Serpent 710
Old 05-10-2005 | 09:13 PM
  #21391
markp27's Avatar
The new chassis looks and feels very nice - I'll post some pictures of the finished car tonight. Hopefully I can test my car tomorrow
markp27 is offline
Old 05-10-2005 | 09:16 PM
  #21392
markp27's Avatar
Originally posted by Pyramid
It has been done correctly on the new chassis as Marks explainned.
Pyramid,
Checking my completed car with the Futaba 113ip rx, it looks to be just about level with the bottom of the chassis. I'm going to try to remove a little material from the rx side protector, in order to be able to mount it a little higher.
Cheers, Mark.
markp27 is offline
Old 05-11-2005 | 01:03 AM
  #21393
Originally posted by markp27
Pyramid,
Cheers, Mark.
Some alternative :
- Dont use (802150) Receiver Bracket, double-tape the PCM rcv on the (802151) Receiver cover. Put 2 (1 on each side) O-ring between deck and rcv cover.
- Make some L shaped spill protector from thick lexan to protect the top of rcv. Tomorrow, I will post the picture.
Its simple, its clean, its Serpent 710....
Other than that , you should do Pyramid's mod on DTS ver4.
GoldFinger is offline
Old 05-11-2005 | 01:08 AM
  #21394
markp27's Avatar
Originally posted by GoldFinger
Some alternative :
Look forward to seeing the pics, Goldfinger - I'm looking for an alternative way to mount the Rx, as I can't pack my Rx unit in a balloon so easily with the current system. And access to the Rx is very restricted. Unless I use my LRP Rx unit.....hmm.
markp27 is offline
Old 05-11-2005 | 01:24 AM
  #21395
markp27's Avatar
Which mod is this, Goldfinger?
markp27 is offline
Old 05-11-2005 | 01:36 AM
  #21396
Sow&Steady's Avatar
Use Jedi mind control to control that from now on!
Sow&Steady is offline
Old 05-11-2005 | 01:39 AM
  #21397
Sow&Steady's Avatar
Some alternative :
you mean have the Rx horizontal? Never mind ... a few pictures will say a thousand words.
Good one.
What? Where?
Old 05-11-2005 | 01:58 AM
  #21398
markp27's Avatar
I tried it at the weekend and now I have water on the brain from all that rain
markp27 is offline
Old 05-11-2005 | 02:29 AM
  #21399
I mean ver5.
Hi Uncle Sow, im feeling old now..
I just realize that Pyramid forgot to post the receiver bracket picture ??!!
In ver 5, we gain 2mm lowered deck thats why we have some problem with receiver cover.
What he did was milled out the top section of the bracket, almost 1.5mm higher(when mounted). And 1mm cut on both notch at receiver cover.
While mines broke and the workshop is busy, im trying out another solution. Less sophisticated but works fine.
Old 05-11-2005 | 02:51 AM
  #21400
markp27's Avatar
I mean ver5.
I'll send you Uncle Sow's micro-scope with nightvision built in.
I had to get it upgraded after this German Nationals Round 2.
markp27 is offline
Old 05-11-2005 | 05:52 AM
  #21401
Sow&Steady's Avatar
I mean ver5.
Welcome to the club of "Uncles"
Will wait for the pictures.
Old 05-11-2005 | 09:17 AM
  #21402
markp27's Avatar
Default 710 Team Chassis
Here it is in my car now
markp27 is offline
Old 05-11-2005 | 09:22 AM
  #21403
apla's Avatar
is there any kit in marker that contains this shassis?
apla is offline
Old 05-11-2005 | 09:28 AM
  #21404
Default One-way and rubber tires..
Hy guys ... just got my Serpent 710 tody ;-) It came of course, with a One-Way in front. Where i race, the rules only allow rubber tires, so, i want to ask, is there anything differente ?? Because, as far as i know, rubber don't give as much grip as foam, so a one-way diff won't be that good, and i can't use overdrive in rubber tires also.. because they're all the same size..
Any thought please !?!?!?!
TY
Rodrigo Meira
RMeira is offline
Old 05-11-2005 | 09:38 AM
  #21405
markp27's Avatar
Default Re: One-way and rubber tires..
TY
Rodrigo Meira
Rodrigo, I can't comment so much on Rubber tyres, as we only use them here when its wet, but I would suggest that you get the front diff - the car goes really well with the diff. I use the diff 90% of the time.
Cheers, Mark.
markp27 is offline
