Serpent 710
Old 05-02-2005 | 04:20 AM
  #21331
Originally posted by performula
Who has the best deal on the 710? I'd like to pick one up, but I bet Serpent is working on their successor as I type this.
Also is the 710 manufactured in Holland or Taiwan? Curious, has nothing to do with anything.
performula is offline
Old 05-02-2005 | 01:23 PM
  #21332
hamann's Avatar
Originally posted by Greg M
Was looking at my switch last night of where I could put it as it was double sided taped to the receiver box and was abit exposed. I'll fit it the same as yours as I have the KO 302 receiver as well
yes, it's KO 302F. if you want same as picture, you can easily do this. just get an on-off switch (smallest one) and modify the top deck of receiver box, thats all. i made this modification by using dremel.
hamann is offline
Old 05-02-2005 | 01:36 PM
  #21333
Originally posted by JustRace
Joe...at least change the nick to JoeSerpent before posting on the 710th page See you this weekend. Oh..can I borrow the JP?
i did not see this until now.... i guess its too late to say yes... what happend to you this weekend?
Joe Chaplow is offline
Old 05-02-2005 | 10:16 PM
  #21334
InitialD's Avatar
Originally posted by hamann
it means i started with serpent and i'm still driving serpent .
We have something in common.
what do you think?
Looks very good and very nicely done. Reminds me on those Friday pics we used to have. You deserve a good pat on the back.
BTW, the 710 looks better than the T1 EVO.
InitialD is offline
Old 05-02-2005 | 10:20 PM
  #21335
InitialD's Avatar
Becareful with the switch... If you insist on using it, try and use it with a DIY switch guard made of lexan piece which would prevent the switch from closing when you get hit at that spot.
InitialD is offline
Old 05-02-2005 | 10:27 PM
  #21336
TitaniumR's Avatar
Default Lower TH Servo
Appreciate if anyone here can share how to lower the throttle servo. It sits rather high and lowering I think might help in less traction roll possibility and improve handling even further. Thanks.
TitaniumR is offline
  #21337
InitialD's Avatar
Originally posted by clmbia45
Seriously, the rolling resistance is decreased with the new belts, but I doubt it's worth the trouble to fabricate a belt guide. The obvious answer is to mold a collar on the port side of the pulley.
Jack, use the side flange collar from the oneway pulley on the ball diff. That's what Art Carbonnel uses.
It's strange. Sometimes I find my ordinary belt also wants to slip out with a front diff. But now, I don't find that problem even when I run with that flange collar from the oneway front pulley. Perhaps it's slightly got to do with the front bulkhead alignment or the ecentric cam...
Concerning the PRO belts, I would use them on a clean track but the track we run on tends to have pebbles here and there. So far I'm very happy with my standard kevlar belts. All 3 belts have not been changed since early January this year. And most of all, I particularly like using the 6361 from the front of the Vector / 950 1/8th scale belt as rear belt.
InitialD is offline
Old 05-02-2005 | 10:28 PM
  #21338
InitialD's Avatar
Holland.
InitialD is offline
Old 05-02-2005 | 10:32 PM
  #21339
InitialD's Avatar
Default Re: Lower TH Servo
You would get the lowest possible if you use a Futaba S9550 low profile servo.
I've tried mounting the normal S9451 and KO 2144 servos under the radio tray to get the throttle / brake servo to sit lower but the problem would be to avoid the chassis from hitting against the servo body. I've not tried other servo bodies. If you think it's iomportant for you, you could try and mill chassis a little so that the servo body clears the chassis.
InitialD is offline
Old 05-02-2005 | 10:43 PM
  #21340
markp27's Avatar
I should get my hands on the new chassis this weekend I'll post some pics when I have it.
markp27 is offline
Old 05-02-2005 | 11:22 PM
  #21341
InitialD's Avatar
P R E C I O U S !
What kind of connections is this Mark?
InitialD is offline
Old 05-02-2005 | 11:34 PM
  #21342
markp27's Avatar
Originally posted by InitialD
P R E C I O U S !
Only the very best, as you would expect! Go to The-Border and order yourself one
http://www.the-border.com/product.ph...cat=81&page=10
markp27 is offline
Old 05-03-2005 | 02:06 AM
  #21343
buboy28's Avatar
i like those universals does the border have them already
buboy28 is offline
Old 05-03-2005 | 03:46 AM
  #21344
Darth Vader's Avatar
Default Tire dia.
Guys,
What's minmum dia tires can we run on the 710 before the suspension geometry starts getting really screwed up?
What's the optimum tire dia?
Darth Vader is offline
Old 05-03-2005 | 06:17 AM
  #21345
when i raced this car in the winternats, i used 59 rear and 58 front and it worked very good. i think some even used 58 rear and 57 front. i think that new chasis maybe would help this as well.
