Serpent 710
Old 03-25-2004 | 10:14 PM
  #6871
InitialD's Avatar
Originally posted by Proficar403
One positive note...Even with the current problems, I have already turned faster lap times than I did with my 705.
Cool. I guess the box setup understeers a little and more so with the kit tires. I used my tried and tested Speedmind tires (40 shore rear and front), the car hooked up pretty well on the track with stock settings.
From the setups on mytsn by team Serpent drivers, I noticed that they are trying to make the rear end stiffer and the front end loose. I believe the rear end has too much grip which makes for much understeering of the car.
InitialD is offline
Old 03-25-2004 | 10:19 PM
  #6872
markp27's Avatar
Default 710 FAQ
Latest FAQ post. Nothing much new, just a couple of cosmetic changes + some flying tips from Julius
File Type: pdf
markp27 is offline
Old 03-25-2004 | 10:24 PM
  #6873
InitialD's Avatar
Default Re: 710 FAQ
Congrats Mark. What better day than today to have come across that 1000th post ! Look forward to 1000 more.
InitialD is offline
Old 03-25-2004 | 10:26 PM
  #6874
markp27's Avatar
Default Re: Re: 710 FAQ
COOOOOOLLLLLLL!!!!
I hadn't even noticed! Thanks for the congrats I'm catching you, I'm sure I'm catching you
Accept the FAQ as a gift to celebrate my 1000th posting
markp27 is offline
Old 03-25-2004 | 10:52 PM
  #6875
InitialD's Avatar
Default Re: Re: Re: 710 FAQ
You wish !
I'll give you a tip ! No sleeping throughout the night !
InitialD is offline
Old 03-25-2004 | 11:01 PM
  #6876
Marcos.J's Avatar
Super Moderator
Default InitialD
Hey InitialD : hopefully i will be racing at this track this weekend w&w permitting (wife & work)
( Photos taken by Jarrod Pilone www.jpsportspics.com)
Marcos.J is offline
Old 03-25-2004 | 11:02 PM
  #6877
InitialD's Avatar
Mark, I took a look the first time the FAQ was rearranged and I must say that you did one hell of an impressive job !
One additional note... Does PDF allow active links to be made so that one just has to click the link to get the browser to come out? Also, run the doc through a spell checker ! Not obvious mistakes just minor spelling errors from typing.
InitialD is offline
Old 03-25-2004 | 11:11 PM
  #6878
hudy's Avatar
Suspended
Hi guys i have a question for all the 710 owners Im thinking of buying this car I currently race an MTX-3
I would like to know if this kit is hard to assemble by that I mean the rear diff centax and the front bulkhead.
I was also told that this car is extremely underweight due to the plastic being hollow and weaker than previous models back.
What are your guys opinion on RB engines? What engines do you guys run on your 710's
thx
hudy is offline
Old 03-25-2004 | 11:12 PM
  #6879
markp27's Avatar
Thanks Used the best Doc tool you get pinch, I mean, buy Framemaker (creatively on the MAC of course )
I've got this one in mind, I'm looking into it to see which options I need to set.
I'll be going through the doc to check for grammar and spelling mistakes on one of those rainy Sunday afternoons which come around so often
The FAQ has become pretty static now, so there isn't too much work left to do.
I think I may a of section, like "don't waste your money on Ti Screws, they only save you 10 gramms"
Cheers, Mark.
markp27 is offline
Old 03-25-2004 | 11:16 PM
  #6880
markp27's Avatar
thx
Hollow plastic!!! Extremely underweight!! Hmm, some pretty strange rumours going around. No hollow plastic on my 710 and it is still the legal side of the weight allowence.
The kit is very easy to build, especially if you follow the extra tips given in the FAQ document which I just posted a couple of messages ago.
As for the details of Centax building, I'll let the others answer this one, as I'm still waiting for my Engine!
From my experience, the car went together without any problems and took hardly any time. I was very impressed!!!
Cheers, Mark.
markp27 is offline
Old 03-25-2004 | 11:18 PM
  #6881
markp27's Avatar
Default Re: InitialD
Half the track's missing!
The infield section looks really good!!
Hmm, I think I'm going to have to add a Wife/Girlfriend section to the FAQ - tips and excuses
markp27 is offline
Old 03-25-2004 | 11:26 PM
  #6882
hudy's Avatar
Suspended
what do you guys think of RB engines?
hudy is offline
Old 03-25-2004 | 11:40 PM
  #6883
BaxterC's Avatar
I AM PLACING MY ORDER TODAY!!! I cant wait... I will post what I ordered once I click on the 'confirm' button. As to engines we run... They are all 0.12 high end motors, as the serpent 710 is a race bred car and it would be stoopid to install a weak motor in it.
Anyways... Guys check out the 'extreme modification' thread as there are some interresting things going on
BaxterC is offline
Old 03-26-2004 | 12:01 AM
  #6884
Well, for the first time I actually put it all together with the clip on the end of the shaft. Then I loosened the brake hex set screw and drive belt pulley set screw and took all the slack out of the shaft so that the gears wouldn't move back and forth(took all the slack out but didn't preload the bearings ) That seemed to get rid of most of the wobble with the second gear. Now its pretty good, just a small amount of wobble. The first gear still wobbles but has play with the oneway bearing and the shaft wich allows the first gear to move around a bit. I can actually get it to run true by pushing the first gear with my finger. So I think once the engine is actually running that the gears will straighten right out.
I guess I'll just have to wait and see once I get her up and running? But I think it will be OK.
The reason I think the second gear wobbles so much when it doesn't have something pushing against it is that the 6x13 bearing fits loosely into the gear. I could tell the gear had some machining issues where the bearings go into. Thanks guys for everything. Now its time to install the engine and then go to bed! Its 12 AM and I have to get up and 5:30AM!!!!! Later...
SupermaxxRich is offline
Old 03-26-2004 | 12:19 AM
  #6885
border r/c's Avatar
Default universal joints ore cvd
just take a look too this
http://shop.the-border.nl/customer/p...420&cat=&page=
we did test them on the car absolute good no wear at all
border r/c is offline
