Old 06-18-2004, 12:40 PM   #12721
YANMAN's Avatar
Trader Rating: 39 (100%+)
Smile
[QUOTE]
Rubber tire set up
Does anyone have a good rubber tire set up for the 710? I am going to a track out of town and they only run rubber tires.
Thanks,
Tim
Has anyone run this car with Rubber Tires? I guess I will start with the stock set up and go from there.
YANMAN is offline   Reply With Quote
Old 06-18-2004, 12:57 PM   #12722
set up
Have u been to my tsn they have set up sheets for every thing
wolfeman is offline   Reply With Quote
Old 06-18-2004, 02:50 PM   #12723
why does it take so long for people to reply on this web sight
Old 06-18-2004, 03:08 PM   #12724
mariochi's Avatar
Originally posted by InitialD
Did you swap in the yellow spring all around WITHOUT changing the 50wt Serpent shock oil or did you use the yellow springs with Serpent 30wt shock oil?
Ola Mr.D
Yesterday my time was very little so :
50W oil - yellow spring all around with a bit of pre-load
BUT tha car was not costant (sometimes has a too much grip,another time , when you push hard suddenly loose some traction ) especially (BAD) in the 2 on-throttle sweeper (as you saied)
Bye
mariochi is offline   Reply With Quote
Old 06-18-2004, 03:13 PM   #12725
mariochi's Avatar
Default Re: Re: Re: Re: ATTENTION: TRACTION ROLL...Help!Help!
I don't know about anybody else but don't you think -4 and -3 for the FRONT camber is a little too excessive? Try 200 mm front trackwidth.
I would also try softer shocks all round (yellow springs with Serpent 30wt oil with 4 or 5 holes) like what Proficar403 advised but use the sway bar to tune and harden the front end to your liking. Works for me.
-3 and -4 is not excessive on my truck.
The front tires worn flat -flat-flat
but i will think about it.
Actually I have 199mm. front width
Mr.D.... Do you think that 200 mm. front trkwidth is too dangerous for losing front dogbones?
I have standard dogbones.I don't want to change with other types
Old 06-18-2004, 03:23 PM   #12726
Thumbs up sweay bar
Is it bad to have to much move ment in your sway bar
My father and I took a little pant off of the sway bar because it was binding and now we have to much move ment in the sway bar
Old 06-18-2004, 03:58 PM   #12727
Blue Sky's Avatar
Send a message via Yahoo to Blue Sky
Just a quick question on engines and plugs. Can you use an OS plug in a Novarossi engine? I have quite a few OS8 but I don't run an OS engine anymore. Thanks.
Blue Sky is offline   Reply With Quote
Old 06-18-2004, 04:14 PM   #12728
Arun's Avatar
I believe the OS8 is a short plug. I believe Novarossi's only work correctly with long plugs.
http://nexusracing.com
Arun is offline   Reply With Quote
Old 06-18-2004, 04:16 PM   #12729
FW-05RR's Avatar
Originally posted by Wap
where are u getting the nova meag i assume it is the 2106. I have been looking for it awhile
actually im getting the 2107MS its the 5 port instead of the 3 port they currently have 3 in stock at my LHS
FW-05RR is offline   Reply With Quote
Old 06-18-2004, 04:19 PM   #12730
Sow&Steady's Avatar
Depends on whether you're talking about turbo or standard plugs.
I think standard plugs are easily interchangeable but turbo ones are not quite so.
http://3hobby.net REVISITED V2 - Its on steroids!
https://www.facebook.com/ssteady
Sow&Steady is offline   Reply With Quote
Old 06-18-2004, 04:20 PM   #12731
Sow&Steady's Avatar
Default Re: sweay bar
You mean you shaved off from the ball of the front sway-bar?
Old 06-18-2004, 07:41 PM   #12732
Trader Rating: 2 (75%+)
You shouldn't have to grind down the male (ball-end) part for the sway bar to get movement out of it!!
It just need to barley go inside that female (cup) part.........you probably had it to far in were it wasn't moving to freely.
PUNISHER is offline   Reply With Quote
Old 06-18-2004, 07:47 PM   #12733
Originally posted by YANMAN
Rubber tire set up
Thanks,
Tim
Hey Tim!
Yea, just try to go with the base set-up and then go from there for rubber tires.
Why aren't you racing this month SWS race!?!?
Hope to see ya at the track soon!
Mike
Old 06-18-2004, 08:48 PM   #12734
jfc_tech's Avatar
Send a message via Yahoo to jfc_tech
Hey, how's the baby? Hopefully you don't put baby stuff on the car and vice versa.
Well, thanks for asking, D
The baby is fine and healthy eventhough he has gone thru his 1st. 2 weeks in the NICU and the ENT OT(Operation Theatre) but he's ok now. thanks for asking.
about the car stuff...actually why i opened up everything is becoz, according to my Kadazan culture thing(whenever the baby got some problems), i need to wipe him with everything i play with during my wife's 9 month pregnant. so obviously my 710 kit need some wiping for him. believe it or not, it works. my baby is fine, healthy and love nitro sounds(i always hold him in front of the tv when i watch rc race videos )
sorry for the long explaination...my fault, i love 710 and my baby.
If you are in front of me, That's because I let you!
jfc_tech is offline   Reply With Quote
Old 06-19-2004, 12:59 AM   #12735
BIBOY's Avatar
Send a message via Yahoo to BIBOY
Default where can i buy?
where can i buy whole set of ceramic bearings (including diff) for 710?
R1 Wurks
Xray
RC America
Reds Racing Engines
Rctarget
BIBOY is offline   Reply With Quote
