Serpent 710
Old 03-25-2004 | 10:49 AM
  #6856
cox049's Avatar
Originally posted by baller360
do you know wear i could get it cheaper on the internet or anywhere i could get it on the net? becuase i doubt my lhs will carry it.
Better try at www.ashfordhobby.com or www.atomichobbies.com because serpent USA is very expensive
cox049 is offline
Old 03-25-2004 | 11:40 AM
  #6857
Marcos.J's Avatar
Super Moderator
not really part number 909417 (red springs is $11.99 from Atomic hobbies and is $ 7.95 ifrom serpent ,how do you figure that atomic hobbies is cheaper i have compared the parts and i will still save bying them from serpent
see for your self
Serpent http://www.serpent-usa.com/serpent/ser050_3.html
Atomin Hobby http://www.atomichobbies.com/serpent_710parts.html
Marcos.J is offline
Old 03-25-2004 | 06:03 PM
  #6858
cox049's Avatar
see for your self
yeah you're right about Atomic, I guess I got the wrong impression looking at the assembled kits prices... Anyway I'm buying my parts from Ashford and he has 10% off the list prices on parts and lightning fast shipping. I got parts today that I ordered tuesday
Note: To buy something at Ashford you gotta call him -Robert- by phone. Attempting to buy through online orders or email will result frustrating
But than I must say that its really good to be able to talk with him, he races serpent and has great experience and knowledge and gives great advice!
cox049 is offline
Old 03-25-2004 | 06:24 PM
  #6859
InitialD's Avatar
Originally posted by KevinS
BUT, two universal joints at the same angle eliminate the sinus effect. The first one induces a sinus to the dogbone, the second one creates a sinus with a difference of half a phase, evening it out for the wheelaxle. If you replace one universal joint by a CVD, the sinus effect of the first universal will not be evened out.
Are you referring to the effect of the Ackerman angle (difference between the outside and inside wheel angle) on using the UJ / dogbone? Due to this effect, the outside wheel will have less angle and hence the loss of input speed is lower?
So in other words; If it's a CVD I don't want it!
(If it's a universal and 3racings usual quality I don't want it either)
Thanks Kevin for the excellent info. So from what you're saying in the sentence above is that you would neither want a CVD nor a UJ in your car?
On another note to Julius or somebody else, perhaps since the input speed of the driveshaft and the output speed on the wheelaxle is different, that is probably why the front of the 710 is slightly overdriven?
InitialD is offline
Old 03-25-2004 | 06:31 PM
  #6860
InitialD's Avatar
Originally posted by markp27
Jesus!! Your German is as bad as D's!
I don't need to know German. The use of the force (or rather Babelfish ) is enough for me !
InitialD is offline
Old 03-25-2004 | 08:29 PM
  #6861
Well I've tried everything on both the second and first gears and they still wobble. I'm just going to try and run them and see what happens? The worst thing that could happen is that the teeth strip and the gears are garbage. So either way they end up in the garbage!
The aluminum 2 speed clutch housing that goes inside the second gear also wobbles a little because of the 2 speed gear wobbling. That shouldn't affect how the 2 speed clutches ingage, should it? The shoes don't rub the housing right now, but there not adjusted yet either. Let me know what you think. Thanks.
SupermaxxRich is offline
Old 03-25-2004 | 09:00 PM
  #6862
cox049's Avatar
Default Supermaxx
How much wobble you got?
cox049 is offline
Old 03-25-2004 | 09:14 PM
  #6863
cyba888's Avatar
I had the same problem yesterday as well. Took it out while I was fixing my car and noticed it wobbled a bit. Tried to see what was wrong and couldnt see why it was wobbling so I just put it back again and it stip wobbling Mine wobbled only a bit so if yours is wobbling alot then you might have a defected part. Other than that dont sweat it and run it first. I dont think mine was damaged but it does have some kind of play when its not fully tighten with the e-clip im guessing. So for me im going to put the engine back on and just run it off the ground to see if it wobbles. I think you should just slap it on and see how if it really wobbles or not with the engine running. Hope this helps.
cyba888 is offline
Old 03-25-2004 | 09:17 PM
  #6864
Maxx, before you throw to garbage, try run it first.
You got nothing to loose.
I wont worry so much, since the spur is the one that having power and then rotating the shaft.
If your shaft is wobbling too thats a problem.
GoldFinger is offline
Old 03-25-2004 | 09:26 PM
  #6865
InitialD's Avatar
Perhaps your 2 speed shaft was assembled to have too much sideway lateral movement? Make sure that it has only very little side lateral movement. Loosen the 22T side pulley on the main 2 speed shaft and move it closer towards the bulkhead / chassis.
Most of the time, people assemble it tightly and with no side lateral play at all on the main shaft and causes the drive train to bind.
While you're doing this, make sure the 24T brake pulley does not rub or get in the way of the engine crankcase footing. Else, just remount it.
InitialD is offline
Old 03-25-2004 | 09:30 PM
  #6866
Well took another look at it and this is what I have come up with. The second gear runs perfect if I pull the 6x13 bearing out. As soon as I put it in, it starts wobbling again? The first gear on the one way still wobbles, quite a bit!!! I think I'm going to try and tweek it a little. Then I'm just going to try and run it and see what happens. If they strip then I'll just buy new ones. I'll let you know if I'm able to get rid of some of the wobble. Later...
Old 03-25-2004 | 09:31 PM
  #6867
InitialD's Avatar
Agreed. If your engine crankshaft wobbles, then it's a bigger problem !
InitialD is offline
Old 03-25-2004 | 09:37 PM
  #6868
Also guys, if you have a chance, please check out my question in the Nitro Engine forum. I started a new post. Thanks.
Old 03-25-2004 | 09:48 PM
  #6869
markp27's Avatar
Slightly off topic: does anyone know the dimensions of the Hudy shocks? Are they the same size or smaller than the Serpent ones - I'm wanting to try some out on my Surikarn if they fit.
Cheers, Mark.
markp27 is offline
Old 03-25-2004 | 09:53 PM
  #6870
Arun's Avatar
Originally posted by InitialD
For me, I suggest NOT to use the kit tires. Use your own tires 40 shore front and rear. It will eliminate the understeering with the stock setup. If it's still understeering (which I doubt), play with simple things such as shock angles and anti roll bar. You could make the rear shock more vertical (up one hole) for better turn in and stay with a harder rear antiroll bar setup for more front traction.
It has been the contrary here in Atlanta. Though I have gotten my car to work pretty well, I am still searching for more steering. As far as the "sweet spot" goes, the car was way off in the beginning with both straight axle and one-way configurations. I have raced twice with the car, and still have not gotten enough "set-up" time due to engine and radio problems. We all have been dealing with push problems with our new cars, but it is getting better.
One positive note...Even with the current problems, I have already turned faster lap times than I did with my 705.
Arun is offline
