Old 03-07-2005, 03:43 PM   #20461
FW-05RR's Avatar
paul how do you like the mega engines?
FW-05RR is offline   Reply With Quote
Old 03-07-2005, 04:17 PM   #20462
paulfitipauldi's Avatar
Thumbs up
Just one word,,, AWSOME!! ,, this is the best engine I ever test,, last sunday I went racing, and after few months of retirement, I came back very strong ,, thanks to Serpent and this mega engine, I was able to make the A main, with 17laps like the other racers that are very active in this hobbie, in the A main, 9 out of 10 cars were Serpents 710, three of then including mine, were running mega combos, Stock out of the box,
the others were running, Murnan's, Maxy's and Jp's Fx, and I didn't saw any diference between all of these engines,, just a little with the Jp, , the cars were face to face in the backstrech, last thing to say is , what more you want for $260.00??,,
Easy to break in ,, in five tanks you have almost break in done, this engine like to run in between the 200 to 220 degrees, with other engines you have to run in the 260's to have this performance ,, If you have plans to buy another engine, you may consider this baby first!!
paulfitipauldi is offline   Reply With Quote
Old 03-07-2005, 07:08 PM   #20463
InitialD's Avatar
Hey Paul, congrats on the strong finish even after semi retirement. It looks like Mega all the way.
Hey, I assume the Mega engine you got was a 3 port RACE with the powerpack pipe combo?
Old 03-07-2005, 07:25 PM   #20464
Thanks D,, and yes , is the power pack combo, with a 7 hot mega glow plug and 30% Blue Thunder fuel, temp at 200 degrees farenheith in a beautifull sunny caribbean day at 90 degrees!!
Old 03-07-2005, 07:38 PM   #20465
InitialD's Avatar
I like the sounds of that ! <looks over to our cold Euro counterparts... >
Old 03-07-2005, 08:00 PM   #20466
FW-05RR's Avatar
nice!!! great job
Old 03-07-2005, 08:35 PM   #20467
Darth Vader's Avatar
D,
You got PM...
Sorry, Force not strong enough, still need PM...
Darth Vader is offline   Reply With Quote
Old 03-07-2005, 10:36 PM   #20468
markp27's Avatar
Send a message via ICQ to markp27
markp27 is offline   Reply With Quote
Old 03-07-2005, 10:36 PM   #20469
markp27's Avatar
Old 03-07-2005, 11:26 PM   #20470
Default Serpent rims
Hi Guys i have the N.Z nationals in a couple of weeks and i cannot get any 40sh front or rear serpent rims so i an going back to the old faithful Fast tyres dish rims, the only problem i had with these is they rub on the steering arm, so i bought some 1mm offset hubs to go on the front. what i wanted to know is how will this affect my car?
Brett.w is offline   Reply With Quote
Old 03-07-2005, 11:33 PM   #20471
InitialD's Avatar
Default Re: Serpent rims
Easy. Whatever you do, set and maintain the front (or rear) trackwidth with the tires you're going to use to the same you were previously doing...
If you were doing 199 mm with Ellegi tires, makes sure you set it back to 199 mm when you're using FAST tires with the 1 mm offset hubs.
Old 03-07-2005, 11:43 PM   #20472
Default Re: Re: Serpent rims
Thought so just needed to confirm thanks for your help mr D
Old 03-08-2005, 12:08 AM   #20473
Car Breaker's Avatar
Default Re: Re: Re: Serpent rims
beside ellegi, a brand call fastlap also make wheel that will perfact fit 710, try that out if you can find one.
else just order ellegi from RC-Mushroom.
tyre is not a concern
Car Breaker is offline   Reply With Quote
Old 03-08-2005, 12:24 AM   #20474
InitialD's Avatar
Default Re: Re: Re: Re: Serpent rims
I believe Brett mentioned that RC-Mushroom is all out of stock with the 40 shore Ellegi tires...
Comparing grip and tire wear, how do you rate the Fastlap tire and the Ellegi?
Old 03-08-2005, 01:26 AM   #20475
Send a message via ICQ to _cyclops_
http://shop.the-border.nl/product.ph...9&cat=1&page=1
enetti's
_cyclops_ is offline   Reply With Quote
