Serpent 710
Old 01-30-2004 | 07:25 AM
  #3721
Pit-racer's Avatar
Originally posted by Doug Darby
Yeah.. too neat.. I am almost embarrassed by it. I got rained out racing last Saturday, and as All the cars were ready, and packed for racing I dedided to spend about 5 hours cleaning shop. What you see is the result.
STOP! STOP! I can't take it anymore......I want that shop!
Pit-racer is offline
Old 01-30-2004 | 07:31 AM
  #3722
Pit-racer's Avatar
I did try rotating the cam through about 120 degrees in about 4 different steps and it didn't seem to make any difference. But I think you are on to something here and I will try starting with no sway bar and then working the cam again to see what I find.
I have the same problem and did everything you mentioned and tried
Old 01-30-2004 | 07:35 AM
  #3723
markp27's Avatar
Default Re: Re: Re: Tweak boards
Originally posted by Julius
The problem with a tweak board is that both sides of the car
are "hanging in the springs".
Now the car is perfect on the tweak board with the rear end in the
fixed part. Now turn the left rear shock collar harder. This will make
the chassis roll to the right. As up front nothing has changed the
movable beam will roll to the right as well, thus showing tweak.
Now turn the left front spring harder and the movable part will roll
back to the left. No tweak but not a perfect chassis...
Just try it.
Now I see what you mean! Hmm, interesting.
I have a slightly off topic question: With my Tamiya Surikarn, most of the weight (due to the battery arrangement) is on the left hand side of the car. I tweak the car so that the tweak station shows that both sides are balanced, but looking at the chassis, I see one side higher than the other, due to the greater weight of the batteries.
This is also relevant for those who haven't got a prefect left-right weight distribution, which without the addition of some weight to the car, is normally the case.
Am I tweaking my electric car incorrectly?
Cheers, Mark.
markp27 is offline
Old 01-30-2004 | 07:39 AM
  #3724
Julius's Avatar
Default Re: Re: Re: Re: Tweak boards
Cheers, Mark.
For any all wheel independant suspension car the tweak board is not handy because of the reasons in my earlier posts. A tweak board is handy on pan (solid rear axle) cars.
Also on your electric you can use the pick it up in the middle technique.
Julius is offline
Old 01-30-2004 | 07:41 AM
  #3725
markp27's Avatar
Default Re: tweak boards
There is a way to use a tweak board come to think of it. You'd need to set the chassis on the fixed beam. That way you'd have a flat and fixed reference. You need a non worn chassis though.
I probably do this as my step one when tweaking. At first I isolate the front by placing a Hudy Block under the rear of the chassis. The front wheels are on the swing-bar and I adjust the front tension until the front is balance. Then I swap ends and do the back (with the Hudy Block under the front).
After doing this, I then remove the Hudy Block and adjust the tweak for the front and rear once more.
And finally, I connect the sway bars and adjust their length (or the cam thing) until the tweak is once more level.
Do you mean, that it would be better to always tweak with the block underneath one end of the car?
Cheers, Mark.
markp27 is offline
Old 01-30-2004 | 07:43 AM
  #3726
Pyramid's Avatar
Registered User
It's absolutely true... I guess thats way the laser tweak station would never be a hot item, buble one still more self convidenced and make us more to believe But I prefer without it
Another note: have not done any maintenance on my S710 since its first race meeting (with some practices and engine tuning) except... cleanning the car and engine that takes about 30 minutes top (include removing the upper deck). Everything still turns smoothly. This is what I called a FUN SPORT Will inspect on all moving parts after the upcoming second race and see how forgiving it is on maintenance.
Pyramid is offline
Old 01-30-2004 | 07:46 AM
  #3727
Diesel Racer's Avatar
Default 710
Yiiiiiiipppppeeeeeeeeeeeeee! My 710 has just arrived.
What would you guys recommend out of the following servos for steering duties.
KoPropo PS-2113 FET or PS-2123 Digital.
Futaba 9402 or S9350
Sanwa ERG-VB or ERG-VR.
I fancied the Sanwa ERG-VB, but been advised that it may be a bit overkill on the 1/10th, my LHS is selling all these around the same price bracket.
Cheers Guys
Diesel Racer is offline
Old 01-30-2004 | 07:50 AM
  #3728
Pyramid's Avatar
Registered User
I never have luck either with KO or Sanwa servos, they all seems to generate noise which make it always unsteady (I tried until 2123/43 and ERG-WR I believe and it was on my electric cars).. I would always go with Futaba
Pyramid is offline
Old 01-30-2004 | 07:58 AM
  #3729
cyba888's Avatar
Default Re: 710
Cheers Guys
Get the Sanwa WRX Its suppose to be the fastest speed contoller Thats what im using on my 710
cyba888 is offline
Old 01-30-2004 | 08:00 AM
  #3730
Sow&Steady's Avatar
Ehm You're right But I don't touch anything to do with MS! WAIT, I didn't mean Lord MS
Greetings from your Windows free zone!
Welcome to the club mark! I'll MacOS X, I'll do Jaguar, I'll do Linux and anything else to keep me away from windooooze except of course, on the work machine
Since the machine at work is free .. . I can't complain too much
Sow&Steady is offline
Old 01-30-2004 | 08:03 AM
  #3731
Sow&Steady's Avatar
A shot of my RC shop for grins...
Now ... that's what I'd call a "liteweight" workshop!
  #3732
markp27's Avatar
Default Re: Re: Re: Re: Re: Tweak boards
Thought about this a little more and please correct me if I'm wrong:
If I first of all tweak the front and rear by placing the Hudy Block underneath the opposite end of the car to which I'm tweaking, I will know that the front and rear are independantly tweaked, and I can be sure that when the right front is too lightly loaded, then I must create more tension on the left rear and less on the right rear. i.e. I would have a known starting point and would end up with a balanced car??
Would this not work as well as the lifting method?
Cheers, Mark.
markp27 is offline
Old 01-30-2004 | 08:05 AM
  #3733
markp27's Avatar
Keep the faith brother
Well in my Computer Centre here at home, I've got two Sun Ultras, two Linux XPs and two Mac laptops - bliss
A mixture for my photo work and my programming work.
Cheers, Mark.
markp27 is offline
Old 01-30-2004 | 08:10 AM
  #3734
Sow&Steady's Avatar
Default Re: 802370 Front ball diff
Originally posted by border r/c
just too let you know:
for all of you who are waiting on it were shipping them out the
1 february !
I couldn't find the item on your site!
Old 01-30-2004 | 08:14 AM
  #3735
Sow&Steady's Avatar
Julius, I must say ... I'm confused!
By fixed beam, you mean the rear beam of say ... the Speedmind Tweak Station?
I think that's what is meant to do isn't it?
