Old 03-25-2004, 04:40 AM   #6826
BaxterC's Avatar
Do any of your guys know what is meant by 'degree' with regards to tyres. and how are Power tyres?
BaxterC is offline   Reply With Quote
Old 03-25-2004, 04:43 AM   #6827
InitialD's Avatar
Originally posted by KevinS
Anen't those 3racing... things... universals and not CVD's? There is a difference...
If so, what is the difference?
Old 03-25-2004, 04:46 AM   #6828
InitialD's Avatar
Power tires are quite good. They are from GRP family of tires.
Can you give an example of what number is associated with regards to the "degree" of the tire?
Old 03-25-2004, 04:57 AM   #6829
BaxterC's Avatar
This is what it looks like, it looks like shore,
Proline Nitro Shoes 26mm 35 DEGREE (0 OFF-SET)
What are proline nitro shoes like? I may just go for GQ, I know for you Dee, they dont last long. I am thinking of getting a body for Tower, maybe I will get tires too from them as RC-Mushroom dont have many.
Old 03-25-2004, 05:20 AM   #6830
markp27's Avatar
Send a message via ICQ to markp27
Never seen it exrpressed like this, but it must mean the shore of the tyre, i.e. the hardness rating.
markp27 is offline   Reply With Quote
Old 03-25-2004, 05:20 AM   #6831
BaxterC's Avatar
Mark and Dee... Have you noticed that rccarinternational have still not shipped my order? this is abnormal I am sure.
Old 03-25-2004, 05:26 AM   #6832
BaxterC's Avatar
Thank you, I thought as much... Have you got your order yet mark?
Old 03-25-2004, 05:47 AM   #6833
markp27's Avatar
Sometimes it does happen - they are normally quite quick. It depends upon what you order - if it is something which not a lot of people order then it takes a bit longer. I'm waiting for a light weight propellor shaft for my Surikarn (sorry for swearing ), which may take a while to get in stock.
Old 03-25-2004, 05:57 AM   #6834
BaxterC's Avatar
Oh right... I hope they are quick... I hope everything arrives at arounf the same sort of time as I would like to collect it all, but then I will need to get someone to help me with all the stuff...... LOTS OF BIG BOXES!!!
Old 03-25-2004, 06:07 AM   #6835
KevinS's Avatar
Standard dogbones are universal joints. A pin connects both wheelaxle and driveshaft. When there is an angle between the driveshaft and wheelaxle, the output speed is not the same as the input speed, but forms a sinus function with the input speed as the average. I think the 3racing joint is a universal joint, the only difference being that the dogbone is fixed inside the wheelaxle, so you don't lose your dogbone so easily.
A CVD (Constant Velocity Driveshaft) is constructed in a different manner to eliminate the difference in output speed. A good example is the homokinetic coupling thats used for driveshafts of most modern cars.
BUT, two universal joints at the same angle eliminate the sinus effect. The first one induces a sinus to the dogbone, the second one creates a sinus with a difference of half a phase, evening it out for the wheelaxle. If you replace one universal joint by a CVD, the sinus effect of the first universal will not be evened out.
So in other words; If it's a CVD I don't want it!
(If it's a universal and 3racings usual quality I don't want it either)
KevinS is offline   Reply With Quote
Old 03-25-2004, 06:21 AM   #6836
BaxterC's Avatar
I know what you mean although you lost me when you started talking about an allergy (sinus). I must just say that a dogbone has a lot more friction because the pins 'rub' in the cups but with a 'universal' has les as it runs on an axis with an axel and another axis with an axel at 90 degrees. if you understand what I am saying. A FWD car has CV Joints or I would imagine CVDs, if they work for big cars, why not for little cars... Dont get me wrong... if it isn't made by serpent, it isn't made for me. If serpent releases CVDs, I will look at them, but till then, I will not.
Old 03-25-2004, 06:36 AM   #6837
BaxterC's Avatar
I could not find a decent picture of a CV or a CVD, but here is a universal, I mush more efficient joint if you ask me...
Old 03-25-2004, 06:39 AM   #6838
KevinS's Avatar
Err... sinus... Don't know if thats the right word in English. It's the sin function on a calculator. (sin, cos, tan)
www.freetranslation.com isn't helping either!
Old 03-25-2004, 06:44 AM   #6839
BaxterC's Avatar
OH, I see what you mean... SIN. Try this site for an explanation.
http://www.me.metu.edu.tr/me308/usefulinf.htm
It is slow but looks interesting
Old 03-25-2004, 06:53 AM   #6840
BaxterC's Avatar
Meiner 710 werden schnell sein.. Dee kann schneller tippen und dies ist nur ein kleiner Witz für Mark oder irgendjemand sonst, der Deutsch lesen kann..
Sorry...
Here is a better pic...
