Serpent 710
Old 03-14-2005 | 06:48 AM
  #20611
markp27's Avatar
Default Re: Re: Re: Re: clutch shims
Originally posted by InitialD
Ummm... Most pedigrees are not pure breeds...
Oooh, yeah, Super *spit* grease
markp27 is offline
Old 03-14-2005 | 06:50 AM
  #20612
markp27's Avatar
Default Re: Re: Re: Re: Re: Re: clutch shims
How can he ask for forgiveness when the person whom you think can give him absolution is committing the same sin?
the church is so corrupt these days!!!
Look carefully Mark and look harder... Eh, did Onkel Sow steal your microscope? Part number has already been given.
Hmmm, I think you need to steal his hearing aid or his Alzheimers medicine!!! I've already said, I stole it from him, but I dropped it and can't find it anymore
markp27 is offline
Old 03-14-2005 | 06:51 AM
  #20613
jag's Avatar
jag
Default Re: Re: clutch shims
Originally posted by B4
I hate to say this but I used the Kyosho shim set as you get more of all the shims and they cost less. Don't have the part number at the moment but if you're interested I'll check for you.
What the heck is going one here? This is the 710 forum isn't it?
If you that thing to run you better use the Serpent shims.
jag is offline
  #20614
markp27's Avatar
Default Re: Re: It's Christmas!!!
What's that? Got late Christmas presents from your Russian nurse?
markp27 is offline
Old 03-14-2005 | 06:52 AM
  #20615
markp27's Avatar
Default Re: Re: Re: clutch shims
Keep the faith brother!
markp27 is offline
  #20616
markp27's Avatar
But why don't you ask yourself! should be familiar to you, no?
markp27 is offline
Old 03-14-2005 | 06:57 AM
  #20617
InitialD's Avatar
Default Re: Re: Re: It's Christmas!!!
InitialD is offline
Old 03-14-2005 | 06:58 AM
  #20618
Pyramid's Avatar
Registered User
Just a side note: dont look at the smoke, trust your temp gun.. give this configuration a try at last and please share with us of what you find yo be the best setups: 0.4-0.6 clucth gap, 2mm spring (centax 2) tension, 0.2mm end play, yellow shoes, mod fliyweights (Glenn C).
Pyramid is offline
Old 03-14-2005 | 07:04 AM
  #20619
InitialD's Avatar
Default Re: Re: Re: Re: It's Christmas!!!
Bro, what are you temping the engine at? 120 degree C?
InitialD is offline
Old 03-14-2005 | 07:05 AM
  #20620
jag's Avatar
jag
Default Re: and again!
Is that sleeve brass or berillium (sp?)?
Is that piston on backwards?
jag is offline
Old 03-14-2005 | 07:08 AM
  #20621
Pyramid's Avatar
Registered User
Default Re: Re: Re: Re: Re: It's Christmas!!!
110C after 5mins warm up, 130C after 45mins with Exergen (non IR) over the top of heat sink. That P/S Mark's posted can do at 190C without get fried Bro.. of course it will automatically slowing down
Pyramid is offline
Old 03-14-2005 | 07:10 AM
  #20622
markp27's Avatar
2mm spring from the 705? Swoooosh!
I'm using the black clutch shoe cut up (thanks Fmolzer) which gives a nice lump of acceleration in comparison to the normal fly weights.
Remember I will be running at 10C outside temps at first, so it may be difficult to get to the 120C.
Should I also run it in a bit hotter than normal? or is 90-95C ok?
markp27 is offline
Old 03-14-2005 | 07:11 AM
  #20623
markp27's Avatar
Default Re: Re: Re: Re: Re: Re: It's Christmas!!!
*faint* *thud* *smoke*
markp27 is offline
Old 03-14-2005 | 07:25 AM
  #20624
Pyramid's Avatar
Registered User
We start with 1.25mm and in average ended up with 2mm. This figure might be totally wrong, so please inform us your best findings. Thanks
Pyramid is offline
Old 03-14-2005 | 07:29 AM
  #20625
InitialD's Avatar
Bro, is that just with one M3 x 4 mm set screw per flyweight and mounted as per manual on the flywheel pin or two M3 x 4 mm set screws per flyweight and mounted in between the flywheel pins?
InitialD is offline
