Old 05-24-2004, 04:40 PM   #11206
rwisejr's Avatar
Send a message via AIM to rwisejr
Thumbs up
Originally posted by Herbie
Dont know excactly but it's a nova rossi and it's efra legal. I only see a art.number and a batchnumber on the box.
Art. 52604
go to the following site and see for yourself by the exhausts
http://www.novarossi.it/index_ing.html
Ok great thanks .I have one of those on and impulse pro.It is a great pipe.
rwisejr is offline   Reply With Quote
Old 05-24-2004, 06:35 PM   #11207
biker's Avatar
Hey guys,
I know this is a 710 forum...but I figured I'd ask anyways..
Do any of you know if parts are still available for the impulse? If so, where is the best place to obtain them?
Thanks for your help
biker is offline   Reply With Quote
Old 05-24-2004, 07:32 PM   #11208
InitialD's Avatar
Should be available. I think it just depends on whether your LHS would want to make an order for them...
Where are you at?
Old 05-24-2004, 07:34 PM   #11209
rwisejr's Avatar
Thumbs up
Hey guys,
Yes they should be most of the parts are the same for the 705. I usually order from serpent or my local shops for serpent parts. But there should be a few online hobby shops as well . I have a 710 and 2 impulse pros.
Old 05-24-2004, 07:42 PM   #11210
Wap
out of town for 5 days i think i have 13 pages to read i like reading all the pages just not all at once
Wap is offline   Reply With Quote
Old 05-24-2004, 07:49 PM   #11211
biker's Avatar
..thanks for the info guys...
Old 05-24-2004, 08:13 PM   #11212
rwisejr's Avatar
Talking
No problem thats what this hobby is about .Helping one another.
Old 05-24-2004, 08:15 PM   #11213
KevinS's Avatar
Oops forgot the picture sorry
Ey... Baanbrekers. I know that track from a game!
Maybe a good tip for everyone; if you want to virtually drive on 5 Dutch tracks, including MACH, go to www.bigscaleracing.com and order the game.
You can also download the demo which features only one track, which is the track closest to where I live. One drawback... you'll be driving those sluggish lawnmowers.
Oh and another thing... I may be getting my hands on a MTX-3 soon. Does anyone want to buy it for $55?
KevinS is offline   Reply With Quote
Old 05-24-2004, 08:18 PM   #11214
Originally posted by InitialD
Cool. So putting each flyweight with 2 set screws (at the end of both sides of the tip??), you need to put 6 set screws in total right?
Yepp
Woow ! The UBO / LT combo is the 2nd highest rear roll center setting !
What did you have found ?
Please share lah...
Another goodie? Are they much lighter? I think the standard one is already durable as it is.
Lighter ? almost half from the steel ones.
The steel ball scratch the plate badly. This ceramic balls is like making a groove instead scratch the plates and it keep polishing by itself.
GoldFinger is offline   Reply With Quote
Old 05-24-2004, 08:23 PM   #11215
Default Re: Re: Re: Re: Tight track engine
Birds of the same feather flock together !
Where do you get this statement ?
Seems very familiar for me...
Is it from Mr "Bob Andrew" ? the CROWN A. ?
Just curious...
Old 05-24-2004, 08:28 PM   #11216
InitialD's Avatar
If it was a snake, I would say "get back in line ". If it's the MTX-3, then I will say, "go ahead, be my guess ".
Old 05-24-2004, 08:41 PM   #11217
InitialD's Avatar
Please share lah...
Well, I haven't tried playing so much with the rear roll center. I'm currently running UTI / LT and front with the highest roll center setting (0 mm shim under front upper arm). Just one step lower rear RC than what you're using. With a front diff, I found that very nice steering around the corners. I thought that the rear of the car would skate around because of the high rear RC. Coupled with a harder rear spring, very nice on throttle steering.
Crashed_1 likes the stock rear roll center (UBI / LB) with the stock 2 mm shim under the front upper arm. That is with front diff. I believe with oneway, the stock rear RC is very nice to drive with. Very stable.
I don't know if this is related but I tried yellow springs front and red rear with 50wt Serpent shock oil and 5x1.2mm piston holes all around. I tried with 42 shore tires all around on our track and it was driveable. Not bad. I went on to try 40wt Serpent shock oil and 4x1.2mm piston holes all around with yellow springs front and back and I thought it was a tad better with 42 shore tires. Need more time to test !
Cool. What grease are you using on the balls? On mine, the scratch on the plate is very minimal. Nothing a good polishing will not get it off. Still very smooth like new.
I hope that using the ceramic balls would not make it turn out like running the NTC3 where you need to change the diff plates on the ball diffs often because of wear...
Old 05-24-2004, 08:43 PM   #11218
InitialD's Avatar
Default Re: Re: Re: Re: Re: Tight track engine
Just curious...
Well, I don't know where that originally came from but I know that it's an old English expression.
Old 05-24-2004, 08:51 PM   #11219
jfc_tech's Avatar
Send a message via Yahoo to jfc_tech
Default Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Tight track engine
Originally posted by Sow&Steady
Ah! Meister in online ...!
Go on then, go here now.
Everyone else welcomed to try too. Just type in a nickname and click chat
The chatroom intro is in Bahasa malaysia??
I almost got lost there....forgotten what is "katalaluan"...end up looking thru dictionary...="password"
i was in at 10:45am...alone
If you are in front of me, That's because I let you!
jfc_tech is offline   Reply With Quote
Old 05-24-2004, 09:20 PM   #11220
I felt that too, with thicker shock oil the car tends to handle better and better when you raise the tire shore. But in full throttle sweeper the car bit "nervous"(Inside front tire having on/off ground).
It is best shock setup for twisty (high traction)track where is so much slow hair pin.
No grease.
I just clean it before final run, since im not using the diff cover.
Nothing to replace.
