Serpent 710
#7036
guys, my s710 ruled the track this sunday. funny thing i saw the front inside tire lifting off the ground while turning the long sweeper. i wonder what might caused that ?
i was running:
reds on all corners/45wt/3holes
5mm caster clips front
highest rear RC
lowest front RC
i was running:
highest rear RC
lowest front RC
#7037
i was running:
highest rear RC
lowest front RC
i was running:
highest rear RC
lowest front RC
#7038
Originally posted by markp27
Ask Rene when you see him - I asked for one and got told off from Julius for swearing
Why'd you choose a schumacher over an Xray? Just out of interest.
Also my buddy is driving an "old" Mission and "old" 705. I help him with his 705 and he helps me with my MI2.
#7043
Originally posted by border r/c
Your problem is that you think you know it all............
Cheers, Mark.
#7045
Originally posted by clmbia45
InitialD: please check that big box of old parts you have under your bed and see if you can find something, BITTE' !
jack
jack
Not that I know off any dogbones of that size...
#7046
Originally posted by Sow&Steady
Did you race?
Who won?
Did you race?
Who won?
Anyway, I was actually very satisfied with my 710. The car was fantastic on a tight infield / technical and a high speed straight with a sweeper hook at the end of the track. Too much traffic and the solid front was very useful. When tire selection was right, the car was very responsive ! Did not change my car setup at all from the previous outings on other tracks. Just played a little (plus minus 5 minute turns) on the rear diff screw. I just changed tires using 35 shore front and 37 shore rear or 37 shore front and 40 rear. Tire wear was the same front and rear !
#7049
re: guys, my s710 ruled the track this sunday. funny thing i saw the front inside tire lifting off the ground while turning the long sweeper. i wonder what might caused that ?
Guys, here's my setup detail:
Front:
downstop: 1mm
ride height: 5mm
left camber: -1.5
right camber: -1.0
trackwidth: 199mm
toe: -0.5 out
caster: 5mm clips front
roll center: 4mm under
upstops: not used
spring: red
oil: 45wt
holes: 3
shock tower position: 2nd hole
swaybar position: flat
front axle: one-way
tires: ellegi 37
diameter: 61mm
Rear:
downstop: 7mm
ride height: 6mm
left camber: -3.5
right camber: -3.0
trackwidth: 200mm
toe: +1.5 in
roll center position upper: low inner
roll center position lower: upper
DRS arm position: lower
springs: red
oil: 45wt
holes: 3
shock tower position: 1st hole
lower shock position: outside
swaybar position: 2mm
position on arms: outside
rear axle: diff
setting: medium
tires: ellegi 37
diameter: 62mm
body: protoform stratus
Front:
downstop: 1mm
ride height: 5mm
left camber: -1.5
right camber: -1.0
trackwidth: 199mm
toe: -0.5 out
upstops: not used
spring: red
oil: 45wt
holes: 3
front axle: one-way
tires: ellegi 37
diameter: 61mm
Rear:
downstop: 7mm
ride height: 6mm
left camber: -3.5
right camber: -3.0
trackwidth: 200mm
toe: +1.5 in
springs: red
oil: 45wt
holes: 3
rear axle: diff
setting: medium
tires: ellegi 37
diameter: 62mm
#7050
Originally posted by InitialD
When I'm not around, somebody decides to show off with his new shell !
I'm told mine is ready.
If you look at it from a 90º angle it's GREEN, but diagonally it's BLUE....
Oh well...
