Serpent 710
Old 05-24-2004 | 08:35 PM
  #11221
InitialD's Avatar
Originally posted by GoldFinger
No grease.
I just clean it before final run, since im not using the diff cover.
Nothing to replace.
Hey bro, better to put a coat of grease in there. Less wear on the plates.
InitialD is offline
Old 05-24-2004 | 08:38 PM
  #11222
InitialD's Avatar
I felt that too, with thicker shock oil the car tends to handle better and better when you raise the tire shore. But in full throttle sweeper the car bit "nervous"(Inside front tire having on/off ground).
Julius mentioned that with thicker shock oil, weight transfer happens slower. I guess your sweeper is a little bumpy? Allowing a little more droop in the front might help.
InitialD is offline
Old 05-24-2004 | 09:07 PM
  #11223
Pyramid's Avatar
Registered User
Originally posted by InitialD
You mean World Model in HK is organising another Serpent Asia challenge in HK this year? Is this confirmed already?
No, it is their own series, not Serpent Asia Challenge.
Pyramid is offline
Old 05-24-2004 | 09:13 PM
  #11224
Pyramid's Avatar
Registered User
[B]Woow ! The UBO / LT combo is the 2nd highest rear roll center setting !/B]
Yes, the one use by Julius (because of that less camber change on roll) is about 25% less rear tracktion without changing anything else as I used it for the first setup.
Pyramid is offline
Old 05-24-2004 | 09:21 PM
  #11225
Pyramid's Avatar
Registered User
Looks like Sir KHM lay off a little now.. newer novamega is `MS` being introduce and the new 2804 KHM EV6 has been discontiniued before its release.. what`s up with that??
Pyramid is offline
Old 05-24-2004 | 09:43 PM
  #11226
BaxterC's Avatar
Default Re: Re: Re: Sow's video
Originally posted by markp27
Listen to Fleetwood Mac's "The Chain" - the second half of the song was the BBC's Anthem for all F1 Grand Prix races from the late seventies until ITV took the races away from them Great song and the second part of the song fits totally with F1 racing
HEY HEY, i will do that... Thanks
BaxterC is offline
Old 05-24-2004 | 09:54 PM
  #11227
markp27's Avatar
Default Re: Re: Re: Re: Re: Re: Tight track engine
Well, I don't know where that originally came from but I know that it's an old English expression.
Just a small correction though "Birds of a feather flock together"
markp27 is offline
Old 05-24-2004 | 10:02 PM
  #11228
BaxterC's Avatar
Originally posted by Herbie
Well it is bought the kit saturdaymorning and ran it sunday afternoon for about 6 tanks. Ruined a new motor 'cause it was so much fun driving the car I forgot I was breaking in the engine
Herbie, remember that to break in an engine, you should be doing it fast. It will give you a great FAST engine. but remember to heat cycle it. you should be ok though.
BaxterC is offline
Old 05-24-2004 | 10:04 PM
  #11229
BaxterC's Avatar
Is your engine really dead? Mine's looking a lot better now - I just need a new glow plug and then I can do a quick check to see if everything is running ok.
Did you fix your engine? What did you replace?
BaxterC is offline
Old 05-24-2004 | 10:10 PM
  #11230
markp27's Avatar
Crankshaft and conrod - everything else seems AOK - the sleave is still tight, so the engine is bearly broken in. Just need to get a glow plug - as I forgot to order a spare one - one is on its way.
markp27 is offline
Old 05-24-2004 | 10:13 PM
  #11231
BaxterC's Avatar
Originally posted by KevinS
Ey... Baanbrekers. I know that track from a game!
Maybe a good tip for everyone; if you want to virtually drive on 5 Dutch tracks, including MACH, go to www.bigscaleracing.com and order the game.
You can also download the demo which features only one track, which is the track closest to where I live. One drawback... you'll be driving those sluggish lawnmowers.
Oh and another thing... I may be getting my hands on a MTX-3 soon. Does anyone want to buy it for $55?
I will give you 60$ if it has an engine. I need a backyard basher.
BaxterC is offline
Old 05-24-2004 | 10:23 PM
  #11232
Marcos.J's Avatar
Super Moderator
Originally posted by rwisejr
Hey Marcos like I said the little snoot nose can't drive so when he crashes its the cars fault. he needs a car with auto pilot or atleast child Proof
Marcos.J is offline
Old 05-24-2004 | 10:39 PM
  #11233
BaxterC's Avatar
WOW, that was lucky. wasnt the piston hectically scored? and the sleave? I suppose if it isnt too bad you can still run it till it says NO MORE!!!
BaxterC is offline
Old 05-24-2004 | 10:46 PM
  #11234
markp27's Avatar
Fortunately, the big pieces of metal stayed in the bottom of the engine and only damaged parts of the casing - shouldn't affect the engine much.
The piston land sleave looked like they had small scratches on them, but I think this was more the brass colouring from the sleave due to the run-in cycle.
I just need to get it fired up on the bench and then see how it behaves.
markp27 is offline
Old 05-24-2004 | 11:11 PM
  #11235
BaxterC's Avatar
I think it should be fine then. How were the bearings? I am sure that f you run it, it should be ok... better than buying a new engine 'ey
BaxterC is offline
