Serpent 710
Originally posted by GoldFinger
Hi,
When using 2343 is it true that the transmitter should ON first before connecting servo to battery?
Otherwise, the servo would not work, is it true ?
Thanks.
Hi,
Thanks.
Hi,
Thanks.
Hi,
Thanks.
Originally posted by crashed_1
Yup. If you plug in the batts b4 the transmitter...the servos will twitch a little but then it won't function when the transmitter in on.
But taking Baxter comment (thank you baxter, that is healthy advice) bit contrary.
I guess you both right, it must be something on their "ICS" programming default.
Crashed, if your servo acts like that it would be a problem when attending a big race with tight schedule.
THe TX is very far from you and you cannot clip your shell completely from paddock.
Have you ever try to use ICS to change that?
Ooops..
Ooops..
Ooops..
Ooops..
It is a hassle indeed...that's where a good pitcrew comes in handy...
Originally posted by BaxterC
You just explianed a problem I had, I thought it was the switch, so I removed it.
You know, last night I spent almost 1 hour for "what happen to the connector?"
I think it was the connector, bit loose on the R113iP so replace it 2 times with new connector !!
On last minute before I throw this servo, I just realise that.
Now I must find some more "victims" so we can buy it "together"
Pardon my ignorance...but what is an ICS?...
I hope i can program the servo when to turn left at what speed and turn right after hard breaking.
I believe your "handy pitman" is your wingman?
I got a problem with my wingman coz he is still faster than me so I can not tell him to do this and that.
Originally posted by markp27
Actually, I'd be willing to pay for the fuel
But the dates will be tricky - July and August are out as I've got bike events every weekend and my folks come to visit at the begining of Sept. When do your races run until? End of Sept should be fine?
For September there are 2 club races: 5th and 19th. Which one?
Originally posted by Pyramid
I believe the speed is the same
Yes, its the same. Note also that the average person takes 0.3 secs from the time the brain says to do something to the time it is actually done. Unless you're a top F1 driver (apparently they all have superfast reflexes) then you'll be hard pushed to beat the 0.1 (S9550) or the .008 (KO 2343) specs of these servos.
Your comment about the throttle linkage is absolutely correct. I suffered this when I changed over my engine from the old JP to the slightly newer Rody. What I found was that the Rody's full open is really microns away from the barrel touching the dead-end!
Originally posted by Titan
Crashed_1,
Thanks dude.
Guys,
I was also wondering if I should get KO Digis 2344 or 2343? I am leaning towards the 2344 servo with lotsa torque.. What do you guys think?
Crashed_1,
Thanks dude.
Guys,
Originally posted by Sow&Steady
Mark, series 2 this year runs all the way to November 21st ... brrrr!
Have you experienced November in the UK yet?
Maybe the 5th, I'm not sure when my folks are coming over - 19th is a definate no. What comes after thaT?
Hi,
Thanks.
Hi,
Thanks.
November
November
On top of this, students could never afford heating!
Sunday 07 November, Sunday 07 November 2004.
You can't get out now my friend ... plenty of dates to choose from!
