoxcg is offline
Old 03-18-2004 | 08:04 PM
  #6299
awesome track!
how far is it from Pembroke Pines? I am live close to I595 and I75
Profoxcg is offline
Old 03-18-2004 | 08:58 PM
  #6300
cox049's Avatar
Default Front Shock Tower Mod
I did it as explained in Mark's FAQ and I like it. I added 2 bushings on the body post to take it back further and it fits perfect . Had to cut the lower pin on the B post and drill a hole.
cox049 is offline
