Serpent 710
Old 05-05-2005 | 08:01 PM
  #21361
clmbia45's Avatar
Originally posted by InitialD
Jack, use the side flange collar from the oneway pulley on the ball diff. That's what Art Carbonnel uses.
It's strange. Sometimes I find my ordinary belt also wants to slip out with a front diff. But now, I don't find that problem even when I run with that flange collar from the oneway front pulley. Perhaps it's slightly got to do with the front bulkhead alignment or the ecentric cam...
Concerning the PRO belts, I would use them on a clean track but the track we run on tends to have pebbles here and there. So far I'm very happy with my standard kevlar belts. All 3 belts have not been changed since early January this year. And most of all, I particularly like using the 6361 from the front of the Vector / 950 1/8th scale belt as rear belt.
O.K., I made the mod. But it requires the fabrication of a shim to hold the flange collar up against the pulley. I used a nylon washer 17.4 mm O.D. and 1.5 mm thick. The I.D. is 13 mm, hollowed out with the Dremel.
Appears to track well with no binding, but havn't run it yet.
clmbia45 is offline
Old 05-05-2005 | 10:04 PM
  #21362
markp27's Avatar
Originally posted by GoldFinger
I guess "some people" watch very closely on "some other people" 710 in recent Thailand Nitro Tour.
Great response !
Just shows where the real Ring is
markp27 is offline
Old 05-06-2005 | 04:48 AM
  #21363
crashed_1's Avatar
Use an O ring and lightly grease it so it doesn't bind with the bearing. Works like a charm...
crashed_1 is offline
Old 05-06-2005 | 10:01 AM
  #21364
clmbia45's Avatar
"Reality is perception, not a reflection of truth"
Tell that to Sir Isaac Newton
clmbia45 is offline
Old 05-07-2005 | 09:30 PM
  #21365
Greg M's Avatar
Ran for 3 tanks and the Pro belt stayed on the front until I went to do some donuts (tyres were stuffed). I've put the side of the one way on the ball diff pulley and the o-ring, looks like it should do the job.
Greg M is offline
Old 05-08-2005 | 06:08 AM
  #21366
guys,is the front diff different with the rear diff???btw,d,where are u????very unusual for u lah.
ntc3freak is offline
Old 05-08-2005 | 07:17 AM
  #21367
crashed_1's Avatar
Hey Greg, Initial D might be on your side of the world, Middle Kingdom...He's on a quest to look for the "R I N G"!!!...
Whatever it is, don't let him get his hands on it.
Old 05-08-2005 | 12:23 PM
  #21368
markp27's Avatar
Seems he's looking in the wrong place
markp27 is offline
  #21369
markp27's Avatar
How do you mean ?
markp27 is offline
Old 05-08-2005 | 12:34 PM
  #21370
Greg M's Avatar
Front and rear diffs have different pullies.
So much for border control
Greg M is offline
Old 05-09-2005 | 06:59 AM
  #21371
markp27's Avatar
Default New Chassis
Here it is folks - looks very nice - will be changing my chassis over this week.
Cheers, Mark.
markp27 is offline
Old 05-09-2005 | 07:13 AM
  #21372
Sow&Steady's Avatar
Yup, mine is being installed this week too (gotta work on it in the evenings if 3hobby doesn't take up too much time!).
Love the front belt channel, the edges need the friendly grind of a needle file ... they're sharp!
Maybe I should leave them be ... would make a friendly reminder to any other car make that dare come near it!
Sow&Steady is offline
Old 05-09-2005 | 07:34 AM
  #21373
Pyramid's Avatar
Registered User
How deep is the groove??
Pyramid is offline
Old 05-09-2005 | 07:38 AM
  #21374
markp27's Avatar
If you look from the middle of the chassis, then it is about 1.85mm deep, but even in the milled out section, the area for the belt is further milled to an extra 0.5mm
markp27 is offline
Old 05-09-2005 | 07:41 AM
  #21375
Pyramid's Avatar
Registered User
Thanks... good to know that they are aware of it.
Pyramid is offline
