Serpent 710
Old 03-16-2004 | 02:09 PM
  #6121
Marcos.J's Avatar
Super Moderator
Originally posted by sparksy
Its because the picture Marcos.S710 posted are too big.
oops !! sorry
Marcos.J is offline
Old 03-16-2004 | 04:27 PM
  #6122
Sow&Steady's Avatar
Default Re: Building and Adjusting Carb/Brake Linkages
Originally posted by GlennCauley
For anyone who is interested, I wrote a column on myTSN about the way that I built the carb/brake linkages on my S710.
The URL is:
http://www.mytsn.com/publ/publ.asp?pid=9742
Glenn Cauley
Ottawa, Canada
Glen, an excellent article. Write more please!
Sow&Steady is offline
Old 03-16-2004 | 06:06 PM
  #6123
InitialD's Avatar
Default Re: Clutch Question
Originally posted by Profoxcg
I want to know this, the tighter the spring nut the sooner the clucth will engage ? or it is the other way around.
I am refereing to the 1.0mm adjustments that the instructions mention. If i make that distance 1.5mm will my clutch be more responsive?
currently I have to give the car alot of gas for it to move..
It's the other way around. You need to loosen the spring pre-tension nut to get it to engage early.
If you have to give a lot of gas to get the clutch to engage, then making the distance to 1.5 mm would be worse off.
Of course, the tighter the spring, the harder the clutch shoe engages onto the clutchbell but there is of course a limit to this. The adverse effects when the clutch spring set too tight would be the clutch slipping and too high engage point.
InitialD is offline
  #6124
InitialD's Avatar
Default Re: Re: Re: question for InitialD
Originally posted by Marcos.S710
with the above suggestion do i still used the yellow springs or the red springs?
For high traction tracks, I would go with red. Else, stick with the stock. Well, you could try it if you want and see if you like the way the car handles.
InitialD is offline
Old 03-16-2004 | 06:07 PM
  #6125
InitialD's Avatar
does the r40 have this problem? (Centax problem in genral? )
Any car when the Centax clutch not set correct would have problems. Any car when the thrust bearing of the Centax clutch not set correct would blow out.
BTW, it also depends from one engine to another and the pipe / manifold combo. This is why the 1.0 mm setting in the manual is just a starting point for you to tune and it is not the be-all-and-end-all setting.
InitialD is offline
  #6126
InitialD's Avatar
Bacter, you said that the silver spring is harder, so i will take it back then. so it is probably a matter of setting the spring nut far enough so that my engine engages...
Don't get me wrong... You can still use the harder silver spring. You just probably need to loosen the Centax pre-tension nut more. I know Julius uses the harder Centax spring...
InitialD is offline
Old 03-16-2004 | 06:08 PM
  #6127
InitialD's Avatar
Originally posted by cyba888
Are the new 710 kits out yet, the ones with the thicker shock tower. If so where can I get one online?
Why do you want to get it online when you can get it cheaper at your LHS?
Just get the LHS to open the box for you and you can check to see if the shock tower is already updated !
InitialD is offline
Old 03-16-2004 | 06:09 PM
  #6128
InitialD's Avatar
Default Re: driver stand
Hey InitialD,this the new drivers stand that we built at our track!
Macros, man that's a cool track ! Keep winning on it !
InitialD is offline
  #6129
InitialD's Avatar
Default Re: 2nd gear mod
I solved this problem by widening the 3 slots in the plastic 2nd gear. By default, the slots are roughly 3mm wide... I widened them an extra 2mm... just enough so the entire hole in the alu cage is visible through the slots when viewed straight on.
There was some talk some time back regarding difficulty to even access the 2 speed screws externally. Your idea will come in handy on my next mod adventures.
InitialD is offline
Old 03-16-2004 | 06:14 PM
  #6130
cox049's Avatar
Unhappy electric wires routing
Can anyone post pics of how to neatly route the servos and battery/ switch wiring?
I'm messy with wires... and last time a broken battery wire almost cost me an engine
cox049 is offline
Old 03-16-2004 | 07:00 PM
  #6131
InitialD's Avatar
Default Re: electric wires routing
This was posted by Rene Cornella some time back.
InitialD is offline
Old 03-16-2004 | 07:02 PM
  #6132
cyba888's Avatar
I have my parents credit card to use thats why
cyba888 is offline
Old 03-16-2004 | 07:05 PM
  #6133
Thumbs up clutch responsiveness
so how responsive can I get the clutch... ?
Profoxcg is offline
Old 03-16-2004 | 07:08 PM
  #6134
InitialD's Avatar
Default Re: clutch responsiveness
That's a very generic question ! It's almost the same as asking how rich I can get !
InitialD is offline
Old 03-16-2004 | 07:16 PM
  #6135
Mark, pls update your FAQ book.
Put on the section, " Cheapest way to build 710 " (Cyba, its a j/k)
GoldFinger is offline
