Serpent 710
Originally posted by Pyramid
We start with 1.25mm and in average ended up with 2mm. This figure might be totally wrong, so please inform us your best findings. Thanks
Originally posted by jag
Is that sleeve brass or berillium (sp?)?
Is that piston on backwards?
Originally posted by markp27
So you mean the spring tension nut set at 2mm?
Originally posted by InitialD
I guess so... The 705 Centax spring coils are 1.8 mm thick versus 1.7 mm for the stock 710. So it's a little bit harder.
Is this just due to this engine or does this hold for all engines?
Bro, is that just with one M3 x 4 mm set screw per flyweight and mounted as per manual on the flywheel pin or two M3 x 4 mm set screws per flyweight and mounted in between the flywheel pins?
Interesting - you tried this out yet?
For me, I've got the thingies mounted between the flywheel pins, but without any grub screws.
When my JP met its maker, it deposited some of the bits of the engine as a rough surface on the combustion chamber. So now instead of the nice shiney surface there, it has a rough texture. Is this still ok to use or do I need a new one?
Originally posted by nitrodude
Would some kind soul give me the diameter of the first gear spur, and the diameter of the flywheel on the 710, please.
Thanks.
Thanks.
I've always used the 705 Centax spring. Well, it depends on engine to engine but if you modify the flyweights, chances are that you need a stronger Centax spring.
Cheers, Mark.
Even if I don't add a grub screw to the modified flyweights? Mine are cut so they lie between the pins.
