Serpent 710
Old 03-19-2004 | 03:13 AM
  #6376
BaxterC's Avatar
It feels more like a storm than a mere disturbance....
Its not a sepent... GET HIM!!!
BaxterC is offline
Old 03-19-2004 | 03:17 AM
  #6377
crashed_1's Avatar
Are you sure your eyes are not playing tricks on you?....
crashed_1 is offline
Old 03-19-2004 | 03:19 AM
  #6378
BaxterC's Avatar
That's better, disturbance subsided it has. I feel...???
BaxterC is offline
Old 03-19-2004 | 04:26 AM
  #6379
cyba888's Avatar
Why would you put silly putty on your pipe? j/k
cyba888 is offline
Old 03-19-2004 | 04:28 AM
  #6380
markp27's Avatar
What did you order? I ordered the stainless steel brakedisk and the racing brake pads. I wanted to order the spring steel drive train stuff but it is a little pricey at the moment
Can't remember the words "Darkside" "Vision" and "Clouded" spring to mind!
I've got a load of Ti screws on order aswell as some springs and some stuff for my Surikarn.
markp27 is offline
Old 03-19-2004 | 04:37 AM
  #6381
BaxterC's Avatar
Sweet... I cant afford to get Ti screws now so I will have to wait a little... I want to get the car first. I am worried I will order all the little thing, but then when I place the order for the car, I can afford it and will have to wait another month.
BaxterC is offline
Old 03-19-2004 | 04:56 AM
  #6382
Marcos.J's Avatar
Super Moderator
Originally posted by Profoxcg
awesome track!
how far is it from Pembroke Pines? I am live close to I595 and I75
probably about 2 hours -2 1/2 hrs my guess
Marcos.J is offline
Old 03-19-2004 | 05:16 AM
  #6383
Julius's Avatar
Originally posted by clmbia45
Julius, are they worn down evenly, so both front and rear are @56mm at the end? What do you think about a little higher OD ratio, say 0.5mm larger front tires? Thanks.
On the day of this test the front/rear wear was pretty even. I started with a 0.5 split (fronts smaller) and ended up with equal tire sizes.
With same size tires on the 710 you have a little overdrive. If you use more overdrive the turn in (using a one way) is better as the fronts try to slow the car when you get off throttle. Out of corners you will most likely get a little more stability/push than with a 1:1 ratio. Because of the tendency to get oversteer into corners a large front overdrive does not work on slippery tracks. Than you will be better of using a front diff for stability.
In very tight twisty tracks an overdrive might be helpfull. We'll see if a 21 pulley is a worthwile option.
There are no plans yet so no need to ask for release dates
Julius is offline
Old 03-19-2004 | 05:26 AM
  #6384
Default Marcos,
I am going to have to plan that trip sometime when I get a little better. but that I will go drive your track I will !
Profoxcg is offline
Old 03-19-2004 | 05:39 AM
  #6385
BaxterC's Avatar
Hey there guys... have a look at this... it is one of the tracks I will be racing at....
http://www.mytsn.com/publ/publmem.asp?pid=2408
BaxterC is offline
Old 03-19-2004 | 05:44 AM
  #6386
cyba888's Avatar
Dont forget to have someone take a picture of you on the podium when you finish the race. Nice track BTW
cyba888 is offline
Old 03-19-2004 | 05:49 AM
  #6387
BaxterC's Avatar
And here
http://www.mytsn.com/tracks/track.asp?cid=140
I will post all my podium finish photos.
I will post all the pics of building, from start to finish, to running the engine in to racing...
BaxterC is offline
Old 03-19-2004 | 05:57 AM
  #6388
BaxterC's Avatar
What would I do if I dont have a mechanic to refuel my car... where would I get one from... I work too long and hard to have friends... I wonder if I can get my Girlfriend to do it...
BaxterC is offline
Old 03-19-2004 | 06:26 AM
  #6389
BaxterC's Avatar
Ahhhh... that feels better... yet another track... http://www.mytsn.com/publ/publ.asp?pid=2769
BaxterC is offline
Old 03-19-2004 | 06:36 AM
  #6390
markp27's Avatar
Bad idea, BaxterC, bad idea Ask Lord D and myself - never, ever get Girlfriends involved - never even let them know you've got a car! And if they do find out, make sure they only see one of your cars at the same time! You can get into big trouble!!
The great thing is - all cars look alike to girlfriends, so if you're clever, you can have quite a collection and they'd never know
Ask D, he'll give you some good hints at "car-hiding"
Other than that, you'll get to know some guys at the track and they'll be able to help out on race days - on practice days you won't need much help in re-fuelling
markp27 is offline
