Serpent 710
Old 05-09-2005 | 08:07 AM
  #21376
Pyramid's Avatar
Registered User
Originally posted by Sow&Steady
Yup, mine is being installed this week too (gotta work on it in the evenings if 3hobby doesn't take up too much time!).
You'll find a time Bro!
'One' other thing must be done/revised also for this chassis.. The receiver cover! must be place higher by at least 0.85mm (assuming brother Marks info on 1.85mm lowered) to clear the ground when cornering. Especially for racers with R133ip futaba receiver.
Last but not least, the pic marks posted, does not look like the hole for sterring post arms being lowered as well while the mid braket is. So if upper deck is lowered, how do you put the alu steering post in without the hole being lowered by the same amount? Mark, did you do photoshoping again?
Pyramid is offline
Old 05-09-2005 | 08:27 AM
  #21377
crashed_1's Avatar
Default Re: New Chassis
Originally posted by markp27
Here it is folks - looks very nice - will be changing my chassis over this week.
Cheers, Mark.
Now I know who has "THE R I N G"!!!
crashed_1 is offline
Old 05-09-2005 | 09:18 AM
  #21378
markp27's Avatar
Me, photoshop never heard of it
Just checking my measurements and to explain more clearly, the milled out sections of the chassis are 1.1mm except for the channel for the belt which is 0.5mm lower. So the rx unit will sit 1.1mm lower than normal.
The hole for the steering post is also milled out by 1.1mm.
Cheers, Mark.
markp27 is offline
Old 05-09-2005 | 09:21 AM
  #21379
markp27's Avatar
Default Re: Re: New Chassis
There is only one true ring and I know who has it My fake ring is just a little better than the fakes you guys have
markp27 is offline
Old 05-09-2005 | 05:20 PM
  #21380
JustRace's Avatar
Cheers, Mark.
What's the odds of sending your pit monkey one for his birthday or christmas!!! Mark...good thing you don't have a wife that's watching your spending
Let us know if it gets you into the Salven zone
JustRace is offline
Old 05-09-2005 | 05:51 PM
  #21381
Cheers, Mark.
nice chassis mark
ntc3freak is offline
Old 05-10-2005 | 07:12 AM
  #21382
Hi everyone,
this is my recommended starting set-up for royal palm in Miami. 37 shore all around
2.5 rear sway bat, all soft inner holes
front sway bar full stiff
drop 0-front 7-rear
default roll center
minus 1 front toe
plus 3 rear toe
front one way
rear diff-medium hard
35wt oil all around 3 holes
yellow front springs
red rear springs
cadi body, a must have for this track, wing as far back as legal
ride height front 5.5, rear 6
3mm caster in front of arms
shock front 2nd hole from bottom, rears layed down
width front 199 rear 200
any questions can be posted, I will do my best to help.
dj apolaro is offline
Old 05-10-2005 | 09:48 AM
  #21383
JustRace's Avatar
Originally posted by dj apolaro
Hi everyone,
drop 0-front 7-rear
default roll center
minus 1 front toe
plus 3 rear toe
front one way
red rear springs
DJ...I've only seen you run the Cadi body What is it about the body that you like? Also, have you tried the madza6?
JustRace is offline
Old 05-10-2005 | 09:55 AM
  #21384
I only use the cady body at that track and oakland park. I use the mazda everywhere else. The cadi is good on the smaller tracks, it is more agressive on the steering, but you loose a little bit of the stability, but the serpent is very stable on the rear, so it is o.k. I have tried the mazda and parma alfa, but the cadi is my favorite at the Miami track.
Old 05-10-2005 | 10:53 AM
  #21385
gonzoY5's Avatar
Hey DJ, going over your setup, would you say you run more droop at RPR compared to the other tracks?
gonzoY5 is offline
Old 05-10-2005 | 11:40 AM
  #21386
not really, but if I do it's only one more.
Old 05-10-2005 | 12:11 PM
  #21387
Sow&Steady's Avatar
I am trying but that other old man beat me already! He just told me he's nearly finished and only just got home from work!
Dang! You are sooo right! I better look at this tonight.
Hmm, another one to look at. Thanks for the tip Pyramid.
Sow&Steady is offline
Old 05-10-2005 | 01:26 PM
  #21388
markp27's Avatar
When the pit monkey is a good pit monkey he can have his chassis
markp27 is offline
Old 05-10-2005 | 07:58 PM
  #21389
clmbia45's Avatar
Looks like the front bearing blocks and rear brace for the radio tray are both milled out lower, there-by lowering the radio tray, and requiring the lower servo saver post to be lower.
clmbia45 is offline
Old 05-10-2005 | 08:45 PM
  #21390
Pyramid's Avatar
Registered User
It has been done correctly on the new chassis as Marks explainned.
Pyramid is offline
