Serpent 710
Originally posted by markp27
there he goes showing off his language skills again
Hmmm ... come to think of it, does that make D, who holds the ceremonous record of having the largest number of posts ever as being a prophet or an empty humongous drum?
Originally posted by InitialD
I believe Brett mentioned that RC-Mushroom is all out of stock with the 40 shore Ellegi tires...
Comparing grip and tire wear, how do you rate the Fastlap tire and the Ellegi?
When I got home I noticed that the wear rate were also much better. Mind you my Ellergi's are old stock brought over from home while these Fastlaps were bought at the track.
Originally posted by Brett.w
Hi Guys i have the N.Z nationals in a couple of weeks and i cannot get any 40sh front or rear serpent rims
so i an going back to the old faithful Fast tyres dish rims, the only problem i had with these is they rub on the steering arm, so i bought some 1mm offset hubs to go on the front. what i wanted to know is how will this affect my car?
http://www.twistertires.com
Originally posted by Marcos.J
you can cut the tyre width by 1mm to clear the steering arm. Thats what i did when i had my serpent.
That would give you 1 mm less of tire surface in the front for available grip and that handling would be affected some how...
well maybe a little bit but better than having the rim rubbing the steering arm and making it weaker
Anyway, using spacers or using offset wheel hexes is a better solution than cutting the tires narrower... Unless you really know what you're doing like cutting down front traction like what Art Carbonnel does at Ft Myers...
Originally posted by Car Breaker
beside ellegi, a brand call fastlap also make wheel that will perfact fit 710, try that out if you can find one.
else just order ellegi from RC-Mushroom.
tyre is not a concern
, Now that you're an International driver
, you can make a visit here the Island, I can be your personal Tour guide
, take a look at our permanent track in Barceloneta , now get the picture,, R/C - Beaches, Beaches - R/C,
I am puting together the rear ball diff. I have read on mytsn a couple articles on how to set it up. however I am a little confused. Once i put it together and get to the part where i screw the two pices together do i screw it in until its tight or just enough until i can't turn the pulley by holding both the shafts?
also does anyone sell just the ball bearings that go in the rear diff? I lost one and cant complete it until i have all 12.
Serpent ball diff spare balls and plates
